    [Plugin] SU2KT 3.18 - Kerkythea exporter
    35 Posts 13 Posters 35.8k Views 13 Watching
    • T
      taufikohidayat
      Hi! I've been having problems installing the plugins, I copied the file into the exact folder, but it seems not working for me, I still couldn't find the plugins option in my sketch up, thanks
      • massimoM
        massimo Moderator
        There is SU2KT 3.17 now.
        About your issue have a look here.
        • T
          taufikohidayat
          I also have tried that, and it doesn't work -__-
            Although you say, "copied the file into the exact folder," if it doesn't work, it is likely you didn't install it correctly. To make it easier to install the plugin correctly after you've downloaded the ZIP file, change the extension to .rbz. Then use Install Extension from Preferences>Extensions to install it correctly. Before doing that, however, go to the Plugins folder and remove any thing related to Kerkyhtea there.
            • T
              taufikohidayat
              this is what happened after i tried installing it from the extensions
              http://imagizer.imageshack.us/v2/150x100q90/841/eu9y.png
              i'm sure there is some parts of installing that I did wrong, but I can't figure out which steps that i did wrong
                That's a worthless screen shot. It's way too small. πŸ˜’ Make a larger screen shot.
                • T
                  taufikohidayat
                  sorry, I didn't realise the size of the screen shot when I uploaded it
                  http://res.cloudinary.com/dsafcphpe/image/upload/v1405265665/Screen_Shot_2014-07-13_at_13_32_45_oeagck.png
                  hope this time will be much better
                    Did you make sure you have Read & Write permissions set for the Plugins folder?
                    • T
                      taufikohidayat
                      yes, I have
                        You must be missing something. I just installed it on my Mac using the ZIP file converted to .rbz as I described, above. It worked just fine. There's nothing wrong with the plugin itself.
                        • T
                          taufikohidayat
                          [attachment=0:2incryk5]<!-- ia0 -->2014-07-13_11-34-43.png<!-- ia0 -->[/attachment:2incryk5]
                          yeah i know, but I can't figure out what i am missing -__-
                            This is with SU8? Are there any strange characters in your user name on the computer?
                            • T
                              taufikohidayat
                              yes, it is su8, I guess not... I haven't seen any strange character on my user name
                                Could you make and post a screen shot of the Info window (Get info) for your Plugins folder?
                                • T
                                  taufikohidayat
                                  http://res.cloudinary.com/dsafcphpe/image/upload/v1405276467/Screen_Shot_2014-07-13_at_19_33_51_suox6i.png
                                    Hmmmm....
                                    • T
                                      taufikohidayat
                                      @dave r said:
                                      Hmmmm....
                                      I found its annoying -__- I have no idea what did i do wrong when installing the plugin
                                      • 2 / 2
