    New 3d Machines Unveilings & Pens, Scanners, Elements Idems
    993 Posts 6 Posters 660.4k Views 6 Watching
    • dukejazzD
      dukejazz
      "I'm surprised at how many FDM printers are doing the same thing as everybody else without anything new or innovative, but I guess this at least helps push the industry forward with competitive pricing." -by xiombarg » Today, 8:29 pm
      Expiration of key patents is the cause -dukejazz
      ( Highlight web title, right click, click search engine and then goto web site )
      3D printing will explode in 2014, thanks to the expiration of key patents |By Christopher Mims
      "It's great to see so many players getting into stereolithography. I'm interested to see the rap sheet on the Autodesk printer." -by xiombarg » Today, 8:29 pm
      Autodesk to launch its own 3D printer this year! | by Mike Lucey
      http://sketchucation.com/forums/viewtopic.php?f=388%26amp;t=57727
      Autodesk Questions and Answers | images.autodesk.com
      Autodesk announced its consumer 3D printer at the MakerCon conference in California, along with an open-software 3D printing platform called 'Spark'.
      Autodesk's new printer uses Stereolithography (SLA) technology to create objects. SLA 3D printer hardens liquid plastic (photopolymer) with an ultraviolet (UV) layer by layer and converts liquid plastic into solid objects. The process can deliver smoother and more complex objects than desktop FDM 3D printers.
      The price is not revealed, but Autodesk CEO Carl Bass said it would likely be in the $5,000 range. Both the printer and the platform will be available "later this year," said the company.
      "Hopefully we will continue to see prices come down. I would love to see a good SLA printer for around $1500." -by xiombarg » Today, 8:29 pm
      Not SLA For $1500
      you can buy a nice FDM DIY kit.
      DIY kit - 3ders.org - price compare 3D printers | 3ders.org/
      Not For $1500
      3D Systems announces new $4,900 micro-SLA 3D printer | 3ders.org
      Dec.5, 2013
      http://www.3ders.org/images/projet-1200-3d-printer-parts_0.jpg
      3ders.org - Farsoon China unveils new 402 SLS 3D printer with fastest scan speed | 3ders.org
      http://www.3ders.org/images2014/farsoon-402-3d-printer-1.jpg
      Specs:
      Effective building volume: 400mm x 400mm x 450mm
      Building speed: 17mm/hour
      Layer thickness: 0.08mm~0.15mm
      Laser type: CO2, 100 W
      Galvo scanning system: dynamic focusing high-accuracy Galvo scanning system (CSI)
      Laser power control system: Digital signal (high precision and good anti-jamming)
      Scan speed during building: 12.7m/s
      Powder feeding mode: Two-way powder feed system with a single feed cartridge
      Printer size: 2660 x 1600 x 2010 mm
      Power Supply: 380VAC,50/60Hz,15KVA,3-phase
      Software: Manual and automatic control mode; Online real-time build parameters modification; Three-dimensional Visualization; Diagnostic function.
      no price listed here.
      I will post all new SLA & Autodesk printer info here bekow as I see them here for you -dukejazz
      $3299
      Kudo3D Titan 1 high performance DLP SLA 3D printer | diy3dprinting.blogspot.com
      http://4.bp.blogspot.com/-XxSMhzwzDD0/U3j40l9J_WI/AAAAAAAAEJ0/6LrRcQ63W7M/s1600/kudo3d_titan_SLA_DLP_3d+printer+1.png
      Kudo3D Titan 1 key features:
      •Stereolithography (SLA) printing technology: Bottom-up SLA configuration
      •Patent Pending PSP (Passive Self-Peeling) technology:
      •Flexible resin container (VAT) design
      •Enhanced printing performance and quality
      •Simplified printer structure
      •Superior reliability: modularized with heavy duty high quality components
      •Adjustable DLP to optimize printing performance
      •Compatible to all SLA photoresins sensitive to 400nm light
      Be real the price range of SLA is $3299 - $1,000,000 US dallors
      No SLA For $1500
      "I'm also continually surprised by Makerbots crappy specs. The layer resolution on this Mini is 200 microns! That stinks. I also don't think any of their machines are self leveling. Ugh." -xiombarg » Today, 8:29 pm
      I see you like SLA over FDM
      FDM easiier and ceaper to use.
