    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 298.2k Views 41 Watching
    • jolranJ Offline
      jolran
      Hi.
      Thank you very much for the input. Much appreciated..
      I already have it in my pluginfolder πŸ˜„
      I have had a peek at Krill's code for ideas, but it is a VERY big script and it can take quite a bit of work(for me anyway) to get a grasp of what is going on.
      Actually in my case I'm avoiding peeking in others script to much since I noticed it
      distracts me a little. Unless I'm searching for a specific problemfix.
      I feel I have learnt more from experimenting, with my own code.
      Besides Krills script is copyrighted so, cant borrow anything from there anyway, but I do like to investigate his OpenGL preview a little, for ideas.
      Regarding Hatchfaces.
      I have code thats almost finished for tiling groups or components with intersecting on a single face. But recent developping has been all working on the node-GUI-editor.
      But I sence this plugin will require quite a lot of work so I might take a break from it in the near future and update Hatchfaces as promised.
      Best regards.
        DOD3R
        glad to hear about your progress. I am looking forward to new hatchfaces.
        Also I am happy, that you know about krills work. But question is if he knows about yours. Maybe you can join forces or maybe he is working on some parametric modeling on his own.
        I would like to here what he has to tell about parametric grasshoper-like modeling in sketch up and i think You even more.
        kind regards
        D.
        • jolranJ Offline
          jolran
          Hi.
          I'm afraid I don't have any collaboration in plan for that plugin.
          Helps, ideas and suggestions are always welcomed though, and I thank you for your
          input so far in this matter.
          Best regards /
          Joel.
          • jemagnussenJ Offline
            jemagnussen
            I have probably missed it, but is there a possibility to make insulation hatches with this plugin?
            Brgds
            Jesper
            @jolran said:
            Hi.
            Best regards /
            Joel.
            HP ZBook 15, Windows 10 64 bit
            Intel Core i7-6820HQ @ 2.70GHz
            32 GB Ram
            NVIDIA Quadro M2000M
            • jolranJ Offline
              jolran
              Not yet.
              But in my developpment version yes. Any pattern you'd like. Hopefully soon for you guys.
              Working on another plugin that has higher priority, but that might now change so standby on this.
              Performance will be much slower than LO on complicated patterns or small scaling=many patterns. That is one of the reasons this plugin has been a little on hold, in case I could figure out a way to solve that.
                teisele27
                I haven't read all the posts, so maybe this was already answered. I am running SU8 on a Mac. I put the plugin in my plugins folder a required, but can't get it to run. Suggestions? Thx
                  Tom, did you just move the ZIP file to the Plugins folder or did you extract the contents of the ZIP file first and put them in the Plugins folder. Did you install the plugin using the Sketchucation Plugin Store? (That's the best method, anyway.) Do you have permissions set to Read AND Write for the Plugins folder? Did you restart SketchUp after installing the plugin?
                  • jolranJ Offline
                    jolran
                    Hi.
                    As Dave pointed out you will have to unzip the files to Plugin directory.
                    Let me know how it goes.
                    1 Reply Last reply Reply Quote -1
                      ArCAD-UK
                      Had a quick play. Wish I'd taken notice of this sooner!
                      Development suggestion.. Crosshatching allows the creation of some interesting parallel line patterns by applying the same angle with different spacing values, but there is no way to do a simple parallel offset using the same spacing. Could you add an offset parameter in the crosshatch window to allow the creation of one of the more common basic hatch patterns like this // // // ?
                      • jolranJ Offline
                        jolran
                        Hi!
                        If you scroll back a few pages you can see that it is the roadmap of using costum patterns. Where one could use any type of pattern one wish.
                        However I like your idea, and it could be expanded into a feature with inbuilt patterns.
                        We could call them "vector-patterns".
                        Now they would not have so many adjustable parameters, cause the dialog would get swamped. But they would be created by code and not tiled groups, so they (may) be faster to intersect.
                        Unfortunally I'm working a lot on another plugin, so this plugin is not prioritized.
                        Especially since Lo had the Hatchpattern function added, I was under impression people where content with that..
                        But if there is more interest I might be able to squeeze in an update when time permitts. I have by no means given up on this plugin..
                          ArCAD-UK
                          Not really. Raster hatching comes with scaling / dpi issues.
