    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • KrisidiousK
      Krisidious
      actually that did produce a face with a material in the section.
      is a "solid" required for sectioning?
      here's the log file.
      RichSection_log.txt
      By: Kristoff Rand
      • P
        pgarmyn
        is a "solid" required for sectioning? ...
        As explained in the first post :
        Elements don't have to be solid, but only closed sections will generate section-materials.
        ( and solids alwys produce closed sections)
        • KrisidiousK
          Krisidious
          This is what I get on a simple structure or complex for that matter.
          By: Kristoff Rand
          • C
            caronte01
            HI Kristoff,
            Can you post that model?
            S
            • KrisidiousK
              Krisidious
              sure...
              0000.skp
              By: Kristoff Rand
              • C
                caronte01
                In your rs settings, section was off (the first item on the list). Also, some of the groups/components in your model were non solid.
                From my experience, rs works better with solids. I use tt's solid inspector a lot. RS works well with nested solids, and even with multi mesh solids (something native su solid tools has problems with).
                Things to avoid:
                Ungrouped geometry.
                Dividing lines on coplanar faces, except when they are used to separate different materials.
                Santiago
                0000.skp
                • KrisidiousK
                  Krisidious
                  Thanks for the help Santiago, I did have "Yes" selected when I created the section. as for the solids and such no.
                  By: Kristoff Rand
                  • C
                    caronte01
                    Hi Piet,
                    Some screenshots of the dialog boxes, win vs. mac. I´ve highlighted in red the clipped text. I tried shortening some of those lines, but the dialog would resize, and clip other text. It also happens in the english translation...
                    Config
                    Settings
                    Legend
                    del
                    • P
                      pgarmyn
                      Hi Santiago
                      Good job ❗
                      I will report this to the sketchup team and the community!
                      See : http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57642%26amp;p=524309#p524309
                      Thanks !
                      • C
                        caronte01
                        Hi Piet,
                        Three small things.
                        Can default settings be saved, at least per session? I´m creating several rs on a model, I´m changing some of the settings from the default (rs profile lines to yes, so I can snap to the rs in layout, and projections to off) I have to do this every time I create an rs. Seems simple, but if I forget, and leave projections on, it takes forever to create an rs.
                        It would be great to have esc abort the rs creation/update. Right now, the only way I´ve found is to either leave rs running, or force quit sketchup....
                        In the settings dialog, move RSName to the top... Right now it is not easily found, down at the bottom.
                        Cheers,
                        Santiago
                        • P
                          pgarmyn
                          Hi Santiago
                          • about settings saved: i planned to propose the last used settings in creation, except name, section on/off and projection on/off, but i can limit the exception to the name...
                          • escape : very usefull (was planned), but more difficult : Have to rewrite a lot. Will have to find the time.
                          • name on the top : ok
                            Thanks for the suggestions
                          • C
                            caronte01
                            • C
                              caronte01
                              Hi Piet,
                              Do you have a new version available? The current demo version expired yesterday....
                              santiago
                              • P
                                pgarmyn
                                @caronte01 said:
                                Hi Piet,
                                santiago
                                Ok, it will be there in 2 or 3 hours
                                • P
                                  pgarmyn
                                  UPDATED : VERSION 0.4.4 is in the PLUGINSTORE
                                  • P
                                    pgarmyn
                                    @bimbachi @diegob
                                    It must be a MAC related problem, you are both running on MAC ?
                                    Any other Mac users with problems ❓ ❓ ❓ ❓ ❓
                                    I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
                                    Can you test the following : disable all the other plugins ❓
                                    If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works ❓
                                    Thanks in advance.
                                    file deleted
                                    • C
                                      caronte01
                                      Thanks Piet!!!!
                                      Cheers
                                      Santiago
                                      • B
                                        bimbachi
                                        Did you abandoned mac problems?
                                        • P
                                          pgarmyn
                                          Caronte01 reported that the standard input box from the sketchup-API isn't working properly on mac.
                                          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=210#p524280
                                          Actually i don't have time to work on it.
                                          Did you find other problems?
                                          • C
                                            caronte01
                                            The new version looks great!
                                            Thanks,
                                            Santiago
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 19
                                            • 20
                                            • 12 / 20
