    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 168.3k Views 41 Watching
      original string and translation next to each other.
      Of course yes, but without the "*" it's a nightmare for a totally noob of Ruby for pick exactly that is must be translated or not! ๐Ÿ˜‰
        mwm5053
        Hi Eneroth3 not getting any thing in dialogue box. I'm on Mac with Safari 7.0.4 and SU 2014 everything up to date.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • eneroth3E
          eneroth3
          Is it the same for all dialogs or just this one?
          My website: http://julia-christina-eneroth.se/
            mwm5053
            Here's some more screen shots of the other dialog boxes.
            2011 iMac
            V2 Twilight
              Something that RailRoadsystem can do! โ˜€
              Just replace locomotive by planes! ๐Ÿ˜„
              • eneroth3E
                eneroth3
                Thanks ๐Ÿ˜„
                It looks as if the javascript code in dialog.show_modal doesn't run on that specific web dialog, probably due to a misspelling in the code. Hopefully there's no problem with the other dialogs ๐Ÿ˜„
                • eneroth3E
                  eneroth3
                  French translation of the Documentation is done! ๐Ÿ˜„
                  I will see now if the new version 1.1.0 has a new documenttion! ๐Ÿ˜‰
                  ๐Ÿ‘
                  I don't understand much French so I can't say much about the translation but I did notice you have capital letters where there shouldn't be in the motion types of the mechanical parts in rolling stocks. Unless these (and all other text the user writes) is spelled correctly the computer won't understand it.
                    Can you give me an example and addresse page?
                    For correction if necessary ๐Ÿ˜„
                      I will see now if the new version 1.1.0 has a new documentation! ๐Ÿ˜‰
                      • eneroth3E
                        eneroth3
                        I don't know if you changed the capital letter because now I can't find them but the Create Rolling stock page mentions an attribute called "rayon" that doesn't exist in the plugin. Also there are no headers in the text except for in a few random places so it's quite hard to see what text belongs to what.
                          Effectivelly I had changed some capitals ๐Ÿ˜„
                          yes it's all the difficulty of translation!
                          What translate or not! ๐Ÿ˜„
                          So imagine in the Ruby code Text! ๐Ÿ˜„
                          "radius" and all few little things corrected
                          This is very mysterious for me!
                          Have you an example of that ? Or a Copy screen ?
                          • eneroth3E
                            eneroth3
                            "Les piรจces en mouvement" is a little bigegr than normal text and has the same color even though it is a second level header. "Toutes les piรจces mรฉcaniques" looks the same even though it's a third level header. "translation_circular" is also a third level header but it's white unlike all other text.
                            • deaneauD
                              deaneau
                              is a translation of the plugin realy important?. ok the manual in other languages is ok.
                              pilou i would understand your wish, if eneroth to have written the plugin in swedish.
                              i think this is not the main problem.
                              my native language is german, and i donยดt ask about any translations.
                              the common denominator is english i think.
                              will you let play your kids with this plugin? ๐Ÿ˜‰
                              i must say in donยดt missing german in this plugin.
                              best regards to a wonderful france. i watching in ARTE(TV)any documentaions about france.
                              dean from berlin
                              p.s.
                              here some text from mark twain about german language.
                              (www.crossmyt.com)
                              or here
                              http://usa.usembassy.de/classroom/Mark%20Twain/Mark%20Twain%20Awful%20Broschuere.pdf
                              german have very long words and if i see the plugin, the layout must be changed.
                              • deaneauD
                                deaneau
                                pilou the same i have written to eneroth.
                                not only plane you can use ships , too.
                                oops my sailboat is flooding,
                                ok i have find a life guard ๐Ÿ˜„
                                • eneroth3E
                                  eneroth3
                                  If there is a translation it has to be 100% correct and not fool the user into problems with the plugin. However I don't see a very big need for it. Learning English, today's lingua franca, is a long term solution that is also very beneficial in other situations throughout life.
                                  • deaneauD
                                    deaneau
                                    translation is on part, the translator must understand the subject,too.
                                    i need only a translation, if the subject will be very difficult to understand.
                                    difficult for me is the way to setup the rolling stock like the flying scotman.
                                    dean
                                    • eneroth3E
                                      eneroth3
                                      dean
                                      That's also the part hardest to translate because if anything is not 100% perfect it will go wrong and not work. I might some day look into the docs and try to make it easier to understand with more images, perhaps even videos of certain steps. Perhaps there will even be a graphical interface in the distant future to initialize the moving parts more easily.
                                      • deaneauD
                                        deaneau
                                        yes, one movie or picture tell more than thousand words.
                                          Some Titles corrections You are very strict! ๐Ÿ˜„
                                          As the page text is some long, reader has forgotten the level of reading and me too! ๐Ÿ˜„
                                          • OxerO
                                            Oxer
                                            Excuse for no reply before. All web dialogs work fine now on Mac 10.9.3 & SU2014, included "Insert Track".
                                            One question, the Track Properties icon is off although you have selected a Track, you can to access to the Properties Track only by Contextual Menu.
                                            To translate the web dialogs BGSketchup_Composants plugin have a file named Loacalization.rb that include all languages, I don't know the ruby code but perhaps this can be a solution to give support to translation.
                                            • 18
                                            • 19
                                            • 6 / 19