      Makerbots Mini has some great specs for a FDM Technology
      Here are the key specs of the Replicator Mini:
      •Printing Technology: FDM
      •Build Volume: 10 L x 10 W x 12.5 H cm (3.9 L x 3.9 W x 4.9 H in)
      •Layer Resolution: 200 Microns
      •Filament Diameter: 1.75 mm
      •Nozzle Diameter: 0.4 mm
      •Camera Resolution: 320x240 pixels
      •File Types Supported: STL, OBJ, Thing, MakerBot
      •Retailing at $1,375
      The layer resolution on this Mini it made to be use by home software that only give .0002 or 200 microns! accerccy -dukejazz
      patents are still on the self leveling machines -dukejazz
      and they look pricy to make
      I saw one that you can make
      Build Platform Levelling - Makerbot 3D Printers Wiki | makerbot.wikia.com/
      Automated Bed Leveling For 3D Printers Is Now Solved | April 15, 2014 By Brian Benchoff
      Ask Hackaday: Auto Bed Leveling And High Temperature Force Sensitive Resistors | March 19, 2014 By Brian Benchoff
      • dukejazzD
        dukejazz
        New 3d Machine Unveilings
        3D Printing: Autodesk Bids To Become The 'Android' of the 3D World | gilcommunity.com
        EPO - Finalist Non-European countries - 3D printing (stereolithography Charles W. Hull | vieuws.eu
        Cube 3D printer - Home 3D printer to turn your ideas into real objects - Cubify | cubify.com
        https://dud5umgikjidx.cloudfront.net/resources/images/cube/bkg_cube_printingandyou_3.jpg
        • dukejazzD
          dukejazz
          I look at SLA printer as a (level 2) printer, high detail prints HD, fast, high power, aim for the business world
          I look at FDM printer as a (level 1) printer, low detail prints LD, low power, aim for the home users
          A Pro users would have a uses for both one for prof and one for finial
          A new design type of FDM printer is coming that can switch gears to a smaller gauge filament
          A Microscope-Inspired Extruder Design Could Add Fine Detail To 3D Prints | TechCrunch
          "The various head sizes will allow users to print large gauge plastic for the structural parts of a 3D print and thinner filament for the finer parts. This improves the resolution of the outside surface while improving stability for the inside parts. When the head spins it can cut off the hot filament for a moment and then extrude it after it heats up. This could add a little time to the printing process, but it’s definitely a cool idea."
          http://tctechcrunch2011.files.wordpress.com/2014/05/crownextruder-4nozzles.jpg?w=615
          "Why is this important? Because this sort of printing, called fused deposition modeling, though expanding, is highly limited in terms of resolution and speed. There are far better ways to print out there, but FDM is the cheapest and this could both save time and filament as it extrudes fat lines where things can be messy and fine lines when high-resolution detail is needed."
          • xiombargX
            xiombarg
            Just so people have an idea of what the difference looks like when speaking of layer resolution, here are a couple of examples.
            Layer resolution of 200 microns, or .2mm
            This is the current minimum layer resolution of the Makerbot mini and older FDM printers.
            http://i9.photobucket.com/albums/a51/xiombarg001/200u_zps2e33427f.jpg
            Layer resolution of 100 microns, or .1mm
            Keep in mind that this picture example is not as magnified as most of the other pictures, so it might look smoother than some of the other examples.
            Many FDM printers have this resolution including the higher end Makerbot models.
            http://i9.photobucket.com/albums/a51/xiombarg001/bb412ff2d20a2e4a02da6e92fee345db_large_zps84057751.jpg
            Layer resolution of 50 microns, or .05mm
            This is the minimum resolution of many older SLA printers and newer FDM printers.
            http://i9.photobucket.com/albums/a51/xiombarg001/Buddha_50mu_pencil_cu_2000_zps69adde82.jpg
            http://i9.photobucket.com/albums/a51/xiombarg001/Buddha_50mu_pencil_2000-300x199_zps2329dcc9.jpg
            Layer resolution of 25 microns, or .025mm
            This is the minimum resolution of the Form1 and many SLA printers (usually between 25-40 micron minimum). Some of the newer FDM printers such as the Cel-Robox have also announced such resolution capability by controlling the resin flow by valves instead of merely controlling the feed rate of the filament as it passes through the nozzle, hence getting a more refined stream.
