    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 252.8k Views 66 Watching
    • V Offline
      VJsku
      I tried to use the latest update. But the plugin (1001bit_freeware_v1.0.3_v1.0.5) did not work. I had to go back the the previous version (1.0.2), which of course works fine.
      I get the following error on clicking on the 'Wall' on the Ruby console:
      Plugins/1001bit_freeware/wall1.rb
      looking for E:/Common Plugins/1001bit_freeware/wall1.rbs
      loading E:/Common Plugins/1001bit_freeware/wall1.rbs
      Error: #<NameError: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_wall1>
      (eval):256:in gh_mnu_wall1' (eval):798:in load'
      (eval):798:in `call'
      In the zip (rbz) file I could see two copies of 1001bit_freeware.rb. One needs to reside in the main plugin folder and one more in the <1001bit_freeware> folder inside the plugin folder. The error on the console remains the same irrespective of whether the 'extra' copy is kept in the <1001bit_freeware> folder or not.
      What am I doing wrong...
      PS: I use Sketchup version 7 and 8 (both free).
      Thanks..
        smuncky
        Has anyone been having problems with 1001 on SU2013? Plugin loads fine when SU is started but when you click on any of the icons or try to start a command from the drop down menu, nothing happens.
        However, everything works fine on SU2014.
        Any ideas?
          Just use 2014, there are less bugs inside! πŸ˜‰
            smuncky
            If I was in charge of our IT dept I would πŸ˜‰
            However, most of the office is still on 2013 with no word on when everyone will switch to 2014. So that's why i'd like to figure out the problem that 1001bit is having with SU2013.
              Do you get any messages in the Ruby console when click on a tool?
              Whatever are security settings for the Plugins folder?
                smuncky
                This is the text I'm getting in SU2013.
                looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/staircase2.rb
                looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/staircase2.rbs
                loading F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/staircase2.rbs
                Error: #<NameError: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_staircase2>
                (eval):285:in gh_mnu_staircase2' (eval):960:in load'
                This is the text I'm getting in SU2014.
                looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/wframe.rb
                looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/wframe.rbs
                loading F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/wframe.rbs
                inside read
                no language file. F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/language/wframe.txt
                default size
                Security permissions are given to all users as the plugins are on a network drive.
                  The v2014 error says, " ...no language file. F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/language/wframe.txt..."
                  This suggests that a file or subfolder/file is missing ?
                  The v2013 error suggests that Constant is not being set up.
                  If you copy/paste+<enter> these [in turn] into the Ruby Console what do you get ?
                  GCH_1001bit_loader GCH_1001bit_loader::GCH_1001bit_load GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools:: GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_staircase2
                    smuncky
                    For 2014, I did a bit more digging around and found that there is no "language" folder. I've downloaded the plugin from both the 1001bit site and the extension warehouse. Both .rbz files have the same contents except for one thing. The .rbz from the warehouse has this "extension_info.txt" file which has this inside: ID=e5b1211a-8d1a-4813-bdc3-b321e5477d7b
                    VERSION_ID=fbd307e2-d0f0-4880-9568-80d2032f0ffe
                    For 2013, I did what you asked and got this:
                    GCH_1001bit_loader
                    GCH_1001bit_loader
                    Error: #<SyntaxError: (eval):285: compile error
                    (eval):285: syntax error, unexpected $end
                    ...1bit_free::GCH_1001bit_tools::
                    (eval):285
                    Error: #<NameError: (eval):285: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_staircase2>
                    (eval):285
                      Try making a folder with an empty file - F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/language/wframe.txt
                      Does that still give the error messages... πŸ˜•
                      None comes with the RBZ, so presumably the scripts make it ?
                      Have you tried removing the whole toolset, including its subfolders, then reinstalling from the RBZ... perhaps you have a rogue extra file, or missing file ??
                        smuncky
                        Made a blank wfram.txt file. Just says that it's "finished reading language file". But then again, I never had a problem in loading the piugin in 2014. So i'm not too worried about this.
                        In 2013, I've deleted and installed the .RBZ twice. One from the 1001bit site and once from the SU warehouse. Didn't work on both occasions. But reading the comments it seems there a lot of people having the same problem as I am.
                          drmrsir
                          Any solution yet for smuncky issue? I am in the same boat where toolbar is loaded but no functionality.
                          Any help would be welcomed!
                          • shukritobiS Offline
                            shukritobi
                            I've been using this plugin for a while and encountered a bug where it says somewhat like this " Group located too deep,... use align tool" window, and when I've try closing the window, it pop back up again... repeatedly. I have to force close the sketchup window, and reopen it. Anyone encountered a similar error?
                            • KrisidiousK Offline
                              Krisidious
                              I haven't used all the tools in 2015 but it's working... I think his is autokey by email isn't it? You might email him from here. It's Goh isn't it?
                              By: Kristoff Rand
                              • pbacotP Offline
                                Anyone know the status of 1001bit Tools support? I need to reload in v. 2015 and can't find my Pro key. I am getting no response from the website. Does the plugin even work in v. 2015?
                                  cboy1980
                                  Having same issues on the 1001 bit freeware.
                                  Nothing seems to happen
                                  here is wat the Ruby console has to say
                                  "looking for C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/1001bit_freeware/managetoolbar.rb
                                  looking for C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/1001bit_freeware/managetoolbar.rbs
                                  loading C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/1001bit_freeware/managetoolbar.rbs
                                  Error: #<NameError: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_managetoolbar>
                                  (eval):140:in gh_mnu_managetoolbar' (eval):407:in load'
                                  (eval):280:in call' (eval):280 looking for C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/1001bit_freeware/staircase4.rb looking for C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/1001bit_freeware/staircase4.rbs loading C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/1001bit_freeware/staircase4.rbs Error: #<NameError: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_staircase4> (eval):295:in gh_mnu_staircase4'
                                  (eval):1008:in load' (eval):140:in call'
                                  (eval):140"
                                  alltough I installed it trough the correct way. never had troubles before with plugins... no idea what's happening.
                                  help is appreciated
                                  thx
                                  cboy
                                  • josephkim626J Offline
                                    josephkim626
                                    would it be possible to have the rectangular grille tool generate the geometry inside the group that's being edited?
                                    it always jumps to outside of the group and having me to cut and paste back in.
                                    • Mistro11M Offline
                                      Mistro11
                                      I'm trying to download 2.2 from official download page and I keep getting a page full of strange characters. Any ideas?
                                      Nevermind. I used Chrome browser and it worked. Firefox have a problem with this.
                                      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                      Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                        saldstudio
                                        hi, this is a great plugin! sometimes some tools dont work in the way I want to, but I can handle it mostly.
                                        But i got major problem with tool convert selected edges to profiles. it simply doesnt work. when i click icon, nothing happens. no window, no error. and its the same on two computers Im using (win7 pro 64x). any ideas?
                                          tomaszdrgas
                                          Believe or not some people in our korean office are forced to work on sk8 still..
                                          1001bit_freeware_v1.0.5 Nothing happens when you click on toolbars..
                                            rv1974
                                            North korean?
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
