    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 373.3k Views 45 Watching
    • N
      ninopiamonte
      Nice overall, keep sharing
        shri
        lots of organic modeling tutorials..thanks
        • bazB
          baz
          Nice cotty.
          How would you go about this if you wanted a single face for the front and back?
          Ie: as if it were bent plywood with vertical edges in the z plane.
          Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:)
          baz
            d12dozr
            Delete the sides, crease the corners, run artisan, then just draw 4 lines to connect the corners together.
            Like so:
            Awesome collection, Cotty - please keep it up! This thread was invaluable to me a couple weeks ago when I made my first real project with SDS (I haven't needed to upgrade to Artisan yet.) The project was for 3D printing, and my customer was very happy with the result, so thank you!
            cotty_baz_bookshelf.skp
            http://goo.gl/f7ooYh
            • bazB
              baz
              Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
              • mitcorbM
                mitcorb
                Hi, cotty:
                Your thread is inspiring and helpful. I have tried a few of the examples, myself. Thank you for posting.
                • jeff hammondJ
                  @baz said:
                  Nice cotty.
                  baz
                  maybe?
                  [edit] after step3, delete the face which has all sorts of coplanar lines from the subsmooth.. draw a line to form a new single face.. then push/pull..
                    d12dozr
                    Just use the Crease tool (at least that's what its called in Subdivide & Smooth), and click on each of those vertices. The Crease tool icon changes from Red when uncreased to Green when creased. There's not a visible effect right away on the model, but you'll be able to tell the difference after running the plugin.
                    ...or in this case, Jeff's way is simpler, but you'll still want to crease the end vertices before subdividing so you get square ends. πŸ‘
                    • cottyC
                      cotty
                      I am not shure, but I will dream of it, maybe a solution will appear ...
                      Here is a little boat ...
                      cotty_boat.skp
                      my SketchUp gallery
                      • bazB
                        baz
                        Thanks Marcus, got it.
                        • cottyC
                          cotty
                          Thanks to ninopiamonte, shri, d12dozr, mitcorb for your kind words. I'll try to add new examples regularly. If you have any ideas for simple geometries, let me know or feel free to share them here too...
                          Another example: a very simple wind flower...
                          cotty_wind_flower.skp
                          my SketchUp gallery
                          • cottyC
                            cotty
                            An (empty) piggy bank...
                            cotty_piggy_bank.skp
                            my SketchUp gallery
                            • L
                              leminilab
                              Here's a little contribution to this great thread:
                              pipistrello lamp
                              pipistrello lamp
                              This one can be certainly found on the internet but I found this an interesting modelling challentge. Could be better but there you go.
                              Thanks a lot for starting this Cotty! πŸ˜„
                              Nicolas
                              • "Live every day as if it were your last and then some day you'll be right."
                              • "ThomThom rules!!!"
                              • cottyC
                                cotty
                                A simple washbasin...
                                cotty_washbasin.skp
                                my SketchUp gallery
                                • cottyC
                                  cotty
                                  A footprint ...
                                  footprint.skp
                                  my SketchUp gallery
                                  • L
                                    leminilab
                                    Seriously, I'm having a blast seeing you enjoying what you do that much! πŸ˜„
                                    I like! πŸ‘
                                    • cottyC
                                      cotty
                                      I like! πŸ‘
                                      Thank you! And you are right, I enjoy these little Artisan practices πŸ˜‰
                                      my SketchUp gallery
                                      • utilerU
                                        utiler
                                        I'm with you nicholas; cotty you bring joy to my day when I've seen what you're doing with Artisan....
                                        Just Curious...
                                        • cottyC
                                          cotty
                                          Thank you! Here is the next one: "The hand" (anatomically questionable πŸ˜• ) ...
                                          cotty_hand.skp
                                          my SketchUp gallery
                                          • cottyC
                                            cotty
                                            The glass carafe ...
                                            cotty_glasscarafe.skp
                                            my SketchUp gallery
                                            • 22
                                            • 23
                                            • 4 / 23
