    Newbie problem...
    7 Posts 6 Posters 264 Views 6 Watching
    • F Offline
      fred5008
      hi
      i am a french beginner in sketchup and i need something for my job:
      • i hope you can see this picture, i would like to hide "the black mesh" but if i put "hide" all the piece will be hidden... so i don't know how to do it
      thanks to help me.
      https://drive.google.com/?tab=mo&authuser=0#my-drive
      • massimoM Offline
        massimo Moderator
        Hi fred, your image is not visible. Please use the "upload attachment" feature in order to post images directly on the forum.
        About your problem, maybe what you want to hide is some geometry placed in a nested group/component? If so you need to open (double click) the group/component and select only what you want to hide.
        • cottyC Offline
          cotty
          I don't see your image, but maybe you search for "view -> hidden geometry"?
          my SketchUp gallery
            pcmoor
            "Soften Edges" is probably the tool you need, access either through window or context right click on selection
              Et il y a aussi une section française 😉
              Menu Settings (en haut à gauche)
              Usergroups
              Français
              Bouton Submit (en bas à droite)
              • F Offline
                fred5008
                thanks for yours answers
                i think i found:
                • right click
                • information about the entity
                • hidden check
                  It's hard to tell if that's the right solution since we still can't see your image but if you're happy with it, that's cool.
