    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 112.8k Views 41 Watching
      See the bottom of the previous page! ๐Ÿ˜‰
      • deaneauD Offline
        deaneau
        Here some parts based on the intersections
        • deaneauD Offline
          deaneau
          my suggestion copy a loco in a separate folder and open this in sketchup and look where the wheels must be.
            I am not sure that only this placement resolve my little problem ๐Ÿ˜„
            As I want input any volume as Loco I had believed that the 7 clicks inputs on this volume were sufficient!
            As I had the message "Give a name" (I gave "Bull" I had supposed that all works fine!
            But no trace of this file nowhere! ๐Ÿ˜ฒ
            Move it on the good altitude of rail don't change nothing!
            http://sketchucation.com/forums/download/file.php?id=120825&mode=view/rokbox.jpg
            • eneroth3E Offline
              eneroth3
              At 2:48:04 in this video you can see how rolling stocks are initialized and then optionally saved to the library. Saving to the library is still quite undeveloped and has to be done through the console now but a graphical interface is planned.
              My website: http://julia-christina-eneroth.se/
                II will study that ๐Ÿ˜„
                • eneroth3E Offline
                  eneroth3
                  Something is wrong with the point you input, otherwise the rolling stock would stand on the track. Also initializing as rolling stock doesn't add it to the library.
                  • deaneauD Offline
                    deaneau
                    i havnยดt try rolling stock. this answer could give the good manual or Eneroth.
                    i dont know, do you have download the big movie.. Eneroth have build a loco, could be you find the answer there ,too.
                      You want to say that is just temporary ? Where it is saved ?
                      Here my volume is named ok ๐Ÿ˜„
                      But alas when I try to Drive it : This train is not on the rail etc... ๐Ÿ˜ฎ
                      • eneroth3E Offline
                        eneroth3
                        Last mystery : ๐Ÿ’š
                        Just now, how to put this volume in the library ? โ“ โ“ โ“
                        A better and graphical interface is planned (including prompting the user already when initializing the rolling stock). for now you need to do as the documentation (Plugins>Railroad>Documentation) or the video I linked says.
                          Many Thanks! ๐Ÿ˜„ I will be patient! โ˜€
                          It's yet now a little true Gem! ๐Ÿ˜Ž
                          • deaneauD Offline
                            deaneau
                            Here some parts for intersections. based on eneroth intersections_2014.06.15_21h28m46s_008_00808.jpgINTERSECTION GB_EU.skp for all friends from GB, too
                            and here variations with CrossWalk
                            _2014.06.15_23h29m50s_011_00811.jpgINTERSECTION GB_EU_PED.skp
                              Bingo!!!! That works fine! โ˜€ โ˜€ โ˜€
                              The trick was to take the 7 clicks "in diagonal" Front / Bottom, Left / Right for avoid same plane! ๐Ÿ˜Ž
                              Another thing : Can I group the girl to the existing volume and Drive it? Seems not! ๐Ÿ˜ž
                              Edit : Bingo again : not group the girl with the volume, but put she "inside" the Volume grouped (in the Menu Window/ Structure! ) ๐Ÿ˜Ž
                              So you can transport any thing! โ˜€
                              http://s6.postimg.org/6p9qpviz5/train5.jpg
                              A funny thing : if you hide thre rails, you can drive any thing like along a path! ๐Ÿ˜Ž
                              Last mystery : ๐Ÿ’š
                              • deaneauD Offline
                                deaneau
                                  Cool roads design! ๐Ÿ˜Ž
                                  Something to know for LightUp : if you put a component "Face me" for transporting on something : animation will works fine in SU but not in LightUp! ๐Ÿ˜ฒ
                                  So put normal components and the animation will work fine also in LightUp! โ˜€
                                  • deaneauD Offline
                                    deaneau
                                    Here a a version with Fences.
                                    i will upload the ready version. the fences have 12 sites (more high poly) tell me when you need lowpoly (5S or 6S),too. than i upload both versions. the fence is without textures, so you can texuring by your self.
                                      ๐Ÿ˜‰
                                      http://moviereviews.allmyblog.com/images/moviereviews/1_20110406_021028.jpg
                                      • eneroth3E Offline
                                        eneroth3
                                        I've been working on an update to the plugin so the inner side of the road can be hidden when automatically drawn. This means each "track" doesn't need to be manually edited to hide these edges and the parametric functionally is much better.
                                        I've made some videos showing how fast it is/will be to edit the intersections.
                                        Change angle and remove outgoing street
                                        Draw road (and how to make sure curves can be arcs)
                                        Drawing a bridge
                                        You can try this already with the new intersections attached but with the current version of the plugin edges will appear in the middle of the street. I'll publish a new version of the plugin when there are some more features added.
                                        intersection2.skp
                                          What a system! ๐Ÿ˜Ž
                                          • deaneauD Offline
                                            deaneau
                                            here now the download
                                            INTERSECTION GB_EU_PED_TL_FENCE.rar
                                            • 18
                                            • 19
                                            • 4 / 19
