    Skalp - Dynamic Sections Plugin released
    46 Posts 12 Posters 9.8k Views 12 Watching
      rfox
      I was having an installation problem since the day i purchased, I use "regular" Windows 7 Ultimate. email the issue to them, got couple of feedbacks but it didn't seem help. I try to contact them several times....no respond.such a bad developer. at least they give me some good technical explanation regarding the issue.
      It's time to render....
      • SkalpS
        Skalp
        Can you give me your support case number. So I can look to it. I know we have some open cases regarding unicode problems (special characters in path names) and we are still looking what causes the problem windows?, ruby?, sketchup? or Skalp?
        regards,
        The Skalp Team.
        Skalp
        http://www.skalp4sketchup.com
          rfox
          here it is : 451_ej9kg1g4mmq9s9c6
          • KrisidiousK
            Krisidious
            Does Skalp need SketchUp 2014 to work or does it need Layout 2014? Could one use Skalp in SketchUp 2013 and then use Layout 2014 to make use of Skalp sections?
            By: Kristoff Rand
            • jiminy-billy-bobJ
              jiminy-billy-bob
              I guess it needs SU2014 for the new API methods regarding sections.
              New! - SectionPlane additions
              Please see the new API docs for how to implement these classes and methods.
              Added support for creating and activating SectionPlane entities.
              New methods are:
              Entities.add_section_plane
              Entities.active_section_plane
              Entities.active_section_plane=
              SectionPlane.activate
              SectionPlane.active?
              Added EntitiesObserver.onActiveSectionPlaneChanged
              RenderingOptions now exposes a new key 'DisplaySectionPlanes' that can be used to show or hide section planes. e.g Sketchup.active_model.rendering_options['DisplaySectionPlanes'] = false
              • SkalpS
                Skalp
                New methods are:
                This new features are feature which are implemented in SketchUp because we asked for them. But the most important reason why we only work on 2014 is ruby 2.0 and the use of the ruby standard library.
                The Skalp Team.
                Skalp
                • SkalpS
                  Skalp
                  No we need SketchUp 2014 and if you like you can use Layout 2013.
                  The Skalp Team.
                  Skalp
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    Oh man, I know what you mean πŸ˜‰
                    • KrisidiousK
                      Krisidious
                      It's SU2014 I'm reluctant to upgrade to... Layout2014 has some features I'd like to have.
                      Another question... I like to use a untextured/uncolored (hidden line) style for my Layout Viewports when doing construction docs. will these section materials still show up on hidden line styles?
                      By: Kristoff Rand
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Why is that?
                        • SkalpS
                          Skalp
                          Krisidious,
                          A Skalp sections are normal SketchUp faces, with normal SketchUp textures. When using the hidden line style everything show up white even the section.
                          But Skalp can do a lot more...
                          For making construction documents we can set the model white except the section. In the above picture are just a few options. All different options can be used together in the same model and on the same section, just different scenes so you can use them on one layout (see picture)
                          The Skalp Team.
                          Skalp
                          • KrisidiousK
                            Krisidious
                            Why is that?
                            • The cost...
                            • I don't really see anything in SU2014 that makes me jump up and down and say Oh I need this. (except maybe Skalp now...)
                            • The process of switching is rather arduous. have to reinstall everything and re-license all my paid plugins, redo all my templates, settings, toolbar locations, move all my materials, components, styles, scrapbooks, build new toolbars for Layout... blah blah blah.
                            • I use a lot of older plugins that might not or probably won't work in 2014, like the SCF Toolbars.
                            • I'm behind now and working every day with this installation and don't really have the down time to switch and get everything working.
                            I know I need to... I'm lazy is the biggest reason.
                            By: Kristoff Rand
                            • KrisidiousK
                              Krisidious
                              Krisidious,
                              The Skalp Team.
                              Thanks... That is exactly what I wanted to hear.
                              Currently... My process is.
                              1. Section with Tig's section cut face.
                              2. then I copy and paste the section into layout.
                              3. scale it.
                              4. place it over my scene view.
                              5. then explode it.
                              6. color it if I just want plain colors like black shaded walls.
                              7. If I want materials I leave it as a scene and put it on a single layer and put the scene over the model scene.
                              HUGE PAIN!
                              Skalp would make it much easier.
                              By: Kristoff Rand
                              • SkalpS
                                Skalp
                                The problem was a know SketchUp problem regarding a dll conflict between Sketchup ruby standard library and zlib1.dll on your windows system. It toke us some time to figure this out because problems with SketchUp and/or the operating system aren't always easy to find and to solve because they have nothing to do with our code. In this case the problem was also not reproducible on our own windows system.
                                When we found the problem and the solution I've send you a mail about the solution like it was logged in the Sketchup beta forum. The solution had nothing to do with our code. Apparently you were not able to solve the problem yourself.
                                After your complain on sketchUcation we contacted you again to do a join.me session and solved your problem even it wasn't a Skalp problem at all. But we like to keep our customers happy. I hope you can now enjoy Skalp like it's meant to be.
                                The Skalp Team.
                                Skalp
                                • 3 / 3
