Adding texture library folder to sketchup
Hi there,
My question is quite simple. I'm browsing to system preference, going under the file tab, choosing a new location to add my library folder which contain my own textures (a pack of 60 GB), but it doesn't seem to be added when I browse the material library window. Tried also to add a new collection then, directly from the windows library, but when I quit application it doesn't come back and I've also no preview of textures displaying (just like if I had an empty folder in my texture library folders).
Seriously I've always used this technique to add a folder library and now it doesn't work (I'm a new user of SU pro)
As you can see on the img, I've added my collection from the material windows (which I normally doesn't need to do when I setup file location in preference system), and my folder seems to be empty when I browse it.
Any suggestions?
Cause I'm not going to add one by one my hundred of textures in the library, hell no
So if you click on the Details button in the Materials browser window, you can use Open or Create a collection... to add the library? After that, have you tried clicking on Add collection to favorites...?
Thanks for replying,
Of course I did it. But my folder looks empty in the library.
And usually I don't need to add from detail button as I'm adding library directly from the preferences. I'm lost a bit.
Some answers I've got told me that I got an empty folder because I've image files (jpgs, pngs etc.) and not .skm files (to show preview).
Anyone know a faster way than to add my textures one by one to the library? I've a 60GB database of jpg...
The Material Browser only list SKM files [as you have discovered].
There are probably several plugins / approaches to help you...
http://rhin.crai.archi.fr/rld/plugin_details.php?id=241
I made some tweaks to re-size the import a folder of images as Materials... or you will almost certainly need to adjust their texture sizes to suit you requirements by hand...
http://sketchucation.com/forums/viewtopic.php?p=243124#p243124 -
Thanks a lot TIG.
That's gonna help a lot.
To find materials & plugins folder for Mac users:
Find SU2014 folder in Applications
Right-click on SU folder and select "Show View Options"
This directs you to the Contents folderNavigation Path is:
/Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content