            http://i9.photobucket.com/albums/a51/xiombarg001/firstprint_grande_zpsfcf2b4d7.jpg
            • dukejazzD
              dukejazz
              In the News 3d Machine
              Kudo3D Launching Kickstarter Campaign for Titan 1 DLP 3D Printer | 3dprintinginsider.com
              http://3dprintinginsider.com/files/2014/05/3d-rings1.jpg
              3D Printers for Sale | 3D Printing Color | 3dprintingcolor.com
              "Setting The Standard
              In Desktop 3D Printing,
              Desktop 3D Scanning, and 3D Entertainment"
              Low Cost 3D Printer - RepRapPro Ormerod » DesignSpark - RS Components | rs-online.com
              http://5af5e3de5795a966dd90-e9792bbf34570cde028937f7b1897875.r53.cf3.rackcdn.com/uploads/images/537dd4a55bb44833a9fc11ae0ab30198
              Sculptify's FLEX: Pellets Instead of Filament - 3D Printing Industry | 3dprintingindustry.com
              http://cdn.3dprintingindustry.com/wp-content/uploads/2014/05/pellet-extrusion-process.jpg
              • dukejazzD
                dukejazz
                In the News for 3d Machine
                Amazon.com: UP! Mini 3D Desktop Printer, 100-240V AC, 50-60Hz, 200W: Electronics | amazon.com
                http://hothardware.com/articleimages/Item1946/small_up-mini-front.jpg
                Autodesk CEO: '3D printing has been way overhyped' • The Channel | channelregister.co.uk
                The Autodesk 3D Printer: A Calculated Bet | Forbes
                Google '3D Printing' and You Might Find an Apple | beforeitsnews.com
                3ders.org - Sneak peak of Robo 3D R2 printer, Titan electronics board & new file | 3ders.org
                http://www.3ders.org/images2014/robo3d-r2-3d-printer-1.jpg
                D&H to bring RoBo3D 3-D printers to US SMBs | eChannelLine
                Meg Whitman Reveals That Hewlett Packard Will Only Focus on 'Business 3D Printing' | 3DPrint.com
                HP's (NYSE: HPQ) Premature Release Leads to Jump in Stock Pricing | Financialbuzz.com
                New Money-Saving 3D Printing Consumables by Canada Powder | PR.com (press release)
                New Money-Saving 3D Printing Consumables by Canada Powder | IT News Online
                  Amazing how speed this domain is evolving! 😲
                  • dukejazzD
                    dukejazz
                    3D Printer ( Prototype ) By Bandit-ed - Thingiverse | Thingiverse - Newest Things
                    Http;//thingiverse-production.s3.amazonaws.com/renders/40/27/94/5c/0b/foto_1_preview_featured.jpg
                    Isis One 3D Printer - Isis3d | Isis3d.net
                    Da Vinci 1.0 3D Printer Complete Review Video | 3Dprintboard.com
                    Creator Wood Case 3D Printer: Amazon.com: Industrial & Scientific | Amazon.com
                    • dukejazzD
                      dukejazz
                      3D Print Your Next House – BetAbram Plans to Sell 3D House Printers for 12000€ | 3DPrint.com
                      http://3dprint.com/wp-content/uploads/2014/05/betabram1-1024x682.jpg
                      De Anza prepares for launch of 3D printer and scanner | La Voz Weekly
                      LittleDLPer: Open Source DLP 3D Resin Printer, Coming Soon to Kickstarter | 3DPrint.com
                      http://3dprint.com/wp-content/uploads/2014/05/littledlper-side.jpg
                      • dukejazzD
                        dukejazz
                        3ders.org - Visualize your prototypes before 3D printing them with CastAR glasses | 3ders.org
                        FlexTrunk - Flexible 5-Axis Machining and 3D Printing Shaft - Cable Actuated Flexure | blogspot.com
                        http://3.bp.blogspot.com/-UbJeLJAk30s/U4DBdk9ZyDI/AAAAAAAAEqo/UY_lXExTB7Y/s1600/DSC00818.JPG
                        A 3D Printer for the Rest of Us: New Matter Builds $199 Device | Mashable
                        New 3D printing tech in works | The Tribune-Democrat
                        Cloudio2go Iceman 3D Printer Launches Crowdfunding Campaign on Indiegogo | 3DPrint.com
                        http://3dprint.com/wp-content/uploads/2014/05/iceman-1.png
                        More desktop 3D Printing from Bristol | Personalize
                        • dukejazzD
                          dukejazz
                          3D Systems to Release Cube3 and CubePro 3D Printers | Desktop Engineering
                          D3D Kickstart Autolift: Retractable Hot Ends for High Performance | 3DPrint.com
                          Cambridge Company Unveils 3D Printed "Fruit" | Security - Slashdot
                          RCGroups.com 3D Printing with the ROBO 3D R1 | RCGroups.com
                          http://static.rcgroups.net/forums/attachments/5/0/5/8/4/7/t6800686-63-thumb-20140425_195109-1.jpg?d=1401172367
