    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.2k Views 110 Watching
    • BoxB Offline
      Hmmm, interesting, I'm on the same setup. I just updated the plugin and it still does it. I'll have to have a look around and see if it's something up my end although both Sdmitch and Eneroth3 were able to give me the line edit to stop it opening.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Could you send me what they told you to modify for their plugin?
        • BoxB Offline
          Here you go.
          Deck builder
          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58084%26amp;p=533860#p533827
          Railway
          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57831%26amp;start=240#p533089
            jiminy-billy-bob
            Ok, try to redownload, I added Eneroth's fix.
            • BoxB Offline
              Yep, that's done the trick. Thanks.
                glro
                I tried
                I got an error message while i was trying to move some layers to a group
                too bad
                the appearance is well finished, and it fits a need
                error message
                  @giro
                  What version of Internet Explorer do you have ?
                    glro
                    internet explorer 11.0.9600.17239
                    @tig said:
                    @giro
                      jiminy-billy-bob
                      Sorry, I was away and didn't see your post.
                      Could you translate the error message?
                      I can't reproduce it, could you explain in detail how you got the error?
                        glro
                        "not possible to get the property "inserbefore', reference null or not defined...
                        do you want to continue script of the page?"
                        more or less...
                          jiminy-billy-bob
                          Thanks,
                          Could you explain in detail how you got the error?
                            glro
                            Thanks,
                            i was trying to make a group of different layers
                            i selected them as shown in the video, and i couldn't drop them
                            but...
                            i tried again and this time it worked
                            false alarm, sorry
                            seems to be working on my computer too
                              jiminy-billy-bob
                              Great, I'm glad it works.
                              Maybe you tried just after installing the plugin, before restarting SU?
                                jiminy-billy-bob
                                Thanks for the donation, glro, I appreciate it! 😉
                                • F Offline
                                  fountainhead
                                  I've had some strange behaviour creep in with layers panel recently. At least once a day, possibly more, the layers dialogue ends up blank, with no layers showing at all. When I chose the recent history dialogue, only one of multiple layers is restored. The only solution for me is to close Sketchup, remove both the jbb_layers_panel folder, and the jbb_layers_panel.rb, then reload Sketchup, and reinstall the .rbz file. Once that is done, all of the layers show up again...until the next sudden disappearance. I need to point out that the layers don't disappear from an .skp file that is currently open, only when opening an existing .skp file initially. The behaviour also repeats itself with the same .skp file over and over. In the last 3 days, I have had to unload/reload layers panel on the same .skp file on 4 separate file opening occasions. Any ideas?
                                  • F Offline
                                    fountainhead
                                    A little more information. Opened an skp file this morning, no layers. Unloaded and re-loaded layers panel, all good. Opened a second, different skp file, no layers in that one, then I decided to open the previous skp file, directly from the open skp file. Since the previous file was open on the desktop, Sketchup warned me "file is open, open read only blah blah", as soon is a picked no, to cancel the load of the previous file, boom, all of the layers in 'layers panel' loaded up in the currently open file, where they, just seconds ago, were unavailable.
                                    Not sure if that helps figure out what could be going on.
                                      jiminy-billy-bob
                                      • Are you running on windows or MAC?
                                      • If windows, what's your Internet Explorer version?
                                      • What's your Sketchup version?
                                      • When the dialog is blank, are you able to use its buttons? For exemple, does the "Add layer" button adds a new layer in Sketchup's layers window?
                                      • Could you try with all other plugins disabled? (Rename the plugins folder to "Plugins2", and create a new "Plugins" folder with only Layers Panel files in it)
                                      (Please answer all questions, thanks)
                                        glro
                                        i have too
                                        sketchup just freezed when i clicked on "select highlighted layer"
                                        the plugin would be very useful, but it doesn't seem stable
                                          jiminy-billy-bob
                                          Any more detail which could help me identify the issue?
                                            glro
                                            nothing much to say
                                            i had created some scenes previously, and then i launched layers panel plugin to select one layer, and it freezed the computer
                                            i shall give it another try, and try to atch better the next time i have a bug
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 30 / 34
