    New 3d Machines Unveilings & Pens, Scanners, Elements Idems
    993 Posts 6 Posters 343.6k Views 6 Watching
    • xiombargX Offline
      xiombarg
      I'm also continually surprised by Makerbots crappy specs. The layer resolution on this Mini is 200 microns! That stinks. I also don't think any of their machines are self leveling. Ugh.
      • dukejazzD Offline
        dukejazz
        "I'm surprised at how many FDM printers are doing the same thing as everybody else without anything new or innovative, but I guess this at least helps push the industry forward with competitive pricing." -by xiombarg » Today, 8:29 pm
        Expiration of key patents is the cause -dukejazz
        ( Highlight web title, right click, click search engine and then goto web site )
        3D printing will explode in 2014, thanks to the expiration of key patents |By Christopher Mims
        "It's great to see so many players getting into stereolithography. I'm interested to see the rap sheet on the Autodesk printer." -by xiombarg » Today, 8:29 pm
        Autodesk to launch its own 3D printer this year! | by Mike Lucey
        http://sketchucation.com/forums/viewtopic.php?f=388%26amp;t=57727
        Autodesk Questions and Answers | images.autodesk.com
        Autodesk announced its consumer 3D printer at the MakerCon conference in California, along with an open-software 3D printing platform called 'Spark'.
        Autodesk's new printer uses Stereolithography (SLA) technology to create objects. SLA 3D printer hardens liquid plastic (photopolymer) with an ultraviolet (UV) layer by layer and converts liquid plastic into solid objects. The process can deliver smoother and more complex objects than desktop FDM 3D printers.
        The price is not revealed, but Autodesk CEO Carl Bass said it would likely be in the $5,000 range. Both the printer and the platform will be available "later this year," said the company.
        "Hopefully we will continue to see prices come down. I would love to see a good SLA printer for around $1500." -by xiombarg » Today, 8:29 pm
        Not SLA For $1500
        you can buy a nice FDM DIY kit.
        DIY kit - 3ders.org - price compare 3D printers | 3ders.org/
        Not For $1500
        3D Systems announces new $4,900 micro-SLA 3D printer | 3ders.org
        Dec.5, 2013
        http://www.3ders.org/images/projet-1200-3d-printer-parts_0.jpg
        3ders.org - Farsoon China unveils new 402 SLS 3D printer with fastest scan speed | 3ders.org
        http://www.3ders.org/images2014/farsoon-402-3d-printer-1.jpg
        Specs:
        Effective building volume: 400mm x 400mm x 450mm
        Building speed: 17mm/hour
        Layer thickness: 0.08mm~0.15mm
        Laser type: CO2, 100 W
        Galvo scanning system: dynamic focusing high-accuracy Galvo scanning system (CSI)
        Laser power control system: Digital signal (high precision and good anti-jamming)
        Scan speed during building: 12.7m/s
        Powder feeding mode: Two-way powder feed system with a single feed cartridge
        Printer size: 2660 x 1600 x 2010 mm
        Power Supply: 380VAC,50/60Hz,15KVA,3-phase
        Software: Manual and automatic control mode; Online real-time build parameters modification; Three-dimensional Visualization; Diagnostic function.
        no price listed here.
        I will post all new SLA & Autodesk printer info here bekow as I see them here for you -dukejazz
        $3299
        Kudo3D Titan 1 high performance DLP SLA 3D printer | diy3dprinting.blogspot.com
        http://4.bp.blogspot.com/-XxSMhzwzDD0/U3j40l9J_WI/AAAAAAAAEJ0/6LrRcQ63W7M/s1600/kudo3d_titan_SLA_DLP_3d+printer+1.png
        Kudo3D Titan 1 key features:
        •Stereolithography (SLA) printing technology: Bottom-up SLA configuration
        •Patent Pending PSP (Passive Self-Peeling) technology:
        •Flexible resin container (VAT) design
        •Enhanced printing performance and quality
        •Simplified printer structure
        •Superior reliability: modularized with heavy duty high quality components
        •Adjustable DLP to optimize printing performance
        •Compatible to all SLA photoresins sensitive to 400nm light
        Be real the price range of SLA is $3299 - $1,000,000 US dallors
        No SLA For $1500
        "I'm also continually surprised by Makerbots crappy specs. The layer resolution on this Mini is 200 microns! That stinks. I also don't think any of their machines are self leveling. Ugh." -xiombarg » Today, 8:29 pm
        I see you like SLA over FDM
        FDM easiier and ceaper to use.