                          • dukejazzD
                            dukejazz
                            World's Cheapest 3D Printer Moves Forward | La3-d
                            Meet New Matter: A Sub-$300 3D Printer And Design Marketplace So Easy A Caveman | Pandodaily
                            Scribd Objet 1000 3D Printer | Scribd
                            http://htmlimg1.scribdassets.com/1emr25c2v43teu02/images/1-9a7b333d65.jpg
                            • dukejazzD
                              dukejazz
                              Pancakebot: this drawbot builds objects from batter #3dxfood | Adafruit industries blog · matt
                              Kickstarter Titan 1 | Kickstarter
                              New matter partners with frog design and launches desktop 3d printer for under two-hundred ... | Shapeways blog on 3d printing news & innovation
                              http://www.shapeways.com/blog/uploads/New-Matter-Hero.jpg
                              New matter 3d printing ecoystem | Frog design
                              German startup launches 3d printing pen & $649 iceman 3d printer on indiegogo | 3Ders.Org
                              Autodesk Takes 3D Printing Open Source | Automation World
                              • dukejazzD
                                dukejazz
                                New 3d Machine Unveilings & Other Idems
                                Autodesk announces new open source 3D Printer | 3DPrinterPrices.net · Andy
                                New Chinese 3D Printer can Print Objects the Size of Cars in Full Color | 3dprintboard.com
                                Cloudio2go Iceman3D Desktop 3D Printer | 3D Printer World
                                I've found my 3D printer | EIT ICT Labs
                                http://www.eitictlabs.eu/uploads/pics/The-Micro.jpg
                                The MOD-t 3D Printer | fabbaloo.com
                                New Matter MOD-t 3D printer hits Indiegogo for $149 | TweakTown
                                World's Cheapest 3D Printer On IndieGogo for $149 | Tom's Guide
                                You Can Now Get a 3D Printer for Under $200 | Nextgov
                                New Matter 3D Printer MOD-t Launches on Indiegogo | The Voice of 3D Printing
                                • dukejazzD
                                  dukejazz
                                  Local 3D firm develops printer-based curriculum | Indianapolis Business Journal
                                  New superfast Cloudio2go Iceman 3DDesktop Printer,Aluminium case,WiFi | Indiegogo
                                  https://images.indiegogo.com/medias/1416467/primary_pictures/full/20140526114210-indie2front.png?1401129735
                                  CubePro vs. Ultimaker 2 | Reddit
                                  Taulman 618 Nylon 3D Printing Filament | Printed Solid
                                  15-year-old boy to build low-cost 3D printer in India | digit.in
                                  Deltaprintr: A new affordable 3D printer developed by a US college | digit.in
                                  How This French 3-D Printing Company Differentiates Itself From the Competition | Motley Fool
                                  French Man Has Developed a 3D Metal Printer for Just 600€: Capable of printing. | 3DPrint.com
                                  Automated Home Manufacturing Combining 3D Printing With Robotics | Hackaday · James Hobson
                                  Paper 3D printing | 3D Printing Today
                                  • dukejazzD
                                    dukejazz
                                    Virginia Tech introducing latest 3D printing vending machine DreamVendor 2 | 3Ders.org
                                    DYNAMISM ANNOUNCES THE LAUNCH OF THE ULTIMAKER 2, THE NEWEST TECHNOLOGY ... | GISuser.com (press release)
                                    Stratasys Dimension 1200es ABS Prototype 3D Printer | ENGINEERING.com
                                    MakerBot Opens First Mini-retail Offering in New York's B&H SuperStore | 3DPrint.com
                                    Dream Vendor: Interactive 3D Printing Machine | Gadgetify.com
                                    DreamVendor's 3D Printing Kiosks to be Available in the Near Future | The Voice of 3D Printing
                                    STRATASYS Fortus 400mc Barcelona 3D printed UAV | DIY Drones
                                    Isis3D Announces Improved Isis One | 3D Printer World
                                    http://www.3dprinterworld.com/sites/speh/files/images/isis/isis_one_dual_extruder_printer.jpg
