    Auto make multiple group or component
    24 Posts 16 Posters 21.0k Views 16 Watching
      grjames
      Hi all,
      I've got a couple hundred buildings floating above my terrain. I'd like to make each of these into their own group or component before dropping them down.
      Does anyone know of a workflow or ruby that can do this one time? Like i'd select all the buildings at once and then it would make each individual building its own group or component? kinda like a batch process rather than selection each by itself and making it.
      tia,
      rob
      • mitcorbM Offline
        mitcorb
        Hi. This is the closest possibility to what I think you are asking. Check it out.
        http://forums.sketchucation.com/viewtopic.php?t=31892#p281272
        May I suggest that you save as and do this on a second file with a similar name?
          Copy/Paste this code into a new plain-text file called say TIG-selected_connected_into_components.rb in the Plugins folder.
          require('sketchup.rb')
          module TIG
           def self.selected_connected_into_components()
            model=Sketchup.active_model
            ents=model.active_entities
            ss=model.selection
            faces=[]
            ss.each{|e|
              if e.class==Sketchup;;Face
                faces << e
          	  faces << e.edges
            faces.flatten!
            faces.uniq!
            cons=[]
            faces.dup.each{|e|
              next unless e.valid? and e.class==Sketchup;;Face and faces.include?(e)
          	con=e.all_connected
          	con.each{|c|faces.delete(c)}
          	cons << con
            model.start_operation("TIG.selected_connected_into_components")
            cons.each{|con|
              grp=ents.add_group(con)
          	ins=grp.to_component
          	defn=ins.definition
          	defn.invalidate_bounds
          	defn.name="Component#1" ### will increment
            model.commit_operation
          ### Usage; Select what faces are to become components
          ### TIG.selected_connected_into_components in the Ruby Console
          Its usage is explained at the end of the code...
          You select the appropriate geometry [faces], run the tool by typing/pasting its command - TIG.selected_connected_into_components - into the Ruby Console... all "connected geometry" is made into separate components, named Component#1, Component#2 etc...
          [mod=:3qy3sl05]To be v2014 compatible encode the file as UTF8-without-BOM [Notepad++.exe encoding>convert option][/mod:3qy3sl05]
            grjames
            Nice! thank you!
              Lersince1991
              TIG I just tried to use this ruby script but couldn't get it to work and brings up an error when loading sketchup, could you please help?
              Got it sorry!
              missed the "TIG-" off the start of the file name and also was saving in rich text format by accident (fresh OS X installed changed defaults)
                dav78
                Hi, I can't make it to work, not sure what I am doing wrong...!
                Could somebody provide the .rb file to paste in the plug-in folder?
                ...and perhaps a plainer step-by-step guide.
                  Have you actually read the earlier post ?? http://sketchucation.com/forums/viewtopic.php?p=379876#p379876
                  Copy the suggested text and paste it into a new .rb file, and put it into the appropriate SketchUp Plugins folder.
                  If you have Windows use Notepad++.exe and encode it as 'UTF8-without-BOM' - a MAC should encode the .rb OK - you haven't bothered to give us any useful info in your SCF user-profile, so we are somewhat hampered by your decision...
                  If you have specific questions, like, "Where is my Plugins folder?", or you don't understand security permission for such folders proir to v2014, then please ask clear questions...
                  We ARE here to help, but we can't read minds..........
                  You need to restart SketchUp and type into the Ruby Console to run this script......
                  • sketchartist023S Offline
                    sketchartist023
                    Hey Guys 😄 I tried the code and made the simple txt file into an .rb and created a plugin folder in which it read the rb fine when I went into the ruby console and typed the command. All the selected components were created but when I make components on my own, the axis is offset. I noticed this when I made a cultist and the thickness was all over the place. So basically, this particular ruby has some defaulted off-axis setting for components. When I create my own components from solids to rename manually (since I don't want to use "component #1, ...) as my cultist names, it still is offset and the component boundary is larger than the actual edges of the solid instead of reading the actual volume corners and faces properly.
                    When I went into the library support (using an iMac with Mavericks), and deleted the .rb file, the components read the axis' correctly when I closed sketch up and then reloaded the file.
                    Just wanted to share my experience with it so far. It creates components great! Just every other "new" manual component is off axis and seems to have to be set manually. Solids with angles, like 45s in the corners etc do not work well with resetting axis' manually when this script is in the plugins.