        Makerbots Mini has some great specs for a FDM Technology
        Here are the key specs of the Replicator Mini:
        •Printing Technology: FDM
        •Build Volume: 10 L x 10 W x 12.5 H cm (3.9 L x 3.9 W x 4.9 H in)
        •Layer Resolution: 200 Microns
        •Filament Diameter: 1.75 mm
        •Nozzle Diameter: 0.4 mm
        •Camera Resolution: 320x240 pixels
        •File Types Supported: STL, OBJ, Thing, MakerBot
        •Retailing at $1,375
        The layer resolution on this Mini it made to be use by home software that only give .0002 or 200 microns! accerccy -dukejazz
        patents are still on the self leveling machines -dukejazz
        and they look pricy to make
        I saw one that you can make
        Build Platform Levelling - Makerbot 3D Printers Wiki | makerbot.wikia.com/
        Automated Bed Leveling For 3D Printers Is Now Solved | April 15, 2014 By Brian Benchoff
        Ask Hackaday: Auto Bed Leveling And High Temperature Force Sensitive Resistors | March 19, 2014 By Brian Benchoff
        • dukejazzD Offline
          dukejazz
          New 3d Machine Unveilings
          3D Printing: Autodesk Bids To Become The 'Android' of the 3D World | gilcommunity.com
          EPO - Finalist Non-European countries - 3D printing (stereolithography Charles W. Hull | vieuws.eu
          Cube 3D printer - Home 3D printer to turn your ideas into real objects - Cubify | cubify.com
          https://dud5umgikjidx.cloudfront.net/resources/images/cube/bkg_cube_printingandyou_3.jpg
          • dukejazzD Offline
            dukejazz
            I look at SLA printer as a (level 2) printer, high detail prints HD, fast, high power, aim for the business world
            I look at FDM printer as a (level 1) printer, low detail prints LD, low power, aim for the home users
            A Pro users would have a uses for both one for prof and one for finial
            A new design type of FDM printer is coming that can switch gears to a smaller gauge filament
            A Microscope-Inspired Extruder Design Could Add Fine Detail To 3D Prints | TechCrunch
            "The various head sizes will allow users to print large gauge plastic for the structural parts of a 3D print and thinner filament for the finer parts. This improves the resolution of the outside surface while improving stability for the inside parts. When the head spins it can cut off the hot filament for a moment and then extrude it after it heats up. This could add a little time to the printing process, but it’s definitely a cool idea."
            http://tctechcrunch2011.files.wordpress.com/2014/05/crownextruder-4nozzles.jpg?w=615
            "Why is this important? Because this sort of printing, called fused deposition modeling, though expanding, is highly limited in terms of resolution and speed. There are far better ways to print out there, but FDM is the cheapest and this could both save time and filament as it extrudes fat lines where things can be messy and fine lines when high-resolution detail is needed."
            • xiombargX Offline
              xiombarg
              Just so people have an idea of what the difference looks like when speaking of layer resolution, here are a couple of examples.
              Layer resolution of 200 microns, or .2mm
              This is the current minimum layer resolution of the Makerbot mini and older FDM printers.
              http://i9.photobucket.com/albums/a51/xiombarg001/200u_zps2e33427f.jpg
              Layer resolution of 100 microns, or .1mm
              Keep in mind that this picture example is not as magnified as most of the other pictures, so it might look smoother than some of the other examples.
