    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      What a strange way of grouping things. It makes no sense.
      Still, I'm not having any difficulty modifying it with FredoScale. Maybe you could show what you are trying to achieve?
        dacastror
        Dave tries to use "radial bend" (for example) on the largest group
          Like this?
          I see what you mean about the Bug Splat but after I gave it a logical grouping it works just fine. I expect it's caused by your strange method of grouping.
            dacastror
            right now I'm not designing something, I'm just writing a plugin and discovered this bug by chance
            I think that could be a problem related to the issue that are not "unique groups" and are nested
              joonnyy
              Hello
              I have installed SU 2014. I installed via the / install extensions / / Fredo6_! LibFredo6 - v5.7 - 15 Feb 14.rbz / a plugin / Fredo6_FredoScale - v2.6b - 05 Feb 14.rbz /
              When I run SU 2014 I got a critical alert / LibFredo6 will be updated at next startup of Sketchup / when I click OK appears critical window / load errors /
              Error loading file Fredo6_FredoScale.rb
              Error: # <NameError: UNINITIALIZED constant Fredo6::Traductor>
              C 😕 Users / Jan / AppData / Roaming / SketchUp / SketchUp 2014/SketchUp/Plugins/Fredo6_FredoScale.rb: 41: in <module:Fredo6> ' C :/ Users / Jan / AppData / Roaming / SketchUp / SketchUp 2014/SketchUp/Plugins/Fredo6_FredoScale.rb: 25: in <top (required)> '
              Where I make mistakes when installing? Thanks
              • bmikeB Offline
                bmike
                @dave r said:
                [attachment=3:lp5xixsu]<!-- ia3 -->Screenshot - 3_28_2014 , 8_50_20 PM.png<!-- ia3 -->[/attachment:lp5xixsu]
                [attachment=2:lp5xixsu]<!-- ia2 -->Screenshot - 3_28_2014 , 8_54_11 PM.png<!-- ia2 -->[/attachment:lp5xixsu]
                Like this?
                I used this plugin on an entire house - windows, doors, walls, compound roof, etc. etc.
                I crashed and crashed - until I started to pull apart the model into logical groups.
                After I figured that out - it worked perfectly.
                To solve a 'bending' a large model - draw an origin, and a line. Now take apart the model in logical groups (all the windows, all the doors, the walls, etc. etc.
                Copy / Paste in place into a new drawing the group of objects, and the origin and scale line.
                Group everything, FredoScale Bend.
                Copy / Paste in place into a new drawing.
                Repeat, but always paste the bent components in place together, in that new 'bent' drawing.
                It let me take this:
                [attachment=1:lp5xixsu]<!-- ia1 -->Screen Shot 2014-06-13 at 11.43.55 AM.png<!-- ia1 -->[/attachment:lp5xixsu]
                To this:
                [attachment=0:lp5xixsu]<!-- ia0 -->Screen Shot 2014-06-13 at 11.43.44 AM.png<!-- ia0 -->[/attachment:lp5xixsu]
                • N Offline
                  numerobis
                  Would it be possible to add a scale option for scaling around the base point of a group/component? And another one for scaling multiple groups/components based on their local origin? (as it works in max for instance)
                  • fredo6F Offline
                    What is the base point exactly? Currently FredoScale uses the center of the bounding box.
                    This would be a different plugin, but I think there exists already one doing this.
                      Scale rotate multiple by Chris Fullmer 😉
                      • N Offline
                        numerobis
                        I meant the origin of the component
                        Why wouldn't it be possible to have this as another option beside the normal scaling and the uniform scaling around the center (strg)?
                        Yes, this works for uniform scaling, but it doesn't support scaling in one direction or did i miss something? And it is not interactive, you have to put in numerical values.
                        • fredo6F Offline
                          NEW RELEASE: FredoScale v2.7a - 19 Oct 14
                          FredoScale 2.7a is required for the support of usernames with non-ascii characters in Sketchup 2014
                          FredoScale 2.7 requires LibFredo6 6.3 or higher.
                          • F Offline
                            fullyfledgeded
                            I've read through the guide and was just wandering: Is it possible, to move the origin(red) about which the object scales from
                            http://i1303.photobucket.com/albums/ag156/eskimo___/snap-and-drag_170_zps2603458a.jpg
                            so for instance in the above example, I want to move the origin to where the green cross hair is, so when scaled, it looks like this:
                            http://i1303.photobucket.com/albums/ag156/eskimo___/snap-and-drag_172_zps2a7ef40f.jpg
                              Yes if you use Menu Fredo Scale / Box Streching to Target ! 🤓
                              So as you can choice the origin...
                              • F Offline
                                fullyfledgeded
                                Thankyou pilou. sorry it took me so long to reply, i wasn't able to find the post after i'd submitted
                                  No problem! 😄
                                  • mariochaM Offline
                                    mariocha
                                    Working with dynamic components, I find that scaling by clicking 2 points also "redraws" the dyn. component; for instance, the fixed lenghts or widths of inner parts are applied immediately. Scaling by typing a ratio does not redraw, so one has to right-click the compo and select Dynamic Component and Redraw to get the parts to their desired dimensions.
                                    I often use the first function of FredoScale to scale to a precise dimension. My wish is that FredoScale would be enhanced with an automatic dyn. compo. redraw before exiting.
                                    %(#008000)[Mario C.
                                      BeePee
                                      ISSUES SKINNING A TWISTED PART
                                      Hi All, I love Fredo Scale and Curviloft. However, while the results look great on screen, I'm wanting to export the parts for 3D printing. I'm finding there are LOTS of healing issues with the parts I've altered using these plugins.
                                      I attach a JPEG and STL of the part I'm trying to skin and place in a box section. It's a short bar twisted 180 degrees. It's actually one of an intended series of these inside of a harmonica comb intended to re-direct air from an upper to a lower reedplate, hence the small size).
                                      You can see from the STL that the twisted bar has lots of holes on the outside edges, and skinning doesn't fix these. When I export to my 3D printer software the part looks a real mess and won't print.
                                      Can one of you experts check the file and let me know how to overcome this?
                                      Thanks! Brendan
                                        driven
                                        @beepee said:
                                        I attach a JPEG and STL of the part ...
                                        hi Brendan
                                        no files attached, but for most of these types of operations in SU you need to scale up 100 times, do the transforms, thens scale back down for export...
                                        SU can't make tiny triangles, but can use and export them if they are scaled down from existing larger ones...
                                        that's most likely your issue..
                                          BeePee
                                          John - sorry for the delayed reply, I couldn't see my post when I first looked but came back later and saw your advice.
                                          I followed it and hey presto, it worked! I scaled up massively, did the twisting and skinning, and after scaling down to the correct size, it stayed healed and looks fine in my 3D printer slicing software.
                                          Thanks so much 😄
                                          Cheers, Brendan
                                            jgt1942
                                            How about a video with english audio. I've watched the existing videos and have not found them helpful because I really don't know what is being done.
                                            How do I scale an object to a desired dimension. Example I have a 6" dia pipe and I want it to be 5" dia. I click the center handle and attempt to get the desired dia but cannot lock in on the desired 5".
                                            jgt
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 56
                                            • 57
                                            • 51 / 57
