    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 90.1k Views 41 Watching
      Yep! 😎
        Anton_S
        Professionally done!
        Works like a charm πŸ‘
        And a suggestion, are you planning to add a reset button?
        Some sounds would be awesome as well
        • alexandre skA Offline
          alexandre sk
          Fantastic plugin AND model. I miss those ICE from Germany, 300km/h without a bump.
          Ohh and thx for your Texture Positioning plug-in I use a lot.
          • pbacotP Offline
            Genious!
            • KrisidiousK Offline
              Krisidious
              She's got a few Oli...
              http://eneroth.port0.org
              By: Kristoff Rand
              • PixeroP Offline
                Pixero
                Fantastiskt! πŸ‘
                I'm not sure how often I will be able to use this for work but it's an amazing plugin.
                Does it work on terrain as well?
                Have you thought of doing a road and cars version?
                • eneroth3E Offline
                  eneroth3
                  i haven't really thought about a reset button. In Sketchyphysics I think the whole animation runs inside a tool and that Sketchup.abort_operation runs to move everything back when the user stops the animation. In my plugin the animation doesn't run inside an active tool since you need several tools so set switches, connect/disconnect couplings etc.
                  I've though about sounds but then I need to be able to play the same sound at different speeds to match the speed of the train. Also I would need lots and lots of sounds.
                  @olishea said:
                  I don't think I'll ever need this plugin, but all I can say is wow! Looks like fun! πŸ‘ πŸ˜„
                  Eneroth: I believe I've seen your plugins before? Did you make a terrain eroder or something along those lines?
                  Yup ,that's mine. You can see all my plugins here:
                  SketchUp Extension Warehouse
                  Your library of custom third-party extensions created to optimize your SketchUp workflow.
                  (extensions.sketchup.com)
                  SketchUp Plugins | PluginStore | SketchUcation
                  SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                  (sketchucation.com)
                  @pixero said:
                  Fantastiskt! πŸ‘
                  It should work on terrain but you might need to alter the terrain after adding the tracks so there's no gap under them. you can also add a new track type that has more ballast under it to prevent this gap. The same thing can be done with roads, create a road as a track type and initialize a car as rolling stock.
                  Under Plugins > Railroad > Documentation it's written how you make custom track types and rolling stocks. saving a rolling stock to the library however isn't very stable at the moment (some observers seem to get upset when I've tried in SU 2013). After saving a rolling stock to the rolling stock library it's recommended to restart Sketchup. Otherwise you can just initialize one without adding to the library.
                  My website: http://julia-christina-eneroth.se/
                    rv1974
                    Without spaghetti western style bandits in library the plugin is rather pointless.
                    How am I supposed to robber the train? πŸ˜„
                    bang-bang
                      Krisidious
                      bang-bang
                      By: Kristoff Rand
                      • eneroth3E Offline
                        eneroth3
                        bang-bang
                        Make a 2d face me component of a person pointing a gun and follow the train with the camera. Then you can be inside the train and have a person standing at the side of the track pointing the gun at you when driving by πŸ˜„
                          rv1974
                          SurstrΓΆmming western?
                          I see..πŸ˜„
                            Reading the "Read me" ! 😎
                            That is a complete universe! 😲
                              Added to PluginStore
                              • eneroth3E Offline
                                eneroth3
                                πŸ‘
                                  Lz
                                  Very impressive. It's a shame that it doesn't seem to work on my SU 8 (i'm using WinXP btw). But i'm planning on upgrading anyway so i might take another look sometime in the future.
                                  either way, if you need help adding new rolling stock/locomotives for future versions, please let me know and i'll gladly try to help out with some models. German locomotives are one of my favorites too.
                                  • OxerO Offline
                                    Oxer
                                    I tried to install on Mac 10.9.3 &SU2014 but it appears Load Error
                                    %(#BF0000)[Error al cargar archivo ene_railroad.rb
                                    Error: #<TypeError: wrong argument type nil (expected Regexp)>
                                    /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/ene_railroad.rb:202:in `gsub'
                                    /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/ene_railroad.rb:202:in `module:Ene_Railroad'
                                    /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/ene_railroad.rb:200:in `<top (required)>']
                                    • ElibjrE Offline
                                      Elibjr
                                      Wow! There is no word to describe how amazing this plugin is! There is a LOT of work here! Like someone said before,I would love to see this in conjunction with the "Enderoth Roadway System" with moving cars! πŸ˜„ This could then be the basis for a 'City Engine' like interface to generating a full city infrastructure system! Create a SketchUp parametric building modeler and you can develop set for model trains, virtual cities for the big screen and Real world studies for municipalities. Then export the whole thing component by component to a 3d printer and have a physical model to take to a municipal presentation for zoning! πŸ˜‰ This, my dear, is a real Sketchup game changer! Thank you for all the hours you spent on this! This should be voted as plugin on the month! Awesome! Sketchup: "The Next Big Thing". Can't wait to have fun with it! πŸ‘
                                      • eneroth3E Offline
                                        eneroth3
                                        There seems to be some bug with the observers in older SU versions 😞 . However you can try it in Sketchup 2013. I've tried to make it as easy as possible to initialize own rolling stocks and it would be really fun if you and other people made your own and sharde πŸ˜„ . At the moment there's some strange bug when saving a rolling stock to the library so after doing so it's best to restart SU to avoid it from crashing later.
                                        Oh 😲 , I thought it would break on web dialogs and possibly multiple document interface. I'll look into this error.
                                        • OxerO Offline
                                          Oxer
                                          Thansk for the reply!!
                                          This is a incredible plugin πŸ‘ , I would like play with it on Mac, waiting your fix. πŸ˜’
                                            driven
                                            @eneroth3 said:
                                            Oh :shock: , I thought it would break on web dialogs and possibly multiple document interface. I'll look into this error.
                                            on mac
                                            File::ALT_SEPARATOR
                                            nil
                                            so it runs with PLUGIN_ROOT = File.dirname(__FILE__) unless defined?(self::PLUGIN_ROOT)
                                            WebDialog needs a show_modal conditional for mac...
                                            seems to work...
                                            also, to see the docs...
                                            menu.add_item("Documentation") { UI.openURL('file://' + (File.join(PLUGIN_ROOT, "ene_railroad", "docs", "home.html"))) }
                                            PS. the track builds the trains run, speed works... very cool...
                                            I'll have a closer look at the code on the weekend...
                                            One question, why do you get/need the screen/window position/size?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 17 / 19