              Many FDM printers have this resolution including the higher end Makerbot models.
              http://i9.photobucket.com/albums/a51/xiombarg001/bb412ff2d20a2e4a02da6e92fee345db_large_zps84057751.jpg
              Layer resolution of 50 microns, or .05mm
              This is the minimum resolution of many older SLA printers and newer FDM printers.
              http://i9.photobucket.com/albums/a51/xiombarg001/Buddha_50mu_pencil_cu_2000_zps69adde82.jpg
              http://i9.photobucket.com/albums/a51/xiombarg001/Buddha_50mu_pencil_2000-300x199_zps2329dcc9.jpg
              Layer resolution of 25 microns, or .025mm
              This is the minimum resolution of the Form1 and many SLA printers (usually between 25-40 micron minimum). Some of the newer FDM printers such as the Cel-Robox have also announced such resolution capability by controlling the resin flow by valves instead of merely controlling the feed rate of the filament as it passes through the nozzle, hence getting a more refined stream.
              http://i9.photobucket.com/albums/a51/xiombarg001/firstprint_grande_zpsfcf2b4d7.jpg
              • dukejazzD Offline
                dukejazz
                In the News 3d Machine
                Kudo3D Launching Kickstarter Campaign for Titan 1 DLP 3D Printer | 3dprintinginsider.com
                http://3dprintinginsider.com/files/2014/05/3d-rings1.jpg
                3D Printers for Sale | 3D Printing Color | 3dprintingcolor.com
                "Setting The Standard
                In Desktop 3D Printing,
                Desktop 3D Scanning, and 3D Entertainment"
                Low Cost 3D Printer - RepRapPro Ormerod » DesignSpark - RS Components | rs-online.com
                http://5af5e3de5795a966dd90-e9792bbf34570cde028937f7b1897875.r53.cf3.rackcdn.com/uploads/images/537dd4a55bb44833a9fc11ae0ab30198
                Sculptify's FLEX: Pellets Instead of Filament - 3D Printing Industry | 3dprintingindustry.com
                http://cdn.3dprintingindustry.com/wp-content/uploads/2014/05/pellet-extrusion-process.jpg
                • dukejazzD Offline
                  dukejazz
                  In the News for 3d Machine
                  Amazon.com: UP! Mini 3D Desktop Printer, 100-240V AC, 50-60Hz, 200W: Electronics | amazon.com
                  http://hothardware.com/articleimages/Item1946/small_up-mini-front.jpg
                  Autodesk CEO: '3D printing has been way overhyped' • The Channel | channelregister.co.uk
                  The Autodesk 3D Printer: A Calculated Bet | Forbes
                  Google '3D Printing' and You Might Find an Apple | beforeitsnews.com
                  3ders.org - Sneak peak of Robo 3D R2 printer, Titan electronics board & new file | 3ders.org
                  http://www.3ders.org/images2014/robo3d-r2-3d-printer-1.jpg
                  D&H to bring RoBo3D 3-D printers to US SMBs | eChannelLine
                  Meg Whitman Reveals That Hewlett Packard Will Only Focus on 'Business 3D Printing' | 3DPrint.com
                  HP's (NYSE: HPQ) Premature Release Leads to Jump in Stock Pricing | Financialbuzz.com
                  New Money-Saving 3D Printing Consumables by Canada Powder | PR.com (press release)
                  New Money-Saving 3D Printing Consumables by Canada Powder | IT News Online
                    Amazing how speed this domain is evolving! 😲
                    • dukejazzD Offline
                      dukejazz
                      3D Printer ( Prototype ) By Bandit-ed - Thingiverse | Thingiverse - Newest Things
                      Http;//thingiverse-production.s3.amazonaws.com/renders/40/27/94/5c/0b/foto_1_preview_featured.jpg
                      Isis One 3D Printer - Isis3d | Isis3d.net
                      Da Vinci 1.0 3D Printer Complete Review Video | 3Dprintboard.com
                      Creator Wood Case 3D Printer: Amazon.com: Industrial & Scientific | Amazon.com
                      • dukejazzD Offline
                        dukejazz
                        3D Print Your Next House – BetAbram Plans to Sell 3D House Printers for 12000€ | 3DPrint.com
                        http://3dprint.com/wp-content/uploads/2014/05/betabram1-1024x682.jpg
                        De Anza prepares for launch of 3D printer and scanner | La Voz Weekly
                        LittleDLPer: Open Source DLP 3D Resin Printer, Coming Soon to Kickstarter | 3DPrint.com
                        http://3dprint.com/wp-content/uploads/2014/05/littledlper-side.jpg
                        • dukejazzD Offline
                          dukejazz
                          3ders.org - Visualize your prototypes before 3D printing them with CastAR glasses | 3ders.org
                          FlexTrunk - Flexible 5-Axis Machining and 3D Printing Shaft - Cable Actuated Flexure | blogspot.com