                          The offset was just a suggestion as I thought it might be easy to add unlike shape patterns which I can see will be a BIG challenge.
                          • jolranJ Offline
                            jolran
                            Right, that was my opinion too. Not Always good printing result.
                            There may be a possibility to pull off a few simpler pattern combinations in code.
                            Which would be faster to intersect.
                            OK, I pull up this one a notch in priority then. No promises made. Gotta try and finish some projects and not just start new ones πŸ˜„
                            • E Offline
                              elvirem
                              Great thanks Jolran : that's my dream !! Unfortunately it doesn t work for Mac with skp8.. if anybody knows how to develop this plugin for mac, that would be really great πŸ˜„
                                It does indeed work on Mac. πŸ˜’
                                If it didn't for you, the most likely causes are incorrect installation or lack of permissions to the Plugins folder. You'll have to give some useful information about if you want help sorting it out. Further development of the plugin isn't the answer, though.
                                • jolranJ Offline
                                  jolran
                                  Hi Elvirem.
                                  Can you be more specific, "than it does not work", please.
                                  I woulden't even know where to start debugging..
                                  Since Dave R (Thank you) can provide a screenshot of a working solution the issue is not general.
                                  If anybody knows how to develop this plugin for mac, that would be really great
                                  I havent updated the plugin for quite a while, since working on other plugin. But I intend to update at later point, even have code for doing so. So I would prefer letting me be in charge of updating my plugin.
                                  As Dave said, please come back with some more information, and I try to help you πŸ˜„
                                  / Joel
                                  • SkalpS Offline
                                    Skalp
                                    @lapx said:
                                    Me too! It would be nice if it could read and tranaslate autocad hatch file. We need some cross polination of the minds on this one. πŸ˜„
                                    I wonder if it works on curved surfaces...I must experiment.
                                    Lapx,
                                    Take a look to Skalp for Sketchup, we have a live section tool and handle Autocad hatch patterns. We create tileable textures based on Autocad pattern files and have the ability to export them back to dxf .
                                    The Skalp Team
                                    Skalp
                                    http://www.skalp4sketchup.com
                                    • jolranJ Offline
                                      jolran
                                      That looks really nice, I must say.
                                      What I think people want is the edgepatterns in Sketchup, so they can get better print in Layout. (That does come at a cost so I do understand why you use textures)
                                      I don't think one can insert a DXF in LAyout ?
                                      So the workflow is to export DXF. Import DXF to SKetchup and Align to sectioncut, or am I missing a step ?
                                      Best regards/
                                      Joel
                                      • SkalpS Offline
                                        Skalp
                                        Best regards/
                                        Joel
                                        Jolran,
                                        We create also tileable textures from autocad pattern files for use in SketchUp and Layout. We optimize the textures for printing at 300dpi (this is the max dpi layout prints) so you want get better results with vectors. Only when we export to layout we change this texture by the original pattern definition.
                                        The Skalp Team.
                                        Skalp
                                        • JQLJ Offline
                                          JQL
                                          Best regards/
                                          Joel
                                          Jolran,
                                          The Skalp Team.
                                          This system of yours is really great! The only reason stopping me from using Skalp is that I would have to change the way I model in sketchup to be able to have your sections working. I never model the inner parts of the building and design every detail as 2D components inside SU sections.
                                          So (I'm sorry for stealing the thread but...) I have a feature suggestion for you:
                                          A way to make Skalp respect those components and don't erase them when generating a new section, whilst allow them to be exported like the rest of the section. If you had that feature working, then Skalp could really become a completely must have plugin...
                                          I would be really interested in this and if you want to discuss more I could send you some PM or whatever...
                                          Best regards,
                                          JQL
                                          www.casca.pt
                                          Visit us on facebook!
                                          • SkalpS Offline
                                            Skalp
                                            Best regards/
                                            Joel
                                            Jolran,
                                            The Skalp Team.
                                            Best regards,
                                            JQL
                                            JQL,
                                            This is a good idea, and it fits our future planning. We plan to do more annotation and dimensioning inside our section inside SketchUp. I discuss this with my partner and come back to you in a PM.
                                            regards,
                                            The Skalp Team
                                            Skalp
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 18 / 18
