    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 259.9k Views 79 Watching
      Works fine with LightUp! β˜€
      And the fabulous Rail road system by Eneroth! β˜€
      • L
        laudhi
        i wish there is more option for vine/ivy.it will be amazing.... πŸ˜›
        • ppoublanP
          ppoublan
          Hi Laudhi,
          Have you checked the Ivy tool from pierreden publihed in this forum ? I'm also using it and maybe it will allow you to achieve what you want.
          Regarding 3D Tree Maker, you can use existing parameters to make "ivy like" trees. Let me know if they are any others you are thinking of ?
          but it is not interactive (like Ivy) and does not take into account existing objects in the model, as 3D Tree Maker is only based on predefined parameters.
          I think that both tools are complementary.
          Yours
          Pascal
          • L
            laudhi
            [attachment=0:kzqk1sgm]<!-- ia0 -->Capture.JPG<!-- ia0 -->[/attachment:kzqk1sgm][/quote]
            I'm just curious if there are plans for vines, there may be an easier way to make vines on the pole ...
            Your plugin is amazing, worth to buy the pro version.... πŸ‘
              rubenamaroh
              Help!!!
              I can't run this ruby, the program display in "Plugins" folder but dont display
              right next to the arrow the window options " New" , "License" and "About", whats wrong?
              Thanks.
                Have you got available, and then activated its Toolbar ?
                How did you 'install' it ?
                • deaneauD
                  deaneau
                  hi TIG
                  i have the same problem in 2013
                  in the menue appear only 3d ArcStudio.
                  i have installed via sketchucation pluginstore plugin.
                  if i try to open the toolbar this will not show in the windows.
                  regards dean
                  • ppoublanP
                    ppoublan
                    Dear all,
                    Just got an error with one of the version published, that did not work on SU8 nor SU2013.
                    Pushed the last one (1.10.11) on Sketchucation and my website.
                    Should load and setup menus now on all SU versions.
                    Let me know if you discover other errors.
                    Pascal
                    • deaneauD
                      deaneau
                      @ppoublan said:
                      Dear all,
                      Pascal
                      Hello Pascal,
                      this work now in 2013
                      thank you for your fast respond.
                      regards dean
                        Jorgensen
                        Hi Pascal
                        I have just purchased the plugin (version 1.10.07) and installed it in SU 8 pro.
                        I get an error when I try edit a tree πŸ˜•
                        Do you know how I can avoid this?
                        [EDIT]
                        It seems to work if I just press ok.
                        Is it somehow possible to speedup the redraw process - I'll have to wait several minutes before the tree is updated πŸ˜•
                        I guess it's a limitation of Sketchup, but I find the plugin hard to use then I have to wait this long every time πŸ˜•
                        • OxerO
                          Oxer
                          I came back to the v1.06.04 because this version draws the trees in few seconds (between 3 and 8 seconds in my computer), but there is one inconvenient, you lose the feature make grass and other features related with the Materials, present in the last version.
                          • ppoublanP
                            ppoublan
                            Hi Jorgensen,
                            Did you try with the last version : 1.10.11 that is published in the Plugin store here or from this link :
                            http://www.3darcstudio.com/downloads/3darcstudiotree/3darcstudio_tree_v1.10.11.rbz
                            Download the file,
                            Setup using standard SU rbz extension install
                            After install, exit and restart SU
                            Did the error still occur ?
                            If yes let me know and we will try other tests. First time I see it, so I need more investigation.
                            Does anybody here also got the same error ?
                            Regarding speed:
                            • on 2 different PCs I'm using, drawing a tree is less than 30s for the more complex one and less than 5seconds for the standard generic tree.
                            • be sure you close the Sketchup Outliner window: this is the main cause of slowness I have seen as SU try to refresh outliner for all geometry changes within scripts
                            • ensure also that additional plugins that checks for geometry changes (like render viewport) are not running while you are drawing a tree as they will try to update
                            • the script also runs a little bit faster on SU 2014.
                            Yours
                            Pascal
                            • ppoublanP
                              ppoublan
                              Dear all,
                              another tip to use tree maker with better performance, to place trees within large models:
                              • I build/change configuration of the tree in an new empty Sketchup model
                              • When I'm happy with the result, I convert it to proxy with the integrated tree maker proxy function
                              • Then I copy/paste this component (which is small) to the final model where I can make instances
                              • When all trees are in place and I want to render, i use "redraw all" in the final model, this can take some time if many trees, but have to do it only once before rendering
                              • I also use the proxies features of the renders when available (Thea, Octane, ...)
                                Yours
                                Pascal
                              • ppoublanP
                                ppoublan
                                Hi Oxer,
                                The main difference is that the old version is making SU groups, not components.
                                Using components is really more efficient when you need to place many instances, and you got also a SU file that is lighter.
                                So yes time to draw with the new version is a little bit more slow to draw one tree (on PC), but a lot much faster to redraw 20 or more trees as only the component is rebuild, not all instances.
                                This was the reason I make this change to integrate features like grass.
                                But as I really have acceptable performance on PC/2014 (few seconds to draw most of the trees), maybe i have a specific issue of speed with Mac.
                                I will try to add few time logs to the next version so see what is slowing down the most.
                                Yours
                                Pascal
                                • OxerO
                                  Oxer
                                  I found a plugin that it makes slow down the drawing of trees, BGSketchup_Composants.rb, with this plugin installed the drawing of tree02:Cypress takes 47 seconds, without the plugin installed the drawing takes 12 seconds, other example, the drawing of tree00:Default Generic Tree takes 6 seconds without plugin, with the plugin installed 55 seconds.
                                  Mac OSX 10.9.4 & SU2014 with Tree Maker v1.10.11
                                    Jorgensen
                                    I tried to removed all plugins, and the script seems to run ok - but I still get the error.
                                    If I install octane render, the problem happens again (things take very long time), even with the Octane Viewport closed.
                                    So it seems that octane render somehow sesses things up in my Sketchup.
                                    • ppoublanP
                                      ppoublan
                                      Dear all,
                                      Just fixed the issue with script error when loading configuration webdialog.
                                      New file published in PluginStore and on my website.
                                      Version is 3darcstudio_tree_v1.10.11a.rbz
                                      Yours
                                      Pascal
                                      PS : do not understand why javascript is executed differently when called from SU8 and from SU2014, but...
                                      • ppoublanP
                                        ppoublan
                                        Hi Oxer,
                                        Great to know. Thanks for tests you made.
                                        My understanding is that other plugins may add entities observers to Sketchup to be informed of any entity change. I'm not sure if this is the case for those you mentioned but I will have a look. When this is the case, each time a change is made to an entity, the third plugin is called. As drawing a tree make lots of change to entities within tree component, it add time due to all these calls.
                                        Yours
                                        • ppoublanP
                                          ppoublan
                                          Fixed (SU8).
                                          I'm also using Octane and cant see important additional delay to draw tree when viewport closed, Could you make a test with SU2014 as Octane Plugin is different for SU2014 ?
                                          Yours
                                          Pascal
                                            Jorgensen
                                            Hi pascal
                                            Not sure I understand you right, but I don't have sketchup 2014.
                                            Maybe I should reinstall sketchup and octane.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
