    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 360.0k Views 45 Watching
    • cottyC
      cotty
      A curvy bookshelf...
      cotty_bookshelf.skp
      my SketchUp gallery
      • N
        ninopiamonte
        Nice overall, keep sharing
          shri
          lots of organic modeling tutorials..thanks
          • bazB
            baz
            Nice cotty.
            How would you go about this if you wanted a single face for the front and back?
            Ie: as if it were bent plywood with vertical edges in the z plane.
            Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:)
            baz
              d12dozr
              Delete the sides, crease the corners, run artisan, then just draw 4 lines to connect the corners together.
              Like so:
              Awesome collection, Cotty - please keep it up! This thread was invaluable to me a couple weeks ago when I made my first real project with SDS (I haven't needed to upgrade to Artisan yet.) The project was for 3D printing, and my customer was very happy with the result, so thank you!
              cotty_baz_bookshelf.skp
              http://goo.gl/f7ooYh
              • bazB
                baz
                Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
                • mitcorbM
                  mitcorb
                  Hi, cotty:
                  Your thread is inspiring and helpful. I have tried a few of the examples, myself. Thank you for posting.
                  • jeff hammondJ
                    @baz said:
                    Nice cotty.
                    baz
                    maybe?
                    [edit] after step3, delete the face which has all sorts of coplanar lines from the subsmooth.. draw a line to form a new single face.. then push/pull..
                      d12dozr
                      Just use the Crease tool (at least that's what its called in Subdivide & Smooth), and click on each of those vertices. The Crease tool icon changes from Red when uncreased to Green when creased. There's not a visible effect right away on the model, but you'll be able to tell the difference after running the plugin.
                      ...or in this case, Jeff's way is simpler, but you'll still want to crease the end vertices before subdividing so you get square ends. ๐Ÿ‘
                      • cottyC
                        cotty
                        I am not shure, but I will dream of it, maybe a solution will appear ...
                        Here is a little boat ...
                        cotty_boat.skp
                        my SketchUp gallery
                        • bazB
                          baz
                          Thanks Marcus, got it.
                          • cottyC
                            cotty
                            Thanks to ninopiamonte, shri, d12dozr, mitcorb for your kind words. I'll try to add new examples regularly. If you have any ideas for simple geometries, let me know or feel free to share them here too...
                            Another example: a very simple wind flower...
                            cotty_wind_flower.skp
                            my SketchUp gallery
                            • cottyC
                              cotty
                              An (empty) piggy bank...
                              cotty_piggy_bank.skp
                              my SketchUp gallery
                              • L
                                leminilab
                                Here's a little contribution to this great thread:
                                pipistrello lamp
                                pipistrello lamp
                                This one can be certainly found on the internet but I found this an interesting modelling challentge. Could be better but there you go.
                                Thanks a lot for starting this Cotty! ๐Ÿ˜„
                                Nicolas
                                • "Live every day as if it were your last and then some day you'll be right."
                                • "ThomThom rules!!!"
                                • cottyC
                                  cotty
                                  A simple washbasin...
                                  cotty_washbasin.skp
                                  my SketchUp gallery
                                  • cottyC
                                    cotty
                                    A footprint ...
                                    footprint.skp
                                    my SketchUp gallery
                                    • L
                                      leminilab
                                      Seriously, I'm having a blast seeing you enjoying what you do that much! ๐Ÿ˜„
                                      I like! ๐Ÿ‘
                                      • cottyC
                                        cotty
                                        I like! ๐Ÿ‘
                                        Thank you! And you are right, I enjoy these little Artisan practices ๐Ÿ˜‰
                                        my SketchUp gallery
                                        • utilerU
                                          utiler
                                          I'm with you nicholas; cotty you bring joy to my day when I've seen what you're doing with Artisan....
                                          Just Curious...
                                          • cottyC
                                            cotty
                                            Thank you! Here is the next one: "The hand" (anatomically questionable ๐Ÿ˜• ) ...
                                            cotty_hand.skp
                                            my SketchUp gallery
                                            • 22
                                            • 23
                                            • 4 / 23
