    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 231.5k Views 45 Watching
      Chairs are very cuty! 😎
      • cottyC Offline
        cotty
        @baz said:
        That second chair is a ripper cotty, I wouldn't mind having a go at making it for real using laminated timber.
        baz
        Thank you! If it was a chair of Alvydas, it would probably be beautiful and perfect textured as laminated timber 😎 . Maybe this will be a task to practice the new texturing tools out there ...
        my SketchUp gallery
        • cottyC Offline
          cotty
          Chair no. 4...
          chair_04_cotty.skp
          my SketchUp gallery
          • cottyC Offline
            cotty
            "Chair" number 5 (with the help of honeycomber)...
            chair_05_cotty.skp
            my SketchUp gallery
            • cottyC Offline
              cotty
              A new post after a long time...
              ...but with power: a wind turbine πŸ˜‰
              cotty_windturbine.skp
              my SketchUp gallery
              • cottyC Offline
                cotty
                A simple rocket...
                cotty_rocket.skp
                my SketchUp gallery
                • cottyC Offline
                  cotty
                  A curvy bookshelf...
                  cotty_bookshelf.skp
                  my SketchUp gallery
                  • N Offline
                    ninopiamonte
                    Nice overall, keep sharing
                      shri
                      lots of organic modeling tutorials..thanks
                      • bazB Offline
                        baz
                        Nice cotty.
                        How would you go about this if you wanted a single face for the front and back?
                        Ie: as if it were bent plywood with vertical edges in the z plane.
                        Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:)
                        baz
                          d12dozr
                          Delete the sides, crease the corners, run artisan, then just draw 4 lines to connect the corners together.
                          Like so:
                          Awesome collection, Cotty - please keep it up! This thread was invaluable to me a couple weeks ago when I made my first real project with SDS (I haven't needed to upgrade to Artisan yet.) The project was for 3D printing, and my customer was very happy with the result, so thank you!
                          cotty_baz_bookshelf.skp
                          http://goo.gl/f7ooYh
                          • bazB Offline
                            baz
                            Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
                            • mitcorbM Offline
                              mitcorb
                              Hi, cotty:
                              Your thread is inspiring and helpful. I have tried a few of the examples, myself. Thank you for posting.
                              • jeff hammondJ Offline
                                @baz said:
                                Nice cotty.
                                baz
                                maybe?
                                [edit] after step3, delete the face which has all sorts of coplanar lines from the subsmooth.. draw a line to form a new single face.. then push/pull..
                                  d12dozr
                                  Just use the Crease tool (at least that's what its called in Subdivide & Smooth), and click on each of those vertices. The Crease tool icon changes from Red when uncreased to Green when creased. There's not a visible effect right away on the model, but you'll be able to tell the difference after running the plugin.
                                  ...or in this case, Jeff's way is simpler, but you'll still want to crease the end vertices before subdividing so you get square ends. πŸ‘
                                  • cottyC Offline
                                    cotty
                                    I am not shure, but I will dream of it, maybe a solution will appear ...
                                    Here is a little boat ...
                                    cotty_boat.skp
                                    my SketchUp gallery
                                    • bazB Offline
                                      baz
                                      Thanks Marcus, got it.
                                      • cottyC Offline
                                        cotty
                                        Thanks to ninopiamonte, shri, d12dozr, mitcorb for your kind words. I'll try to add new examples regularly. If you have any ideas for simple geometries, let me know or feel free to share them here too...
                                        Another example: a very simple wind flower...
                                        cotty_wind_flower.skp
                                        my SketchUp gallery
                                        • cottyC Offline
                                          cotty
                                          An (empty) piggy bank...
                                          cotty_piggy_bank.skp
                                          my SketchUp gallery
                                            leminilab
                                            Here's a little contribution to this great thread:
                                            pipistrello lamp
                                            pipistrello lamp
                                            This one can be certainly found on the internet but I found this an interesting modelling challentge. Could be better but there you go.
                                            Thanks a lot for starting this Cotty! πŸ˜„
                                            Nicolas
                                            • "Live every day as if it were your last and then some day you'll be right."
                                            • "ThomThom rules!!!"
                                            • 22
                                            • 23
                                            • 4 / 23
