    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 168.3k Views 41 Watching
    • eneroth3E
      eneroth3
      place the folders in "<plugin folder>/ene_railroad/tracks/". If you can't find the plugin folder you can activate the Insert Rolling Stock tool and click the Open Rolling Stock folder button, then go up one level and open you'll see tracks/.
      My website: http://julia-christina-eneroth.se/
        Thx! Cool now! โ˜€
        No sure that streets was for trains?
        • eneroth3E
          eneroth3
          You can initialize cars as rolling stocks to drive them on the roads.
          You can also right click on the streets with the sidewalk in the middle, open their properties and reverse them to put the sidewalk on the side.
            For create a new one car or train...
            Can I take any volume as one group ?
            Does this group must be ont the rail or street during the creation?
            Where must be this new on after I give it a name ?
            Because seems nothing is created after the naming! ๐Ÿ˜„
            • eneroth3E
              eneroth3
              It must be standing on a track/street to be driven so it's easiest to initialize it there too. To find the center plane of the street you can draw a temporary edge between the painted lines at the sides of that lane and position the group at its midpoint.
                Ok but about the naming?
                If it's ask a name, that want to say that all points are fully ...so in what folder goes the new one created ?
                Creation was success after the naming but...
                and I see nowhere where is the "Bull" that I had created! ๐Ÿ˜„
                  All this new creation can be done in SU Make ?
                  A new one must follow all the parts of an existing One?
                  A simple box volume can't be work ?
                  • deaneauD
                    deaneau
                    @eneroth3 said:
                    Hi all.
                    I've made a street version of the track now....
                    many thanks thats looks good.
                    you have pm about streets in berlin
                    regards dean
                    • deaneauD
                      deaneau
                      Thanks for the info! โ˜€
                      You have made a true gem! ๐Ÿ˜Ž
                      Will try the Streets maker as soon as possible! ๐Ÿค“
                      Can you show the image of the arborescence of the new Files Folders Streets supposed to be ? ๐Ÿ˜‰
                      Because beside or inside nothing appears! ๐Ÿ˜ฎ
                      pilou look here
                        Thx ๐Ÿ˜‰
                        My problem is now how make a new thing for go to the rail ! ๐Ÿ˜„
                        • deaneauD
                          deaneau
                          Thx ๐Ÿ˜‰
                          what do you mean with new things? locos, cars or what?
                            See the bottom of the previous page! ๐Ÿ˜‰
                            • deaneauD
                              deaneau
                              Here some parts based on the intersections
                              • deaneauD
                                deaneau
                                my suggestion copy a loco in a separate folder and open this in sketchup and look where the wheels must be.
                                  I am not sure that only this placement resolve my little problem ๐Ÿ˜„
                                  As I want input any volume as Loco I had believed that the 7 clicks inputs on this volume were sufficient!
                                  As I had the message "Give a name" (I gave "Bull" I had supposed that all works fine!
                                  But no trace of this file nowhere! ๐Ÿ˜ฒ
                                  Move it on the good altitude of rail don't change nothing!
                                  http://sketchucation.com/forums/download/file.php?id=120825&mode=view/rokbox.jpg
                                  • eneroth3E
                                    eneroth3
                                    At 2:48:04 in this video you can see how rolling stocks are initialized and then optionally saved to the library. Saving to the library is still quite undeveloped and has to be done through the console now but a graphical interface is planned.
                                      II will study that ๐Ÿ˜„
                                      • eneroth3E
                                        eneroth3
                                        Something is wrong with the point you input, otherwise the rolling stock would stand on the track. Also initializing as rolling stock doesn't add it to the library.
                                        • deaneauD
                                          deaneau
                                          i havnยดt try rolling stock. this answer could give the good manual or Eneroth.
                                          i dont know, do you have download the big movie.. Eneroth have build a loco, could be you find the answer there ,too.
                                            You want to say that is just temporary ? Where it is saved ?
                                            Here my volume is named ok ๐Ÿ˜„
                                            But alas when I try to Drive it : This train is not on the rail etc... ๐Ÿ˜ฎ
                                            • 18
                                            • 19
                                            • 4 / 19
