    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.1k Views 41 Watching
    • eneroth3E
      eneroth3
      I am not sure that only this placement resolve my little problem ๐Ÿ˜„
      As I want input any volume as Loco I had believed that the 7 clicks inputs on this volume were sufficient!
      As I had the message "Give a name" (I gave "Bull" I had supposed that all works fine!
      But no trace of this file nowhere! ๐Ÿ˜ฒ
      Move it on the good altitude of rail don't change nothing!
      http://sketchucation.com/forums/download/file.php?id=120825&mode=view/rokbox.jpg
      Something is wrong with the point you input, otherwise the rolling stock would stand on the track. Also initializing as rolling stock doesn't add it to the library.
      My website: http://julia-christina-eneroth.se/
      • deaneauD
        deaneau
        i havnยดt try rolling stock. this answer could give the good manual or Eneroth.
        i dont know, do you have download the big movie.. Eneroth have build a loco, could be you find the answer there ,too.
          You want to say that is just temporary ? Where it is saved ?
          Here my volume is named ok ๐Ÿ˜„
          But alas when I try to Drive it : This train is not on the rail etc... ๐Ÿ˜ฎ
          • eneroth3E
            eneroth3
            Last mystery : ๐Ÿ’š
            Just now, how to put this volume in the library ? โ“ โ“ โ“
            A better and graphical interface is planned (including prompting the user already when initializing the rolling stock). for now you need to do as the documentation (Plugins>Railroad>Documentation) or the video I linked says.
              Many Thanks! ๐Ÿ˜„ I will be patient! โ˜€
              It's yet now a little true Gem! ๐Ÿ˜Ž
              • deaneauD
                deaneau
                Here some parts for intersections. based on eneroth intersections_2014.06.15_21h28m46s_008_00808.jpgINTERSECTION GB_EU.skp for all friends from GB, too
                and here variations with CrossWalk
                _2014.06.15_23h29m50s_011_00811.jpgINTERSECTION GB_EU_PED.skp
                  Bingo!!!! That works fine! โ˜€ โ˜€ โ˜€
                  The trick was to take the 7 clicks "in diagonal" Front / Bottom, Left / Right for avoid same plane! ๐Ÿ˜Ž
                  Another thing : Can I group the girl to the existing volume and Drive it? Seems not! ๐Ÿ˜ž
                  Edit : Bingo again : not group the girl with the volume, but put she "inside" the Volume grouped (in the Menu Window/ Structure! ) ๐Ÿ˜Ž
                  So you can transport any thing! โ˜€
                  http://s6.postimg.org/6p9qpviz5/train5.jpg
                  A funny thing : if you hide thre rails, you can drive any thing like along a path! ๐Ÿ˜Ž
                  Last mystery : ๐Ÿ’š
                  • deaneauD
                    deaneau
                      Cool roads design! ๐Ÿ˜Ž
                      Something to know for LightUp : if you put a component "Face me" for transporting on something : animation will works fine in SU but not in LightUp! ๐Ÿ˜ฒ
                      So put normal components and the animation will work fine also in LightUp! โ˜€
                      • deaneauD
                        deaneau
                        Here a a version with Fences.
                        i will upload the ready version. the fences have 12 sites (more high poly) tell me when you need lowpoly (5S or 6S),too. than i upload both versions. the fence is without textures, so you can texuring by your self.
                          ๐Ÿ˜‰
                          http://moviereviews.allmyblog.com/images/moviereviews/1_20110406_021028.jpg
                          • eneroth3E
                            eneroth3
                            I've been working on an update to the plugin so the inner side of the road can be hidden when automatically drawn. This means each "track" doesn't need to be manually edited to hide these edges and the parametric functionally is much better.
                            I've made some videos showing how fast it is/will be to edit the intersections.
                            Change angle and remove outgoing street
                            Draw road (and how to make sure curves can be arcs)
                            Drawing a bridge
                            You can try this already with the new intersections attached but with the current version of the plugin edges will appear in the middle of the street. I'll publish a new version of the plugin when there are some more features added.
                            intersection2.skp
                              What a system! ๐Ÿ˜Ž
                              • deaneauD
                                deaneau
                                here now the download
                                INTERSECTION GB_EU_PED_TL_FENCE.rar
                                • eneroth3E
                                  eneroth3
                                  deaneau: Instead of manually modelling the fence you could add it as a track type and be able to use it in all sorts of curves without ever having to remodel it! The plugin adds parametric behavior for just this.
                                  • deaneauD
                                    deaneau
                                    oh realy? could you guide me with a movie?
                                    that will be interesting for other ,too.
                                    thank you Dean
                                      Are you interested by a French translation of the documentation ? ๐Ÿ˜„
                                      If someone don't yet made it! ๐Ÿ˜’
                                      Started ๐Ÿ˜„
                                      http://railroadsystem.weebly.com/
                                      • eneroth3E
                                        eneroth3
                                        thank you Dean
                                        It's all in the documentation. So far placing objects along the track is written in the Tie/Sleeper section but it's done in the same way even no matter what kind of objects there are. Also the existing tracks are great to understand how track types work. The truss bridge in particular shows how to place objects along the track.
                                        Started ๐Ÿ˜„
                                        So far the plugin is under quite heavy development and the docs are changing. For instance I might rewrite the Tie/Sleepers section to make it more clear that it can be used to place any objects along the track. Perhaps it's better to wait with the translation until the plugin doesn't change as much.
                                          No problem, i can change anything at any time! ๐Ÿ˜„
                                          And the advantage for me of this actual translation is that I learn it in the same time! ๐Ÿ˜‰
                                          • eneroth3E
                                            eneroth3
                                            Then it sounds like a good idea ๐Ÿ‘ ๐Ÿ‘
                                            • 18
                                            • 19
                                            • 4 / 19
