    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 265.5k Views 66 Watching
      gohch
      ok, this is really odd, i ran SU2014 in Win7 and the crash occurred,
      and then i ran SU2014 on Win7 again with compatibility mode set to XP(service pack 3) and no more crashes.
      Ran SU2014 on Win7 with compatibility set to Vista SP2 no crashes.
      So, in Win8 i have to run as compatibility for Win7
      and in Win7 i have to run as compatibility for XP or Vista
      odd...
      • AndrewSA Offline
        AndrewS
        I don't know anything at all about the specific plugin you're running, but I can at least tell you this: When running on any operating system newer than Vista (7, 8, 8.1), using any version of SketchUp (8, 2013, 2014), SketchUp automatically executes in Windows Vista compatibility mode. You can force it down to an older XP compatibility mode, but even if you choose something newer, the highest it will actually go is Vista.
        The reason is that we have not formally taken measures to embed any OS compatibility flags within the SketchUp Windows executable. As a result, the OS assumes an incompatibility on Win 7, 8 or 8.1, and therefore automatically runs it in Windows Vista compatibility mode. In theory, it should not make any difference that you are running a newer OS, or attempt to force it into a newer compatibility mode elsewhere.
        Again, I know nothing about the use or design of your specific plugin, but I would suggest that compatibility modes are likely not the source of your problems. Any perceived connection may be largely circumstantial.
        Good luck,
        Andrew
        Andrew S.
        SketchUp Release Engineer
          gohch
          Thanks Andrew,
          For some reason, setting it to run under compatibility mode seems to prevent the crash. Another user just reported that the tool no longer crash when he ran SU in compatibility mode too.
          Thanks and cheers!
            gohch
            Managed to catch the BUG!!!
            The bugs in the tools that caused the crashes:
            "extend to edge or face"
            "information between 2 points"
            have been fixed in the latest rbz file:
            http://www.1001bit.com/pro/download/1001bit_pro(v2.2).rbz
            I have tested the other tools to work fine in SU2014,
            if anyone has any issue, please let me know and i will look into it.
            Thanks and cheers!
            Goh
            • ElibjrE Offline
              Elibjr
              Thanks and cheers!
              Goh
              Just to let you know Goh that the link here is corrupted and cannot be downloaded. If this is a fix please re-post it again. Thank you. I love this plugin.
              EliBjr
                gohch
                hi EliBjr,
                Can you please try the link again, i managed to download the rbz file through the link.
                Goh
                • V Offline
                  VJsku
                  Dear Goh,
                  Thank you for an excellent plugin.
                  I ran into a curious problem. My first attempt at using your plugin. Used it on Ver. 7 & 8 (both free).
                  I made walls using the plugin. Then while making openings I made the internal doors in walls of varying thickness. No problems so far. Then I started on the windows on the 'external' walls. Here if the window was punched from 'outside', they would be made but only 3" deep without the back face. If the window was made on the same external wall from 'inside' it would punch through the full depth of the wall.
                  Is this how it is supposed to work?
                  VJsku
                  Sent from my HTC One X using Tapatalk
                  PS: Adding a screenshot of the behaviour...
                  The left window is punched from 'outside', while the window on the right was punched from the 'inside' of the same wall. The wall is 15" thick in this example, but when an opening is created from 'outside' the opening goes 'in' by only 3".
                  Unfortunately I am not able to recreate this on a fresh 3d. So it seems something unique has happened to this particular model...
                    gohch
                    hi VJsku,
                    Thanks for the feedback. This seems to be a bug... in how the tool identify the opposite face of the wall.
                    I will look into this an come up with a patch.
                    Thanks for bringing this up!
                    Goh
                      mohamed alaa155
                      thnxxx
                        Justo79
                        Your site is down, temporarily I hope?
                        edit - all good
                        Cheers
                        Justin
                        • Mistro11M Offline
                          Mistro11
                          I want to bring my 1001bits Pro from Sketchup v8 free over to my Sketchup2014 Pro installation. I get a crash every time. I think I'm just doing something wrong. I uninstalled from v8 and copied the plugin files along with my Prokey file I downloaded to my 2014 plugins directory in windows XP. I cannot get it to work. I get a "syntax error" and within the message is "Invalid Break". Is there anything I should be aware of concerning 1001 and SU2014? I tried looking for it through the plugin store but do not see the pro version. Any help is appreciated.
                          EDIT: Nevermind, I figured it out. I went to the official site and downloaded from the link to the rbz file. It came in as a regular zip file so I just renamed the extension to rbz and was able to install and put my key in. It works now.