                                    The Titan 1 3D Printer | fabbaloo.com
                                    WIP
                                    • dukejazzD
                                      dukejazz
                                      New Matter aims to make 3D printing more accessible with the MOD-t | 3dprintingplan.com
                                      The MakrToolbox Mk1 – Inexpensive 3D Printer Kit | 3D Printer World
                                      https://s3.amazonaws.com/ksr/assets/002/026/481/1f96065d5d69a98427a2f4bb2ae2ad4f_large.jpg?1400450756
                                      Klic-N-Print 3D printer | KNK USA
                                      Combining 3D Printing with Robtic Arms | 3D Printing Forum - 3D Print Board
                                      Affordable precision 3D printing for pros | kurzweilai.net
                                      Structured Polymers Raises $1.2 million to Expand 3D Printing Materials Market | 3D Printing Forum - 3D Print Board
                                      3D Printed Earbuds Compact | Instructables
                                      This Titan 1 3D Printer Can Make Towering Objects in Half the Time | Inhabitat
                                      Creating a 3D printer for under $100 | Bits & Pieces from the Embedded Design World - WordPress.com
                                      • dukejazzD
                                        dukejazz
                                        New SLA 3D Printer Kickstarter Campaign | Mold3D
                                        French Man Developed 3D Metal Printer for Just 600 | freerepublic.com
                                        http://3dprint.com/wp-content/uploads/2014/06/strong-inactive.jpg
                                        Botfeeder 3d Printer Filament 1st Year Anniversary | ez-robot.com
                                        eirdest Things We'd Want To Make With A 3D Printer | 93.1 Jack FM · Nadia Noir
                                        Selectism Printing Things | Selectism · Lena Dystant
                                        • dukejazzD
                                          dukejazz
                                          Turning A Laser Cutter Into A 3D Printer With OpenSLS | Hackaday · Brian Benchoff
                                          Up close with Zeus, the first consumer all-in-one 3D printer, scanner and fax | Gizmag
                                          XYZPrinting's da Vinci 1.0 AiO and 2.1 AiO ALL-IN-ONE 3d Printers & Scanners Will Be | 3DPrint.com
                                          XYZprinting launch two new printers with in-built 3D Scanning | Personalize
                                          LulzBot TAZ 4 3D Printer Now Available For $2195 (video) | Geeky gadgets
                                          http://www.geeky-gadgets.com/wp-content/uploads/2014/06/LulzBot-TAZ-4-3D-Printer.jpg
                                          Looking Glass Hologram Volumetric Printing Service Hits Kickstarter (video) | Geeky gadgets
                                          Stratasys launches multi-material 3D printer | The Star Online
                                          OpenSLS – An Open Source Project Creates a Sub-$15K Selective Laser Sintering r | 3DPrint.com
                                          Tinkerine launches its own line of biodegradable PLA 3D printing filament | Biobased Digest
                                          • dukejazzD
                                            dukejazz
                                            Stratasys 3D Printed Injection Molds Help Company Cut Lead Times | Product Design & Development
                                            Texas-Based 3DP Materials Startup Raises $1.5M | ENGINEERING.com
                                            Sony unveils ultrathin Xperia T3 smartphone | htxt.africa
                                            Materialise to Implement 3-matic STL for Additive Manufacturing in the Altair Partner Alliance | MarketWatch
                                            XYZprinting announces da Vinci Nobel 1.0 SLA 3D printer, priced under $2500 | 3Ders.org
                                            xt-copolyester | ColorFabb
                                            Why Buying a 3D Printer Sucks | THRE3D
                                            DirectJet 1024UVHS Texture 3D Printing | Signwarehouse.com
                                            http://www.signwarehouse.com/blog/wp-content/uploads/2014/06/blog_Texture3D_header_300X158.jpg
                                            • 49
                                            • 50
                                            • 1 / 50
