    Artisan Experiment
    26 Posts 6 Posters 6.3k Views 6 Watching
    • Bryan KB
      @baz said:
      Bryan, have you seen this thread?
      Lots of great Artisan examples.
      404 Not Found
      (sketchucation.com)
      Whoa! Jackpot!
      Thank you!
      • bazB
        baz
        πŸ‘
        • bazB
          baz
          @solo said:
          You need an idea what to model? Here is a good model for you to try achieve.
          [attachment=0:2ow4ucct]<!-- ia0 -->Harvey-Probber.jpg<!-- ia0 -->[/attachment:2ow4ucct]
          Solo, that is the ugliest piece of furniture I think I've ever seen.
          Worthy of a new thread?
          • Bryan KB
            Simple pillow. (I didn't create enough quads... again πŸ˜† )
            • olisheaO
              olishea
              You are getting somewhere! πŸ‘
              oli
              • pbacotP
                You can't have an "Artisan Experiment" thread without showing the proxy and the mesh. Good work--look forward to more!
                • Bryan KB
                  Oops. You are right.
                  No first proxy picture, but easy enough to describe. It was just a box created using the additive Push/Pull. I then used the Artisan Crease tool and excepted the flat surfaces from smoothing while allowing all edges to smooth. Used setting "3" for subdivide.
                  I then manually depressed areas using the Sculpt tool at random with a -2" radius and very shallow depression.
                  • xiombargX
                    xiombarg
                    If you model a standard loaf of bread with Artisan you will learn most of the basics of the Artisan process.
                    • Bryan KB
                      Good idea! Thank you.
                      • bazB
                        baz
                        I'm curious as to what a 'standard' loaf of bread looks like?
                        Perhaps you could illustrate....
                        • olisheaO
                          olishea
                          Split tin loaf I imagine.
                          http://darvellandsons.co.uk/wp-content/uploads/2013/01/White-Split-Tin.jpg
                          oli
                          • bazB
                            baz
                            C'mon Oli, show us the proxy:)
                            • pbacotP
                              You could use TIG's slicer on that. Hmmm. I think it's time for toast.
                              • olisheaO
                                olishea
                                I wish I could model as well as that photograph haha
                                oli
                                • xiombargX
                                  xiombarg
                                  I had a teacher in college who had us model a loaf of bread as a 3D assignment to teach us how to use the smoothing and creasing functions in Maya (same principles as Artisan). Unfortunately I didn't keep the model. It's harder than it might sound. It's a good exercise as it usually forces you to explore different topologies in order to achieve an ideal result. In class we all had to print up our topology before and after smoothing and pin them up on the bulletin board so we could see which models worked better than others.
                                  It seemed like a boring assignment at first but I learned a lot from it.
                                  • Bryan KB
                                    More experimenting.
                                    • xiombargX
                                      xiombarg
                                      I can't use Artisan without Vertex Tools as well. Artisan by itself without the gizmo and VT's "make planar" function is only half as good.
                                      • Bryan KB
                                        I've temporarily lost the momentum on this. I'm going to do some conventional models and then come back to Artisan.
                                        I wasn't real pleased with the park model either. So much so I took it down from my website.
                                        The beer goggles on the other hand... πŸ˜†
