    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 107.0k Views 41 Watching
      mwm5053
      Hi Eneroth3 not getting any thing in dialogue box. I'm on Mac with Safari 7.0.4 and SU 2014 everything up to date.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • eneroth3E Offline
        eneroth3
        Is it the same for all dialogs or just this one?
        My website: http://julia-christina-eneroth.se/
          mwm5053
          Here's some more screen shots of the other dialog boxes.
          2011 iMac
          V2 Twilight
            Something that RailRoadsystem can do! โ˜€
            Just replace locomotive by planes! ๐Ÿ˜„
            • eneroth3E Offline
              eneroth3
              Thanks ๐Ÿ˜„
              It looks as if the javascript code in dialog.show_modal doesn't run on that specific web dialog, probably due to a misspelling in the code. Hopefully there's no problem with the other dialogs ๐Ÿ˜„
              • eneroth3E Offline
                eneroth3
                French translation of the Documentation is done! ๐Ÿ˜„
                I will see now if the new version 1.1.0 has a new documenttion! ๐Ÿ˜‰
                ๐Ÿ‘
                I don't understand much French so I can't say much about the translation but I did notice you have capital letters where there shouldn't be in the motion types of the mechanical parts in rolling stocks. Unless these (and all other text the user writes) is spelled correctly the computer won't understand it.
                  Can you give me an example and addresse page?
                  For correction if necessary ๐Ÿ˜„
                    I will see now if the new version 1.1.0 has a new documentation! ๐Ÿ˜‰
                    • eneroth3E Offline
                      eneroth3
                      I don't know if you changed the capital letter because now I can't find them but the Create Rolling stock page mentions an attribute called "rayon" that doesn't exist in the plugin. Also there are no headers in the text except for in a few random places so it's quite hard to see what text belongs to what.
                        Effectivelly I had changed some capitals ๐Ÿ˜„
                        yes it's all the difficulty of translation!
                        What translate or not! ๐Ÿ˜„
                        So imagine in the Ruby code Text! ๐Ÿ˜„
                        "radius" and all few little things corrected
                        This is very mysterious for me!
                        Have you an example of that ? Or a Copy screen ?
                        • eneroth3E Offline
                          eneroth3
                          "Les piรจces en mouvement" is a little bigegr than normal text and has the same color even though it is a second level header. "Toutes les piรจces mรฉcaniques" looks the same even though it's a third level header. "translation_circular" is also a third level header but it's white unlike all other text.
                          • deaneauD Offline
                            deaneau
                            is a translation of the plugin realy important?. ok the manual in other languages is ok.
                            pilou i would understand your wish, if eneroth to have written the plugin in swedish.
                            i think this is not the main problem.
                            my native language is german, and i donยดt ask about any translations.
                            the common denominator is english i think.
                            will you let play your kids with this plugin? ๐Ÿ˜‰
                            i must say in donยดt missing german in this plugin.
                            best regards to a wonderful france. i watching in ARTE(TV)any documentaions about france.
                            dean from berlin
                            p.s.
                            here some text from mark twain about german language.
                            301 Moved Permanently
                            (www.crossmyt.com)
                            or here
                            http://usa.usembassy.de/classroom/Mark%20Twain/Mark%20Twain%20Awful%20Broschuere.pdf
                            german have very long words and if i see the plugin, the layout must be changed.
                            • deaneauD Offline
                              deaneau
                              pilou the same i have written to eneroth.
                              not only plane you can use ships , too.
                              oops my sailboat is flooding,
                              ok i have find a life guard ๐Ÿ˜„
                              • eneroth3E Offline
                                eneroth3
                                If there is a translation it has to be 100% correct and not fool the user into problems with the plugin. However I don't see a very big need for it. Learning English, today's lingua franca, is a long term solution that is also very beneficial in other situations throughout life.
                                • deaneauD Offline
                                  deaneau
                                  translation is on part, the translator must understand the subject,too.
                                  i need only a translation, if the subject will be very difficult to understand.
                                  difficult for me is the way to setup the rolling stock like the flying scotman.
                                  dean
                                  • eneroth3E Offline
                                    eneroth3
                                    dean
                                    That's also the part hardest to translate because if anything is not 100% perfect it will go wrong and not work. I might some day look into the docs and try to make it easier to understand with more images, perhaps even videos of certain steps. Perhaps there will even be a graphical interface in the distant future to initialize the moving parts more easily.
                                    • deaneauD Offline
                                      deaneau
                                      yes, one movie or picture tell more than thousand words.
                                        Some Titles corrections You are very strict! ๐Ÿ˜„
                                        As the page text is some long, reader has forgotten the level of reading and me too! ๐Ÿ˜„
                                        • OxerO Offline
                                          Oxer
                                          Excuse for no reply before. All web dialogs work fine now on Mac 10.9.3 & SU2014, included "Insert Track".
                                          One question, the Track Properties icon is off although you have selected a Track, you can to access to the Properties Track only by Contextual Menu.
                                          To translate the web dialogs BGSketchup_Composants plugin have a file named Loacalization.rb that include all languages, I don't know the ruby code but perhaps this can be a solution to give support to translation.
                                            With new version 1.11 on 2014 (previous version was fine)
                                            Seems Connect Ends system from Selection between roads create rails! ๐Ÿ˜ฒ
                                            Does this normal ?
                                            And Add a Rolling Stock adds an image and not a volume! ๐Ÿ˜ฎ
                                            • 18
                                            • 19
                                            • 6 / 19