                    Sometime I would like to be able to use this plugin idea and auto create the component description as the text information that is attached to it! That would be amazing!
                    I will help you diagnose this if you like and be a test dummy if you want 😄
                    I hope that is enough information to help and appreciate the help if you can 😄
                      Kenny
                      I've just tried this on SketchUp 2015 and I get the attached error. Does it work on 2015?
                      If it's not 2015 compatibility at issue then it could be encoding. I created the file in Notepad, which I've also attached. I chose UTF8 encoding however I couldn't see an option for "without-BOM [Notepad++.exe encoding>convert option]". I'm not familiar with coding so I don't really know what this is.
                      Tig, Ideally it would be good to have this as a standard plugin which could be autoinstalled. 😄
                      TIG-selected_connected_into_components.rb.txt
                      http://www.townscapesolutions.co.uk/
                        Use Notepad++ to convert the file's encoding to UTF-8_without_BOM and save it.
                        It IS a standard encoding format in the list.
                        That is the encoding format required in > v2013, it also works in earlier versions.
                        Attached is the converted .rb, BUT please check how to do it yourself...TIG-selected_connected_into_components.rb
                        To make it easily installable simply ZIP the RB fie, then rename the file-type suffix from .zip to .rbz...
                        Again I have attached one, BUT once again, please check how to do it yourself...TIG-selected_connected_into_components.rbz
                          Kenny
                          Thanks TIG that's great. The problem was that I was using Microsoft Notepad and not Notepad++ which I had to download.
                          Regarding the installable file, does it create a menu item anywhere? I can't see any. It would be good if you could select the geometry, then either right click or click a menu item under Extensions which would make the multiple components, rather than having to paste into the Ruby console each time. It's no big deal however as the fact that I can do it all is a massive time saver, so thanks again for creating it.
                            If you read the usage it runs from the Ruby Console with TIG.selected_connected_into_components
                            It's easy enough to add a menu item...
                            Edit the file using Notepad++ and at near start find module TIG
                            Immediately after it, insert these new lines.
                            unless file_loaded?(__FILE__)
                              UI.menu("Plugins").add_item("TIG.selected_connected_into_components"){self.selected_connected_into_components()}
                              file_loaded(__FILE__)
                            Save it and restart SketchUp to reload...
                              Kenny
                              Excellent, thanks again TIG.
                              • F Offline
                                fendarria
                                thank you TIG.. but in my case i want to group every face in the model.
                                for example: i have 63 face in a sofa model. i want 63 seperate group/component in one click.
                                for your ruby script, it only make component touching all faces.
                                how can i achieve that?
                                  @fender
                                  Copy+Paste the one-liner below into a Notepad++ file.
                                  The reason for that is so you can edit the start part n="???", this sets the name of each group Face#1, Face#2 etc... If you are processing several parts it might be useful to have differing names ? They list in the Outliner in alphanumerical order.
                                  Select what you want to separate into groups - only faces are processed so no need to be too careful, just ensure the faces you want to group are included.
                                  Copy all of the text.
                                  Open the Ruby Console.
                                  Paste the text.
                                  Press <enter>.
                                  Now all selected faces are made into separate groups.
                                  It is one step undo-able...
                                  n="Face";m=Sketchup.active_model;s=m.selection;fs=s.grep(Sketchup;;Face);s.clear;a=m.active_entities;m.start_operation("~",true);fs.each_with_index{|f,i|g=a.add_group(f);g.name="#{n}##{i+1}"};m.commit_operation
                                  • F Offline
                                    fendarria
                                    @TIG
                                    it works perfectly!! thank you so much! you save my day
                                    • ssokolS Offline
                                      ssokol
                                      great thanks!!!
                                        Klamek
                                        Great plugin!
                                        Saved my time for hundreds of separated objects to group/component!
                                          keitheseymour
                                          Took me a few goes to get it running but got there! This is just what I needed. Huge thanks, Tig.
                                          • maxhouserocksM Offline
                                            maxhouserocks
                                            this is such a great time saver for tricky situations. thanks!
                                            Has this ever been officially made into a plugin for the masses?
                                            thanks,
                                            bob
                                            Robert A. Christman
                                            http://rachristman.blogspot.com/
