    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Just like Thea, I can't trigger the Twilight render from ruby, so I can't add support for it.
      It would have to be Twilight that reads Layers Panel data.
      • EdsonE Offline
        Edson
        jbb,
        One more question. can Layers Panel deal with special characters from other languages? in my case, Portuguese is my native tongue and LP is not allowing me to write well in it.
        As an example, when I write Proteção it comes out like this: Prote√ß√£o.
        Any thoughts on that?
        Cheers.
        http://www.mahfuz.arq.br
          matt.gordon320
          Hi JBB,
          I have a couple more things to report back. LP is working well in the office environment so far. There are a couple things that cause no issue, but aren't working 100% for some reason.
          On my station, everything works perfectly. I have full admin access to the folder which the plugin network runs from. The users to whom I've rolled the plugin out, who have read only access, cannot alter colors for the LP layers, nor do the color previews show. The little grip by which the color is chosen and the layer is moved shows as grey only.
          Let me know what else I can provide or be of any help!
          Thanks,
          Matt
            jiminy-billy-bob
            @matt.gordon320 said:
            On my station, everything works perfectly. I have full admin access to the folder which the plugin network runs from. The users to whom I've rolled the plugin out, who have read only access, cannot alter colors for the LP layers, nor do the color previews show. The little grip by which the color is chosen and the layer is moved shows as grey only.t
            I bet you have SU2014 and the other user runs SU2013? 😄
            SU2014 introduced a new API method which allows me to add colors to LP. But it was non-existant in earlier versions.
              matt.gordon320
              Bingo! Thanks for letting me know, it's always good to know stuff like that.
                smuncky
                First of all, great plugin. This should be a basic part of SKP right out of the box.
                However, I'm getting a specific problem with it.
                Here is the series of events:
                -Open file
                -Delete a few things in the model on different layers
                -Purge the model (which deletes the layers that are empty)
                -Try to undo
                -Main modelling window freezes (can't pan/zoom/rotate) but I can still click on buttons and file menu
                -Model then bug splats
                I'm using the plugin from a network folder but also tried it in my local plugins folder and the same problem occurs.
                I've also downloaded and replaced the 2 files which you included on the previous page but problem still occurs.
                However, when I try the same steps in SU8, it undoes everything just fine without any bug splats. So, not sure if it's a SU2014 problem only.
                This is the error that comes up when I open up the ruby console:
                Error: #<NoMethodError: undefined method `get_attribute' for nil:NilClass>
                Any ideas on what might be causing this?
                  jiminy-billy-bob
                  Is this the whole error?
                  • Y Offline
                    yiannis76
                    Update it for Keyshot 5 please.
                    Thank you very much.
                      smuncky
                      Sorry, must've deleted it while editing.
                      This is followed right after:
                      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3159:in get_cascading_attribute' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3279:in get_attribute_formula'
                      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3260:in get_attribute_value' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1052:in has_behaviors'
                      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1080:in block in has_behaviors' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in each'
                      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in has_behaviors' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1080:in block in has_behaviors'
                      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in each' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in has_behaviors'
                      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs:819:in `onComponentAdded'
                        jiminy-billy-bob
                        This error is related to Dynamic components, not Layers Panel.
                          smuncky
                          Do you have any idea as to why this error only happens when Layers Panel is on?
                            jiminy-billy-bob
                            Hmmm, I'll look into it.
                              jiminy-billy-bob
                              For those who want Layers Panel to support Thea Render (or the other way around), please say so in this thread : http://sketchucation.com/forums/viewtopic.php?f=384%26amp;t=58168
                              • Bob JamesB Offline
                                Bob James
                                Still get the occasional "Undo Layers Panel ID" when trying to undo an action.
                                • danchoD Offline
                                  dancho
                                  Can you put inside plugin to arange layers in alphabetica order?
                                    smuncky
                                    Any luck on replicating the problem or finding the cause in the code?
                                      jiminy-billy-bob
                                      I couldn't replecate the issue. Could you send me your model?
                                        smuncky
                                        PM sent.
                                          jiminy-billy-bob
                                          New version 1.2.0 !
                                          Changelog :
                                          • Added an History dialog, to easily revert back if groups/order disappear
                                          • Added a right-click menu
                                          • Fixed an issue causing an infinite undo loop
                                          • Fixed encoding issue with non-english characters and alphabets
                                          • The dialog now remembers its position in OSX
                                          • Fixed minimizing
                                          • Added support for KeyShot5
                                          http://i.imgur.com/bzlLnCc.png
                                          Download in the plugin store !
                                            jiminy-billy-bob
                                            If you already updated to 1.2.0, please redownload it. I fixed a minor glitch.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 29 / 34
