    [Plugin] Smooth Zoom 2.1.0 - 24 October 2021
    76 Posts 31 Posters 98.6k Views 30 Watching
      Anton_S
      Thanks, Pilou! I find it very convenient. I wish SU made this part of its features.
      • N
        numerobis
        VERY COOL! I will install it now! Thank You! πŸ˜„
        • C
          cadmunkey
          Fantastic, SU needs this so much on large models! Cheers.
          • F
            function
            I was just thinking of this idea in SKP last week! thanks anton
              Anton_S
              Thank you
              Thank you
              And Thank you
              I found some type where this new zoom tool doesn't behave properly. I will investigate and upload a fix next week. As well, I think camera acceleration and deceleration should be added too.
              • BoxB
                Oh what a difference! Excellent.
                That's one of those plugins that you didn't really know you needed but now couldn't do without.
                  Anton you are a legend!
                  • F
                    function
                    @anton_s said:
                    Thank you
                    Thank you
                    And Thank you
                    The plug stopped working for me, panning left and right instead of zooming, but I was and am still assuming it has to do with all the mousehook ahk files I'm running.
                    Here is another idea on the lines of acceleration: flick-panning
                    I hated this feature when adobe put it on default in photoshop, but have since grown to love it for quick navigation.
                      Anton_S
                      Thanks, function.
                      I have some tool installed and encounter similar problems where the mouse wheel in Sketchup stops workin'. This happens because the tool doesn't pass it's mouse hook notifications to the next hook on the list, which prevents my hook from working. I will see if I could change my script to use a different type of hook, such as message proc, which can also monitor mouse wheel messages.
                      I will see if I could implement the flick-panning feature. Thanks for suggestion.
                      • BoxB
                        I'm finding it quite unstable, it often needs to be disabled and enabled to get it going again. It doesn't play well with some other plugins. For example Fredo's new VisuHole makes it run slow and then drop the zooming function while still showing enabled.
                        Love the plugin, just catching bugs.
                          Anton_S
                          Thanks for feedback, Box.
                          I will see if what I can do to improve it.
                            johnwmcc
                            Just tried this on 64-bit Win7 and SU 2015 Pro 64-bit - crashes on launch with error that starts:
                            Error Loading File C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ams_SmoothZoom/main.rb
                            Error: #<LoadError: 193: %1 is not a valid Win32 application. - C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ams_SmoothZoom/win32/2.0/ams_smooth_zoom.so>
                            Presumably designed for 32-bit SU?
                            Had to delete from Plugins folder.
                            Works very nicely in older SU 2014 32-bit - it would be great to have it updated for 64-bit SU 2015, if possible.
                              Anton_S
                              Hello John,
                              Sorry for not replying. I never noticed this post. πŸ˜’
                              Yes, the plugin is not compatible with SU2015. I already got it working, but I want to add all prior requests before posting the new version.
                              -- Anton
                                Hi Anton,
                                Getting this on SU2015 at startup....
                                Error Loading File C;/Users/user1/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ams_SmoothZoom/main.rb
                                Error; #<LoadError; 193; %1 is not a valid Win32 application.   - C;/Users/user1/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ams_SmoothZoom/win32/2.0/ams_smooth_zoom.so>
                                C;/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb;45;in `require'
                                C;/Users/user1/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ams_SmoothZoom/main.rb;8;in `<top (required)>'
                                C;/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb;197;in `require'
                                C;/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb;197;in `load'
                                C;/Users/user1/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ams_SmoothZoom.rb;55;in `register_extension'
                                C;/Users/user1/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ams_SmoothZoom.rb;55;in `<module;SmoothZoom>'
                                C;/Users/user1/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ams_SmoothZoom.rb;37;in `<top (required)>'
                                  @rich o brien said:
                                  Hi Anton,
                                  Looks like you have 64bit SUp v2015 and this tool has a Ruby? 32 bit .so ?
                                  It quite possible to compile two or more .so files, so they are either 32 bit or 64 bit and load/require the correct one...
                                  For example..
                                  if defined?(Sketchup.is_64bit?) && Sketchup.is_64bit? ### >= v2015
                                    my_so = File.join(File.dirname(__FILE__), 'win32', '2.0', 'ams_smooth_zoom_64.so')
                                  else ### it's < v2015 and/or 32 bit - use existing .so version ?
                                    my_so = File.join(File.dirname(__FILE__), 'win32', '2.0', 'ams_smooth_zoom.so')
                                  require(my_so)
                                    Anton_S
                                    Ugh, I forgot about this plug... Will update once get home.
                                    • BerserkB
                                      Berserk
                                      Very nice idea! And it will be better if add scrolling speed dependence.
                                      • L
                                        leetran72
                                        When will you fix it for x64 T.T
                                          Anton_S
                                          Making an update is a piece of cake. I just wanted to include all the feature requests and fix bugs before uploading, but upon your request I'll upload 64bit version shortly.
                                            Thanks Anton.
                                            Your tools are always killer!
                                            • 1 / 4
