    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 329.3k Views 41 Watching
    • jolranJ
      jolran
      I have probably missed it, but is there a possibility to make insulation hatches with this plugin?
      Not yet.
      But in my developpment version yes. Any pattern you'd like. Hopefully soon for you guys.
      Working on another plugin that has higher priority, but that might now change so standby on this.
      Performance will be much slower than LO on complicated patterns or small scaling=many patterns. That is one of the reasons this plugin has been a little on hold, in case I could figure out a way to solve that.
      • T
        teisele27
        I haven't read all the posts, so maybe this was already answered. I am running SU8 on a Mac. I put the plugin in my plugins folder a required, but can't get it to run. Suggestions? Thx
          Tom, did you just move the ZIP file to the Plugins folder or did you extract the contents of the ZIP file first and put them in the Plugins folder. Did you install the plugin using the Sketchucation Plugin Store? (That's the best method, anyway.) Do you have permissions set to Read AND Write for the Plugins folder? Did you restart SketchUp after installing the plugin?
          • jolranJ
            jolran
            Hi.
            As Dave pointed out you will have to unzip the files to Plugin directory.
            Let me know how it goes.
            Reply Quote -1
              ArCAD-UK
              Had a quick play. Wish I'd taken notice of this sooner!
              Development suggestion.. Crosshatching allows the creation of some interesting parallel line patterns by applying the same angle with different spacing values, but there is no way to do a simple parallel offset using the same spacing. Could you add an offset parameter in the crosshatch window to allow the creation of one of the more common basic hatch patterns like this // // // ?
              • jolranJ
                jolran
                Hi!
                If you scroll back a few pages you can see that it is the roadmap of using costum patterns. Where one could use any type of pattern one wish.
                However I like your idea, and it could be expanded into a feature with inbuilt patterns.
                We could call them "vector-patterns".
                Now they would not have so many adjustable parameters, cause the dialog would get swamped. But they would be created by code and not tiled groups, so they (may) be faster to intersect.
                Unfortunally I'm working a lot on another plugin, so this plugin is not prioritized.
                Especially since Lo had the Hatchpattern function added, I was under impression people where content with that..
                But if there is more interest I might be able to squeeze in an update when time permitts. I have by no means given up on this plugin..
                  ArCAD-UK
                  Not really. Raster hatching comes with scaling / dpi issues.
                  The offset was just a suggestion as I thought it might be easy to add unlike shape patterns which I can see will be a BIG challenge.
                  • jolranJ
                    jolran
                    Right, that was my opinion too. Not Always good printing result.
                    There may be a possibility to pull off a few simpler pattern combinations in code.
                    Which would be faster to intersect.
                    OK, I pull up this one a notch in priority then. No promises made. Gotta try and finish some projects and not just start new ones πŸ˜„
                    • E
                      elvirem
                      Great thanks Jolran : that's my dream !! Unfortunately it doesn t work for Mac with skp8.. if anybody knows how to develop this plugin for mac, that would be really great πŸ˜„
                        It does indeed work on Mac. πŸ˜’
                        If it didn't for you, the most likely causes are incorrect installation or lack of permissions to the Plugins folder. You'll have to give some useful information about if you want help sorting it out. Further development of the plugin isn't the answer, though.
                        • jolranJ
                          jolran
                          Hi Elvirem.
                          Can you be more specific, "than it does not work", please.
                          I woulden't even know where to start debugging..
                          Since Dave R (Thank you) can provide a screenshot of a working solution the issue is not general.
                          If anybody knows how to develop this plugin for mac, that would be really great
                          I havent updated the plugin for quite a while, since working on other plugin. But I intend to update at later point, even have code for doing so. So I would prefer letting me be in charge of updating my plugin.
                          As Dave said, please come back with some more information, and I try to help you πŸ˜„
                          / Joel
                          • SkalpS
                            Skalp
                            @lapx said:
                            Me too! It would be nice if it could read and tranaslate autocad hatch file. We need some cross polination of the minds on this one. πŸ˜„
                            I wonder if it works on curved surfaces...I must experiment.
                            Lapx,
                            Take a look to Skalp for Sketchup, we have a live section tool and handle Autocad hatch patterns. We create tileable textures based on Autocad pattern files and have the ability to export them back to dxf .
