    [Plugin] SketchUcation Tools 2.6
    212 Posts 58 Posters 145.9k Views 58 Watching
    • F Offline
      FritsBee
      I was a SU 2013 user. And I didn't want to go to SU2014 because the plugins works different.
      I made the step and went to SU2014 but after installing SketchUcation 2.6
      It installs whell but after restart SU I get errors.
      These are the errors:
      Error: #<LoadError: cannot load such file -- open-uri>
      c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in require' c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in module:SCFapi'
      c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:22:in <main>' C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in eval'
      C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in load' C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in block in <top (required)>'
      C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in each' C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in <top (required)>'
      E:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' E:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
      C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in register_extension' C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in module:SCF'
      C:/Users/Gebruiker/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:16:in `<top (required)>'
      What did I do wrong?
        @Frits
        The answer was a few posts earlier http://sketchucation.com/forums/viewtopic.php?p=524358%26amp;f=10#p524358
        Please read that... 🤓
        I suspect you have the same issue...
        If you start SketchUp from the SketchUp.exe rather than a SKP on another drive you should not experience the error.
        Adding the special 'fix' rb file into the Tools folder should resolve the issue until an update of SketchUp is released... 😒
          paddyclown
          Hi all, I have an odd anomaly...
          When I click on the button for sketchucation plugin store (i have v 2.6.0) I get the error
          "Navigation vers la page Web annulée
          Essayez la chose suivante :
          Actualisez la page. "
          (navigation to webpage cancelled, try following: reload page) - which I try to no avail...
          I went into the java config tool on my PC and tried activating/deactivating stuff & nothing doing, I also checked that sketchucation was authorised in the noscript plugin for firefox...
          very odd... it used to work
          thanks if anyone has a bright idea
            On a PC all web-dialogs use IE, irrespective of your preferred browser - like Firefox.
            Check your IE Internet Options settings...
            Allow javascript etc...
            Has your system or IE been updated recently ?
              paddyclown
              TIG yes, thanks; tried everything I can think of in IE (it is fully up to date as is my OS - I always let windows update do it's thing) I reset the security parameters in IE and checked in the JAVA config & all seems activated as it always was 😞
              The worst is it works on another computer running windows7 (which I hate) hého, maybe I should reinstall IE if I have some time to waste...
              It would be cool if in SU we could tell it to use Firefox or whatever as the browser....
              thanks anyway
              best,
                Gábor
                Might this explain the cause?
                http://answers.microsoft.com/en-us/ie/forum/ie11-iewindows8_1/navigation-to-the-webpage-was-cancelled-message/a9d1ea43-6f53-4f59-94b6-247eb3e757f1
                  paddyclown
                  Just to let you know I fixed the problem and here's how:
                  I reset IE to the original install settings
                  & I got rid of the access manager (deactivated it)
                  cf attached images (sorry my system is in French)
                  anyway, thanks to all for your time/help
                  best,
                    Gábor
                    👍 Thank you for sharing it.
                      bimbachi
                      hello all,
                      I have some questions concerning "My setup" part of plugin :
                      1./ I have 2 (two) "Bundles" for my one computer, neither has all plugins/extensions.
                      How can I manage them, add together, update to include my all set of plugins/extensions? (I want recreate same for my new PC setup)
                      2,/ What is difference between "downloads" and "instals", what is for?
                      regards
                        Gábor
                        In the Bundles only those plugins are included what were obtained from and can be found at the SketchUcation pluginstore.
                        "Downloads" are those plugins what you've ever downloaded from the PluginStore. "Instals" is a subset of the "Downloads" what contains the list of those plugins what are still installed on your given SketchUp instance.
                          bimbachi
                          Gábor,
                          thank you.
                          @gábor said:
                            kellenraid
                            I have downloaded SU Tools. I believe this to be true because I have the different colored cubes on the toolbar. I am trying, and have been for a month, to download FredoScale. After doing what the tutorial shows, and using SU2014, nothing happens. The program works, but FredoScale does not come up. Could it be that I need to sign up for a paid subscription? Pretty much I am holding on my design until I can somehow get FredoScale. I am willing to pay for any help.
                              FredoScale [and his other Plugins] need FredoLib installing too...
                              See its guidance notes...
                              When it's installed restart SketchUp.
                              Check if there's a Preferences > Extensions to load - if so activate it.
                              Also its Toolbar might then need activating...
                                bimbachi
                                Maybe you can help me?
                                Is there any way to reset sketchucation store plug ?
                                I dont recive antmore update warnings!?
                                Regards
                                • H Offline
                                  hebron
                                  Is the SketchUcation plugin working on SU2014 ?
                                    Yes. What makes you think it might not be ?
                                      @bimbachi said:
                                      Can you explain what you mean ?
                                      The 'Update' notifications are set against your User ID and your current computer, SketchUp version and its installed Plugins.
                                      The Bundles function lets you sync across versions or computers.
                                      What is it you want to do ?
                                        bimbachi
                                        I do not have any more info about plugins to update,
                                        even that I can see on web existance of updated versions.
                                        @tig said:
                                        @bimbachi said:
                                          Have you changed your User-name on SketchUcation - or perhaps have more than one membership ?
                                          Have you changed your computer [or changed its name] ?
                                          Are you now using a new SketchUp version ?
                                            sectionaa
                                            Sorry to use this post, but could not find a more relevant topic.
                                            New install of SU Pro 2014. New install of SketchUcation Tools 2.6 (many thanks) in new Plugins folder in SU programme directory (E:).
                                            Also installed Find My Plugins Folder (autoinstall), and I have copied that file into both locations). But, contrary to what it says on the tin it does not put an extra menu item to open location of plugins folder. Is it something I am doing wrong? This is related problem to me trying to get all plugins into SU programme folder, not on C:\Users etc. I dont want them there.
                                            Does your reply below solve my problem(s)?
                                            Many thanks.
                                            @tig said:
                                            Did you install SketchUp v2014 on the main system-drive [C: ] or is it on another drive-letter ?
                                            There is known bug in v2014 M0 where this configuration of file locations and usage can stop its Ruby2.0 loading properly, and then you can get errors as a partial Ruby can't parse some strings or find vital ruby methods...
                                            Please post the results of the following in the Ruby Console for v2014...
                                            ` Sketchup.find_support_file('Plugins')
                                            Sketchup.find_support_file('Tools')
                                            Sketchup.find_support_file('SketchUp.exe')
                                            $".grep(/gems/)`
                                            And also a file-path for one of the SKPs that is showing this issue...
                                            I don't think it's directly related to our toolset per se, but rather your configuration...
                                            But we need to get to the bottom of this... 😕
                                            • 11
                                            • 9 / 11
