    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 182.6k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @smuncky said:
      This is the error that comes up when I open up the ruby console:
      Error: #<NoMethodError: undefined method `get_attribute' for nil:NilClass>
      Is this the whole error?
      • Y Offline
        yiannis76
        Update it for Keyshot 5 please.
        Thank you very much.
          smuncky
          Sorry, must've deleted it while editing.
          This is followed right after:
          c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3159:in get_cascading_attribute' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3279:in get_attribute_formula'
          c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3260:in get_attribute_value' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1052:in has_behaviors'
          c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1080:in block in has_behaviors' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in each'
          c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in has_behaviors' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1080:in block in has_behaviors'
          c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in each' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in has_behaviors'
          c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs:819:in `onComponentAdded'
            jiminy-billy-bob
            This error is related to Dynamic components, not Layers Panel.
              smuncky
              Do you have any idea as to why this error only happens when Layers Panel is on?
                jiminy-billy-bob
                Hmmm, I'll look into it.
                  jiminy-billy-bob
                  For those who want Layers Panel to support Thea Render (or the other way around), please say so in this thread : http://sketchucation.com/forums/viewtopic.php?f=384%26amp;t=58168
                  • Bob JamesB Offline
                    Bob James
                    Still get the occasional "Undo Layers Panel ID" when trying to undo an action.
                    • danchoD Offline
                      dancho
                      Can you put inside plugin to arange layers in alphabetica order?
                        smuncky
                        Any luck on replicating the problem or finding the cause in the code?
                          jiminy-billy-bob
                          I couldn't replecate the issue. Could you send me your model?
                            smuncky
                            PM sent.
                              jiminy-billy-bob
                              New version 1.2.0 !
                              Changelog :
                              • Added an History dialog, to easily revert back if groups/order disappear
                              • Added a right-click menu
                              • Fixed an issue causing an infinite undo loop
                              • Fixed encoding issue with non-english characters and alphabets
                              • The dialog now remembers its position in OSX
                              • Fixed minimizing
                              • Added support for KeyShot5
                              http://i.imgur.com/bzlLnCc.png
                              Download in the plugin store !
                                jiminy-billy-bob
                                If you already updated to 1.2.0, please redownload it. I fixed a minor glitch.
                                • cmeedC Offline
                                  cmeed
                                  Amazing job. Thank you.
                                  • BoxB Offline
                                    I just noticed your toolbar is persistent, meaning even if you choose to close it it will reopen on next startup. Is it possible to remove this behavior.
                                    I've notice quite a few tools do this and it makes for a minor nuisance when you want to use a minimal number of toolbars.
                                      jiminy-billy-bob
                                      Box > On windows 7 64bits, with SU2014?
                                      It works fine for me.
                                      • BoxB Offline
                                        Hmmm, interesting, I'm on the same setup. I just updated the plugin and it still does it. I'll have to have a look around and see if it's something up my end although both Sdmitch and Eneroth3 were able to give me the line edit to stop it opening.
                                          jiminy-billy-bob
                                          Could you send me what they told you to modify for their plugin?
                                          • BoxB Offline
                                            Here you go.
                                            Deck builder
                                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58084%26amp;p=533860#p533827
                                            Railway
                                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57831%26amp;start=240#p533089
                                            • 33
                                            • 34
                                            • 5 / 34
