    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 327.9k Views 45 Watching
    • cottyC Offline
      cotty
      Lomme bed by leminilab from here...
      (ZIP with model is attached there)
      my SketchUp gallery
      • cottyC Offline
        cotty
        Snoopy by Solo from here...
        my SketchUp gallery
        • cottyC Offline
          cotty
          [Tutorial] Penguin by Boofredlay from here...
          my SketchUp gallery
          • cottyC Offline
            cotty
            A simple tooth example...
            tooth.skp
            my SketchUp gallery
            • cottyC Offline
              cotty
              A simple plastic chair ...
              chair_cotty_01.skp
              my SketchUp gallery
              • cottyC Offline
                cotty
                Another chair from me ...
                chair_cotty_02.skp
                my SketchUp gallery
                • bazB Offline
                  baz
                  That second chair is a ripper cotty, I wouldn't mind having a go at making it for real using laminated timber.
                  baz
                  • cottyC Offline
                    cotty
                    Another chair ...
                    chair_03_cotty.skp
                    my SketchUp gallery
                      Chairs are very cuty! 😎
                      • cottyC Offline
                        cotty
                        baz
                        Thank you! If it was a chair of Alvydas, it would probably be beautiful and perfect textured as laminated timber 😎 . Maybe this will be a task to practice the new texturing tools out there ...
                        my SketchUp gallery
                        • cottyC Offline
                          cotty
                          Chair no. 4...
                          chair_04_cotty.skp
                          my SketchUp gallery
                          • cottyC Offline
                            cotty
                            "Chair" number 5 (with the help of honeycomber)...
                            chair_05_cotty.skp
                            my SketchUp gallery
                            • cottyC Offline
                              cotty
                              A new post after a long time...
                              ...but with power: a wind turbine πŸ˜‰
                              cotty_windturbine.skp
                              my SketchUp gallery
                              • cottyC Offline
                                cotty
                                A simple rocket...
                                cotty_rocket.skp
                                my SketchUp gallery
                                • cottyC Offline
                                  cotty
                                  A curvy bookshelf...
                                  cotty_bookshelf.skp
                                  my SketchUp gallery
                                  • N Offline
                                    ninopiamonte
                                    Nice overall, keep sharing
                                      shri
                                      lots of organic modeling tutorials..thanks
                                      • bazB Offline
                                        baz
                                        Nice cotty.
                                        How would you go about this if you wanted a single face for the front and back?
                                        Ie: as if it were bent plywood with vertical edges in the z plane.
                                        Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:)
                                        baz
                                          d12dozr
                                          Delete the sides, crease the corners, run artisan, then just draw 4 lines to connect the corners together.
                                          Like so:
                                          Awesome collection, Cotty - please keep it up! This thread was invaluable to me a couple weeks ago when I made my first real project with SDS (I haven't needed to upgrade to Artisan yet.) The project was for 3D printing, and my customer was very happy with the result, so thank you!
                                          cotty_baz_bookshelf.skp
                                          http://goo.gl/f7ooYh
                                          • bazB Offline
                                            baz
                                            Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
                                            • 22
                                            • 23
                                            • 4 / 23