                          I left the original post in case anyone else ran into this issue.
                          i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                          Structural Integrity is Not Just Physical...It's in the Design and Purpose
                          • V Offline
                            VJsku
                            I tried to use the latest update. But the plugin (1001bit_freeware_v1.0.3_v1.0.5) did not work. I had to go back the the previous version (1.0.2), which of course works fine.
                            I get the following error on clicking on the 'Wall' on the Ruby console:
                            Plugins/1001bit_freeware/wall1.rb
                            looking for E:/Common Plugins/1001bit_freeware/wall1.rbs
                            loading E:/Common Plugins/1001bit_freeware/wall1.rbs
                            Error: #<NameError: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_wall1>
                            (eval):256:in gh_mnu_wall1' (eval):798:in load'
                            (eval):798:in `call'
                            In the zip (rbz) file I could see two copies of 1001bit_freeware.rb. One needs to reside in the main plugin folder and one more in the <1001bit_freeware> folder inside the plugin folder. The error on the console remains the same irrespective of whether the 'extra' copy is kept in the <1001bit_freeware> folder or not.
                            What am I doing wrong...
                            PS: I use Sketchup version 7 and 8 (both free).
                            Thanks..
                              smuncky
                              Has anyone been having problems with 1001 on SU2013? Plugin loads fine when SU is started but when you click on any of the icons or try to start a command from the drop down menu, nothing happens.
                              However, everything works fine on SU2014.
                              Any ideas?
                                Just use 2014, there are less bugs inside! πŸ˜‰
                                  smuncky
                                  If I was in charge of our IT dept I would πŸ˜‰
                                  However, most of the office is still on 2013 with no word on when everyone will switch to 2014. So that's why i'd like to figure out the problem that 1001bit is having with SU2013.
                                    Do you get any messages in the Ruby console when click on a tool?
                                    Whatever are security settings for the Plugins folder?
                                      smuncky
                                      This is the text I'm getting in SU2013.
                                      looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/staircase2.rb
                                      looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/staircase2.rbs
                                      loading F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/staircase2.rbs
                                      Error: #<NameError: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_staircase2>
                                      (eval):285:in gh_mnu_staircase2' (eval):960:in load'
                                      This is the text I'm getting in SU2014.
                                      looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/wframe.rb
                                      looking for F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/wframe.rbs
                                      loading F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/wframe.rbs
                                      inside read
                                      no language file. F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/language/wframe.txt
                                      default size
                                      Security permissions are given to all users as the plugins are on a network drive.
                                        The v2014 error says, " ...no language file. F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/language/wframe.txt..."
                                        This suggests that a file or subfolder/file is missing ?
                                        The v2013 error suggests that Constant is not being set up.
                                        If you copy/paste+<enter> these [in turn] into the Ruby Console what do you get ?
                                        GCH_1001bit_loader GCH_1001bit_loader::GCH_1001bit_load GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools:: GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_staircase2
                                          smuncky
                                          For 2014, I did a bit more digging around and found that there is no "language" folder. I've downloaded the plugin from both the 1001bit site and the extension warehouse. Both .rbz files have the same contents except for one thing. The .rbz from the warehouse has this "extension_info.txt" file which has this inside: ID=e5b1211a-8d1a-4813-bdc3-b321e5477d7b
                                          VERSION_ID=fbd307e2-d0f0-4880-9568-80d2032f0ffe
                                          For 2013, I did what you asked and got this:
                                          GCH_1001bit_loader
                                          GCH_1001bit_loader
                                          Error: #<SyntaxError: (eval):285: compile error
                                          (eval):285: syntax error, unexpected $end
                                          ...1bit_free::GCH_1001bit_tools::
                                          (eval):285
                                          Error: #<NameError: (eval):285: uninitialized constant GCH_1001bit_loader::GCH_1001bit_load::GCH_1001bit_free::GCH_1001bit_tools::GCH_1001bit_staircase2>
                                          (eval):285
                                            Try making a folder with an empty file - F:/03-Tools/Software/SketchUp/PLUGIN LIBRARY/Plugins/1001bit_freeware/language/wframe.txt
                                            Does that still give the error messages... πŸ˜•
                                            None comes with the RBZ, so presumably the scripts make it ?
                                            Have you tried removing the whole toolset, including its subfolders, then reinstalling from the RBZ... perhaps you have a rogue extra file, or missing file ??
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
