    [Plugin] DrawAlong - v1.2a - 12 Oct 14
    32 Posts 15 Posters 38.0k Views 15 Watching
    • fredo6F
      @pbacot said:
      That's right. The long hand version is usually 5'-2 1/2", but the hyphen is often dropped. So Ruby treats it differently?
      Less and less clear
      in the Ruby console
      a = "5'-2 1/4".to_l
      -8.8976377952756
      Anyway, whatever is the notation, I still don't understand why 5'2 1/4 = 138.74 inches, whereas 5' is just 60 inches.
      • fredo6F
        I found the explanation finally.
        The model was in unit "decimal" metre
        So if you type 5'2 1/4 it is misinterpreted by SU. I guess it takes the 1/4 for 1/4 of a metre.
        Anyway, if the model unit is Fractional, then it works and the 3 notations below would give 62.25 inches
        • 5'2 1/4
        • 5' 2 1/4
        • 5' 2.25"
        I have done the changes and will republish soon
        • fredo6F
          NEW RELEASE: DrawAlong v1.0b - 17 May 14
          DrawAlong 1.0b is an update fixing a bug in the input of architectural units in the VCB. It also includes a Spanish translation (ES) by Oxer.
          It is published as part of FredTools 1.9b.
          See main post of this thread and FredoTools for download.
            Thanks Fredo
            • fredo6F
              NEW RELEASE: DrawAlong v1.1a - 18 Jun 14
              DrawAlong 1.1a is an update fixing various problems and introducing inferences when drawing on a plane (ES) by Oxer.
              It is published as part of FredTools 2.0a.
                makiboypogi
                Very Nice GOD Bless you more... You help thousands of people.
                • C
                  chrismichaelgentile
                  This would be great if it included the arc command!
                  • fredo6F
                    NEW RELEASE: DrawAlong v1.2a - 12 Oct 14
                    DrawAlong 1.2a is an update fixing problems with Construction Points: inferencing when cpoint is on a face and avoid doubling when drawing in Guide mode.
                    It is published as part of FredTools 2.1a.
                    • L
                      laudhi
                      πŸ‘
                      • sicksickisckS
                        sicksickisck
                        This is incredible tool.
                        • F
                          function
                          Is it possible to have length snapping with DrawAlong? I can't seem to have it working . . .
                          • F
                            FlorinAp
                            In SU 2024, in a newly created and empty file, the first line (even formed from multiple edges) is not visible, only the second is visible, or if the file is not empty.
                            I tested in SU 2023 and 2022, and this bug is only in 2024.
                            Edit: It is a problem in my custom template that occurs only in SU 2024...!
                            The problem doesn't exist with the same template in SU 2022 or 2023... I don't understand yet...
                            • 2 / 2
