    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 107.0k Views 41 Watching
      Thx! Cool now! โ˜€
      No sure that streets was for trains?
      • eneroth3E Offline
        eneroth3
        You can initialize cars as rolling stocks to drive them on the roads.
        You can also right click on the streets with the sidewalk in the middle, open their properties and reverse them to put the sidewalk on the side.
        My website: http://julia-christina-eneroth.se/
          For create a new one car or train...
          Can I take any volume as one group ?
          Does this group must be ont the rail or street during the creation?
          Where must be this new on after I give it a name ?
          Because seems nothing is created after the naming! ๐Ÿ˜„
          • eneroth3E Offline
            eneroth3
            It must be standing on a track/street to be driven so it's easiest to initialize it there too. To find the center plane of the street you can draw a temporary edge between the painted lines at the sides of that lane and position the group at its midpoint.
              Ok but about the naming?
              If it's ask a name, that want to say that all points are fully ...so in what folder goes the new one created ?
              Creation was success after the naming but...
              and I see nowhere where is the "Bull" that I had created! ๐Ÿ˜„
                All this new creation can be done in SU Make ?
                A new one must follow all the parts of an existing One?
                A simple box volume can't be work ?
                • deaneauD Offline
                  deaneau
                  @eneroth3 said:
                  Hi all.
                  I've made a street version of the track now....
                  many thanks thats looks good.
                  you have pm about streets in berlin
                  regards dean
                  • deaneauD Offline
                    deaneau
                    Thanks for the info! โ˜€
                    You have made a true gem! ๐Ÿ˜Ž
                    Will try the Streets maker as soon as possible! ๐Ÿค“
                    Can you show the image of the arborescence of the new Files Folders Streets supposed to be ? ๐Ÿ˜‰
                    Because beside or inside nothing appears! ๐Ÿ˜ฎ
                    pilou look here
                      Thx ๐Ÿ˜‰
                      My problem is now how make a new thing for go to the rail ! ๐Ÿ˜„
                      • deaneauD Offline
                        deaneau
                        Thx ๐Ÿ˜‰
                        what do you mean with new things? locos, cars or what?
                          See the bottom of the previous page! ๐Ÿ˜‰
                          • deaneauD Offline
                            deaneau
                            Here some parts based on the intersections
                            • deaneauD Offline
                              deaneau
                              my suggestion copy a loco in a separate folder and open this in sketchup and look where the wheels must be.
                                I am not sure that only this placement resolve my little problem ๐Ÿ˜„
                                As I want input any volume as Loco I had believed that the 7 clicks inputs on this volume were sufficient!
                                As I had the message "Give a name" (I gave "Bull" I had supposed that all works fine!
                                But no trace of this file nowhere! ๐Ÿ˜ฒ
                                Move it on the good altitude of rail don't change nothing!
                                http://sketchucation.com/forums/download/file.php?id=120825&mode=view/rokbox.jpg
                                • eneroth3E Offline
                                  eneroth3
                                  At 2:48:04 in this video you can see how rolling stocks are initialized and then optionally saved to the library. Saving to the library is still quite undeveloped and has to be done through the console now but a graphical interface is planned.
                                    II will study that ๐Ÿ˜„
                                    • eneroth3E Offline
                                      eneroth3
                                      Something is wrong with the point you input, otherwise the rolling stock would stand on the track. Also initializing as rolling stock doesn't add it to the library.
                                      • deaneauD Offline
                                        deaneau
                                        i havnยดt try rolling stock. this answer could give the good manual or Eneroth.
                                        i dont know, do you have download the big movie.. Eneroth have build a loco, could be you find the answer there ,too.
                                          You want to say that is just temporary ? Where it is saved ?
                                          Here my volume is named ok ๐Ÿ˜„
                                          But alas when I try to Drive it : This train is not on the rail etc... ๐Ÿ˜ฎ
                                          • eneroth3E Offline
                                            eneroth3
                                            Last mystery : ๐Ÿ’š
                                            Just now, how to put this volume in the library ? โ“ โ“ โ“
                                            A better and graphical interface is planned (including prompting the user already when initializing the rolling stock). for now you need to do as the documentation (Plugins>Railroad>Documentation) or the video I linked says.
                                            • 18
                                            • 19
                                            • 4 / 19