                          http://3.bp.blogspot.com/-UbJeLJAk30s/U4DBdk9ZyDI/AAAAAAAAEqo/UY_lXExTB7Y/s1600/DSC00818.JPG
                          A 3D Printer for the Rest of Us: New Matter Builds $199 Device | Mashable
                          New 3D printing tech in works | The Tribune-Democrat
                          Cloudio2go Iceman 3D Printer Launches Crowdfunding Campaign on Indiegogo | 3DPrint.com
                          http://3dprint.com/wp-content/uploads/2014/05/iceman-1.png
                          More desktop 3D Printing from Bristol | Personalize
                          • dukejazzD Offline
                            dukejazz
                            3D Systems to Release Cube3 and CubePro 3D Printers | Desktop Engineering
                            D3D Kickstart Autolift: Retractable Hot Ends for High Performance | 3DPrint.com
                            Cambridge Company Unveils 3D Printed "Fruit" | Security - Slashdot
                            RCGroups.com 3D Printing with the ROBO 3D R1 | RCGroups.com
                            http://static.rcgroups.net/forums/attachments/5/0/5/8/4/7/t6800686-63-thumb-20140425_195109-1.jpg?d=1401172367
                            • dukejazzD Offline
                              dukejazz
                              World's Cheapest 3D Printer Moves Forward | La3-d
                              Meet New Matter: A Sub-$300 3D Printer And Design Marketplace So Easy A Caveman | Pandodaily
                              Scribd Objet 1000 3D Printer | Scribd
                              http://htmlimg1.scribdassets.com/1emr25c2v43teu02/images/1-9a7b333d65.jpg
                              • dukejazzD Offline
                                dukejazz
                                Pancakebot: this drawbot builds objects from batter #3dxfood | Adafruit industries blog · matt
                                Kickstarter Titan 1 | Kickstarter
                                New matter partners with frog design and launches desktop 3d printer for under two-hundred ... | Shapeways blog on 3d printing news & innovation
                                http://www.shapeways.com/blog/uploads/New-Matter-Hero.jpg
                                New matter 3d printing ecoystem | Frog design
                                German startup launches 3d printing pen & $649 iceman 3d printer on indiegogo | 3Ders.Org
                                Autodesk Takes 3D Printing Open Source | Automation World
                                • dukejazzD Offline
                                  dukejazz
                                  New 3d Machine Unveilings & Other Idems
                                  Autodesk announces new open source 3D Printer | 3DPrinterPrices.net · Andy
                                  New Chinese 3D Printer can Print Objects the Size of Cars in Full Color | 3dprintboard.com
                                  Cloudio2go Iceman3D Desktop 3D Printer | 3D Printer World
                                  I've found my 3D printer | EIT ICT Labs
                                  http://www.eitictlabs.eu/uploads/pics/The-Micro.jpg
                                  The MOD-t 3D Printer | fabbaloo.com
                                  New Matter MOD-t 3D printer hits Indiegogo for $149 | TweakTown
                                  World's Cheapest 3D Printer On IndieGogo for $149 | Tom's Guide
                                  You Can Now Get a 3D Printer for Under $200 | Nextgov
                                  New Matter 3D Printer MOD-t Launches on Indiegogo | The Voice of 3D Printing
                                  • dukejazzD Offline
                                    dukejazz
                                    Local 3D firm develops printer-based curriculum | Indianapolis Business Journal
                                    New superfast Cloudio2go Iceman 3DDesktop Printer,Aluminium case,WiFi | Indiegogo
                                    https://images.indiegogo.com/medias/1416467/primary_pictures/full/20140526114210-indie2front.png?1401129735
                                    CubePro vs. Ultimaker 2 | Reddit
                                    Taulman 618 Nylon 3D Printing Filament | Printed Solid
                                    15-year-old boy to build low-cost 3D printer in India | digit.in
                                    Deltaprintr: A new affordable 3D printer developed by a US college | digit.in
                                    How This French 3-D Printing Company Differentiates Itself From the Competition | Motley Fool
                                    French Man Has Developed a 3D Metal Printer for Just 600€: Capable of printing. | 3DPrint.com
                                    Automated Home Manufacturing Combining 3D Printing With Robotics | Hackaday · James Hobson
                                    Paper 3D printing | 3D Printing Today
