    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.1k Views 41 Watching
    • deaneauD
      deaneau
      @eneroth3 said:
      Hi all.
      I've made a street version of the track now....
      many thanks thats looks good.
      you have pm about streets in berlin
      regards dean
      • deaneauD
        deaneau
        Thanks for the info! โ˜€
        You have made a true gem! ๐Ÿ˜Ž
        Will try the Streets maker as soon as possible! ๐Ÿค“
        Can you show the image of the arborescence of the new Files Folders Streets supposed to be ? ๐Ÿ˜‰
        Because beside or inside nothing appears! ๐Ÿ˜ฎ
        pilou look here
          Thx ๐Ÿ˜‰
          My problem is now how make a new thing for go to the rail ! ๐Ÿ˜„
          • deaneauD
            deaneau
            Thx ๐Ÿ˜‰
            what do you mean with new things? locos, cars or what?
              See the bottom of the previous page! ๐Ÿ˜‰
              • deaneauD
                deaneau
                Here some parts based on the intersections
                • deaneauD
                  deaneau
                  my suggestion copy a loco in a separate folder and open this in sketchup and look where the wheels must be.
                    I am not sure that only this placement resolve my little problem ๐Ÿ˜„
                    As I want input any volume as Loco I had believed that the 7 clicks inputs on this volume were sufficient!
                    As I had the message "Give a name" (I gave "Bull" I had supposed that all works fine!
                    But no trace of this file nowhere! ๐Ÿ˜ฒ
                    Move it on the good altitude of rail don't change nothing!
                    http://sketchucation.com/forums/download/file.php?id=120825&mode=view/rokbox.jpg
                    • eneroth3E
                      eneroth3
                      At 2:48:04 in this video you can see how rolling stocks are initialized and then optionally saved to the library. Saving to the library is still quite undeveloped and has to be done through the console now but a graphical interface is planned.
                      My website: http://julia-christina-eneroth.se/
                        II will study that ๐Ÿ˜„
                        • eneroth3E
                          eneroth3
                          Something is wrong with the point you input, otherwise the rolling stock would stand on the track. Also initializing as rolling stock doesn't add it to the library.
                          • deaneauD
                            deaneau
                            i havnยดt try rolling stock. this answer could give the good manual or Eneroth.
                            i dont know, do you have download the big movie.. Eneroth have build a loco, could be you find the answer there ,too.
                              You want to say that is just temporary ? Where it is saved ?
                              Here my volume is named ok ๐Ÿ˜„
                              But alas when I try to Drive it : This train is not on the rail etc... ๐Ÿ˜ฎ
                              • eneroth3E
                                eneroth3
                                Last mystery : ๐Ÿ’š
                                Just now, how to put this volume in the library ? โ“ โ“ โ“
                                A better and graphical interface is planned (including prompting the user already when initializing the rolling stock). for now you need to do as the documentation (Plugins>Railroad>Documentation) or the video I linked says.
                                  Many Thanks! ๐Ÿ˜„ I will be patient! โ˜€
                                  It's yet now a little true Gem! ๐Ÿ˜Ž
                                  • deaneauD
                                    deaneau
                                    Here some parts for intersections. based on eneroth intersections_2014.06.15_21h28m46s_008_00808.jpgINTERSECTION GB_EU.skp for all friends from GB, too
                                    and here variations with CrossWalk
                                    _2014.06.15_23h29m50s_011_00811.jpgINTERSECTION GB_EU_PED.skp
                                      Bingo!!!! That works fine! โ˜€ โ˜€ โ˜€
                                      The trick was to take the 7 clicks "in diagonal" Front / Bottom, Left / Right for avoid same plane! ๐Ÿ˜Ž
                                      Another thing : Can I group the girl to the existing volume and Drive it? Seems not! ๐Ÿ˜ž
                                      Edit : Bingo again : not group the girl with the volume, but put she "inside" the Volume grouped (in the Menu Window/ Structure! ) ๐Ÿ˜Ž
                                      So you can transport any thing! โ˜€
                                      http://s6.postimg.org/6p9qpviz5/train5.jpg
                                      A funny thing : if you hide thre rails, you can drive any thing like along a path! ๐Ÿ˜Ž
                                      Last mystery : ๐Ÿ’š
                                      • deaneauD
                                        deaneau
                                          Cool roads design! ๐Ÿ˜Ž
                                          Something to know for LightUp : if you put a component "Face me" for transporting on something : animation will works fine in SU but not in LightUp! ๐Ÿ˜ฒ
                                          So put normal components and the animation will work fine also in LightUp! โ˜€
                                          • deaneauD
                                            deaneau
                                            Here a a version with Fences.
                                            i will upload the ready version. the fences have 12 sites (more high poly) tell me when you need lowpoly (5S or 6S),too. than i upload both versions. the fence is without textures, so you can texuring by your self.
                                            • 18
                                            • 19
                                            • 4 / 19
