    Artisan Experiment
    26 Posts 6 Posters 5.8k Views 6 Watching
    • Bryan KB Offline
      Nothing fancy. Just an experiment to get the hang of it.
      • soloS Offline
        You need an idea what to model? Here is a good model for you to try achieve.
        • Bryan KB Offline
          Do you have a better picture?
          • olisheaO Offline
            olishea
            what is it bryan? artisan is my favourite plugin to have some fun.
            oli
            • Bryan KB Offline
              πŸ˜† It's nothing. Just a free form test.
              I am in fact, in the middle of designing something with it. I just posted this test for the heck of it and to show that I am learning it. It has nothing to do with the model I'm working on.
              However, the thing I am designing is still just one step out my reach so I will fall back to something a little easier.
              There are several good tutorials I will practice with. I'll post those results.
              • olisheaO Offline
                olishea
                Need any help getting it to work?
                oli
                • Bryan KB Offline
                  Thanks for the offer Oli, but I think I just need to go through a few more tutorials. I've already done the ones on the Artisan website and they were very helpful. I've also watched most of the ones on the Tron lightcycle as well as a custom car. I'm going to watch the one on fabric folds and the tuck and pleat furniture. πŸ‘
                  • bazB Offline
                    baz
                    Bryan, have you seen this thread?
                    Lots of great Artisan examples.
                    http://sketchucation.com/forums/viewtopic.php?f=335%26amp;t=42938%26amp;hilit=cotty+artisan
                    • Bryan KB Offline
                      Whoa! Jackpot!
                      Thank you!
                      • bazB Offline
                        baz
                        πŸ‘
                        • bazB Offline
                          baz
                          [attachment=0:2ow4ucct]<!-- ia0 -->Harvey-Probber.jpg<!-- ia0 -->[/attachment:2ow4ucct]
                          Solo, that is the ugliest piece of furniture I think I've ever seen.
                          Worthy of a new thread?
                          • Bryan KB Offline
                            Simple pillow. (I didn't create enough quads... again πŸ˜† )
                            • olisheaO Offline
                              olishea
                              You are getting somewhere! πŸ‘
                              oli
                              • pbacotP Offline
                                You can't have an "Artisan Experiment" thread without showing the proxy and the mesh. Good work--look forward to more!
                                • Bryan KB Offline
                                  Oops. You are right.
                                  No first proxy picture, but easy enough to describe. It was just a box created using the additive Push/Pull. I then used the Artisan Crease tool and excepted the flat surfaces from smoothing while allowing all edges to smooth. Used setting "3" for subdivide.
                                  I then manually depressed areas using the Sculpt tool at random with a -2" radius and very shallow depression.
                                  • xiombargX Offline
                                    xiombarg
                                    If you model a standard loaf of bread with Artisan you will learn most of the basics of the Artisan process.
                                    • Bryan KB Offline
                                      Good idea! Thank you.
                                      • bazB Offline
                                        baz
                                        I'm curious as to what a 'standard' loaf of bread looks like?
                                        Perhaps you could illustrate....
                                        • olisheaO Offline
                                          olishea
                                          Split tin loaf I imagine.
                                          http://darvellandsons.co.uk/wp-content/uploads/2013/01/White-Split-Tin.jpg
                                          oli
                                          • bazB Offline
                                            baz
                                            C'mon Oli, show us the proxy:)