                                    • dukejazzD Offline
                                      dukejazz
                                      Virginia Tech introducing latest 3D printing vending machine DreamVendor 2 | 3Ders.org
                                      DYNAMISM ANNOUNCES THE LAUNCH OF THE ULTIMAKER 2, THE NEWEST TECHNOLOGY ... | GISuser.com (press release)
                                      Stratasys Dimension 1200es ABS Prototype 3D Printer | ENGINEERING.com
                                      MakerBot Opens First Mini-retail Offering in New York's B&H SuperStore | 3DPrint.com
                                      Dream Vendor: Interactive 3D Printing Machine | Gadgetify.com
                                      DreamVendor's 3D Printing Kiosks to be Available in the Near Future | The Voice of 3D Printing
                                      STRATASYS Fortus 400mc Barcelona 3D printed UAV | DIY Drones
                                      Isis3D Announces Improved Isis One | 3D Printer World
                                      http://www.3dprinterworld.com/sites/speh/files/images/isis/isis_one_dual_extruder_printer.jpg
                                      The Titan 1 3D Printer | fabbaloo.com
                                      WIP
                                      • dukejazzD Offline
                                        dukejazz
                                        New Matter aims to make 3D printing more accessible with the MOD-t | 3dprintingplan.com
                                        The MakrToolbox Mk1 – Inexpensive 3D Printer Kit | 3D Printer World
                                        https://s3.amazonaws.com/ksr/assets/002/026/481/1f96065d5d69a98427a2f4bb2ae2ad4f_large.jpg?1400450756
                                        Klic-N-Print 3D printer | KNK USA
                                        Combining 3D Printing with Robtic Arms | 3D Printing Forum - 3D Print Board
                                        Affordable precision 3D printing for pros | kurzweilai.net
                                        Structured Polymers Raises $1.2 million to Expand 3D Printing Materials Market | 3D Printing Forum - 3D Print Board
                                        3D Printed Earbuds Compact | Instructables
                                        This Titan 1 3D Printer Can Make Towering Objects in Half the Time | Inhabitat
                                        Creating a 3D printer for under $100 | Bits & Pieces from the Embedded Design World - WordPress.com
                                        • dukejazzD Offline
                                          dukejazz
                                          New SLA 3D Printer Kickstarter Campaign | Mold3D
                                          French Man Developed 3D Metal Printer for Just 600 | freerepublic.com
                                          http://3dprint.com/wp-content/uploads/2014/06/strong-inactive.jpg
                                          Botfeeder 3d Printer Filament 1st Year Anniversary | ez-robot.com
                                          eirdest Things We'd Want To Make With A 3D Printer | 93.1 Jack FM · Nadia Noir
                                          Selectism Printing Things | Selectism · Lena Dystant
                                          • dukejazzD Offline
                                            dukejazz
                                            Turning A Laser Cutter Into A 3D Printer With OpenSLS | Hackaday · Brian Benchoff
                                            Up close with Zeus, the first consumer all-in-one 3D printer, scanner and fax | Gizmag
                                            XYZPrinting's da Vinci 1.0 AiO and 2.1 AiO ALL-IN-ONE 3d Printers & Scanners Will Be | 3DPrint.com
                                            XYZprinting launch two new printers with in-built 3D Scanning | Personalize
                                            LulzBot TAZ 4 3D Printer Now Available For $2195 (video) | Geeky gadgets
                                            http://www.geeky-gadgets.com/wp-content/uploads/2014/06/LulzBot-TAZ-4-3D-Printer.jpg
                                            Looking Glass Hologram Volumetric Printing Service Hits Kickstarter (video) | Geeky gadgets
                                            Stratasys launches multi-material 3D printer | The Star Online
                                            OpenSLS – An Open Source Project Creates a Sub-$15K Selective Laser Sintering r | 3DPrint.com
                                            Tinkerine launches its own line of biodegradable PLA 3D printing filament | Biobased Digest
                                            • 49
                                            • 50
                                            • 1 / 50
