[Plugin] DrawAlong - v1.2a - 12 Oct 14
@pbacot said:
That's right. The long hand version is usually 5'-2 1/2", but the hyphen is often dropped. So Ruby treats it differently?
Less and less clear
in the Ruby consolea = "5'-2 1/4".to_l -8.8976377952756
Anyway, whatever is the notation, I still don't understand why 5'2 1/4 = 138.74 inches, whereas 5' is just 60 inches.
I found the explanation finally.
The model was in unit "decimal" metre
So if you type 5'2 1/4 it is misinterpreted by SU. I guess it takes the 1/4 for 1/4 of a metre.
Anyway, if the model unit is Fractional, then it works and the 3 notations below would give 62.25 inches
- 5'2 1/4
- 5' 2 1/4
- 5' 2.25"
I have done the changes and will republish soon
NEW RELEASE: DrawAlong v1.0b - 17 May 14
DrawAlong 1.0b is an update fixing a bug in the input of architectural units in the VCB. It also includes a Spanish translation (ES) by Oxer.
It is published as part of FredTools 1.9b.
See main post of this thread and FredoTools for download.
Thanks Fredo
NEW RELEASE: DrawAlong v1.1a - 18 Jun 14
DrawAlong 1.1a is an update fixing various problems and introducing inferences when drawing on a plane (ES) by Oxer.
It is published as part of FredTools 2.0a.
Very Nice GOD Bless you more... You help thousands of people.
This would be great if it included the arc command!
NEW RELEASE: DrawAlong v1.2a - 12 Oct 14
DrawAlong 1.2a is an update fixing problems with Construction Points: inferencing when cpoint is on a face and avoid doubling when drawing in Guide mode.
It is published as part of FredTools 2.1a.
This is incredible tool.
Is it possible to have length snapping with DrawAlong? I can't seem to have it working . . .
In SU 2024, in a newly created and empty file, the first line (even formed from multiple edges) is not visible, only the second is visible, or if the file is not empty.
I tested in SU 2023 and 2022, and this bug is only in 2024.Edit: It is a problem in my custom template that occurs only in SU 2024...!
The problem doesn't exist with the same template in SU 2022 or 2023... I don't understand yet...