                            The Skalp Team
                            Skalp
                            http://www.skalp4sketchup.com
                            • jolranJ
                              jolran
                              That looks really nice, I must say.
                              What I think people want is the edgepatterns in Sketchup, so they can get better print in Layout. (That does come at a cost so I do understand why you use textures)
                              I don't think one can insert a DXF in LAyout ?
                              So the workflow is to export DXF. Import DXF to SKetchup and Align to sectioncut, or am I missing a step ?
                              Best regards/
                              Joel
                              • SkalpS
                                Skalp
                                Best regards/
                                Joel
                                Jolran,
                                We create also tileable textures from autocad pattern files for use in SketchUp and Layout. We optimize the textures for printing at 300dpi (this is the max dpi layout prints) so you want get better results with vectors. Only when we export to layout we change this texture by the original pattern definition.
                                The Skalp Team.
                                Skalp
                                • JQLJ
                                  JQL
                                  Best regards/
                                  Joel
                                  Jolran,
                                  The Skalp Team.
                                  This system of yours is really great! The only reason stopping me from using Skalp is that I would have to change the way I model in sketchup to be able to have your sections working. I never model the inner parts of the building and design every detail as 2D components inside SU sections.
                                  So (I'm sorry for stealing the thread but...) I have a feature suggestion for you:
                                  A way to make Skalp respect those components and don't erase them when generating a new section, whilst allow them to be exported like the rest of the section. If you had that feature working, then Skalp could really become a completely must have plugin...
                                  I would be really interested in this and if you want to discuss more I could send you some PM or whatever...
                                  Best regards,
                                  JQL
                                  www.casca.pt
                                  Visit us on facebook!
                                  • SkalpS
                                    Skalp
                                    Best regards/
                                    Joel
                                    Jolran,
                                    The Skalp Team.
                                    Best regards,
                                    JQL
                                    JQL,
                                    This is a good idea, and it fits our future planning. We plan to do more annotation and dimensioning inside our section inside SketchUp. I discuss this with my partner and come back to you in a PM.
                                    regards,
                                    The Skalp Team
                                    Skalp
                                      jherrmann2305
                                      Well, its 2020 and i just downloaded your plugin and use it with Sketchup 2020. It still works, like a charm after renaming the ZIP package into a RBZ file.
                                      Thanks so much for this plugin.
                                      I guess you ended developement on it, which is a shame ( πŸ˜‰ ), but anyways:
                                      If somebody reads this:
                                      It would be nice to have more hatch-pattern-options available. I have to draw construction schemes according to a norm (German DIN) - and this norm specifies certain hatch patterns for certain wood-types and/or orientations.
                                      Don't ask me why - but they want to see it in my exam. I chose sketchup instead of a classic CAD because of the shorter "brain-to-screen" path - but in this case here (standardised patterns), sketchup is a really nasty tool to work with, if you don't want to end up with bitmap-textures.
                                      Anyways: Thanks very much for your plugin.
                                      And yes: i am aware of Skalp. But i find Skalp too expensive for my wallet. Excuse me, i am poor.
                                      • jolranJ
                                        jolran
                                        Hi!
                                        (Sorry about the late reply.)
                                        I'm glad to hear people still find this plugin useful, thanks!
                                        I'm still developping this plugin (and other) from time to time but its all experimental code and no estimated time of delivery..
                                        Your best option is Skalp, in my opinion.
                                        Best regards/
                                        Joel
                                        • F
                                          Frank Ferrari
                                          Hi folks,
                                          I am on the same path as jherrmann2305 ! It is a shame that there is no native solution for hatches in SU..
                                          Also having different custom hatches is pretty difficult to implement with the mentioned workarounds.
                                          I used skalp and it honestly is pretty clonky.. its slow on my projects and simply doesn't do what I want.. and in the end it crashes. I tried the trail.. but I will not spend so much money for something that doesn't run smooth.
                                          I understand plugin owners charging for their work, but they should make it popular and run improvements so its smooth and ready. Than I am totally willing to pay for it..
                                          Hoping for a better hatch future
                                            dylanwoods
                                            just downloaded this and it is an excellent plugin. this will save me a lot of time so i am very grateful.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 18 / 18
