    [Plugin] SU2KT 3.18 - Kerkythea exporter
    35 Posts 13 Posters 35.5k Views 13 Watching
      Although you say, "copied the file into the exact folder," if it doesn't work, it is likely you didn't install it correctly. To make it easier to install the plugin correctly after you've downloaded the ZIP file, change the extension to .rbz. Then use Install Extension from Preferences>Extensions to install it correctly. Before doing that, however, go to the Plugins folder and remove any thing related to Kerkyhtea there.
        taufikohidayat
        this is what happened after i tried installing it from the extensions
        http://imagizer.imageshack.us/v2/150x100q90/841/eu9y.png
        i'm sure there is some parts of installing that I did wrong, but I can't figure out which steps that i did wrong
          That's a worthless screen shot. It's way too small. πŸ˜’ Make a larger screen shot.
            taufikohidayat
            sorry, I didn't realise the size of the screen shot when I uploaded it
            http://res.cloudinary.com/dsafcphpe/image/upload/v1405265665/Screen_Shot_2014-07-13_at_13_32_45_oeagck.png
            hope this time will be much better
              Did you make sure you have Read & Write permissions set for the Plugins folder?
                taufikohidayat
                yes, I have
                  You must be missing something. I just installed it on my Mac using the ZIP file converted to .rbz as I described, above. It worked just fine. There's nothing wrong with the plugin itself.
                    taufikohidayat
                    [attachment=0:2incryk5]<!-- ia0 -->2014-07-13_11-34-43.png<!-- ia0 -->[/attachment:2incryk5]
                    yeah i know, but I can't figure out what i am missing -__-
                      This is with SU8? Are there any strange characters in your user name on the computer?
                        taufikohidayat
                        yes, it is su8, I guess not... I haven't seen any strange character on my user name
                          Could you make and post a screen shot of the Info window (Get info) for your Plugins folder?
                            taufikohidayat
                            http://res.cloudinary.com/dsafcphpe/image/upload/v1405276467/Screen_Shot_2014-07-13_at_19_33_51_suox6i.png
                              Hmmmm....
                                taufikohidayat
                                @dave r said:
                                Hmmmm....
                                I found its annoying -__- I have no idea what did i do wrong when installing the plugin
                                • 2 / 2
