    [Plugin] DrawAlong - v1.2a - 12 Oct 14
    32 Posts 15 Posters 38.0k Views 15 Watching
    • fredo6F
      If I understand the syntax, I think I can make it.
      For instance what does mean 5'2 1/2
      Is it 5 feet and 2 inch and half an inch?
      [EDIT] I made some test in the Ruby console, and I am lost, because 5'2 does not look to be 5 feet and 2 inches!!
      "5'".to_l
      60.0
      "5'2".to_l
      138.74015748031496
      "5'2 1/4".to_l
      148.58267716535434
      • pbacotP
        That's right. The long hand version is usually 5'-2 1/2", but the hyphen is often dropped. So Ruby treats it differently?
        • fredo6F
          Less and less clear
          in the Ruby console
          a = "5'-2 1/4".to_l
          -8.8976377952756
          Anyway, whatever is the notation, I still don't understand why 5'2 1/4 = 138.74 inches, whereas 5' is just 60 inches.
          • fredo6F
            I found the explanation finally.
            The model was in unit "decimal" metre
            So if you type 5'2 1/4 it is misinterpreted by SU. I guess it takes the 1/4 for 1/4 of a metre.
            Anyway, if the model unit is Fractional, then it works and the 3 notations below would give 62.25 inches
            • 5'2 1/4
            • 5' 2 1/4
            • 5' 2.25"
            I have done the changes and will republish soon
            • fredo6F
              NEW RELEASE: DrawAlong v1.0b - 17 May 14
              DrawAlong 1.0b is an update fixing a bug in the input of architectural units in the VCB. It also includes a Spanish translation (ES) by Oxer.
              It is published as part of FredTools 1.9b.
              See main post of this thread and FredoTools for download.
                Thanks Fredo
                • fredo6F
                  NEW RELEASE: DrawAlong v1.1a - 18 Jun 14
                  DrawAlong 1.1a is an update fixing various problems and introducing inferences when drawing on a plane (ES) by Oxer.
                  It is published as part of FredTools 2.0a.
                    makiboypogi
                    Very Nice GOD Bless you more... You help thousands of people.
                    • C
                      chrismichaelgentile
                      This would be great if it included the arc command!
                      • fredo6F
                        NEW RELEASE: DrawAlong v1.2a - 12 Oct 14
                        DrawAlong 1.2a is an update fixing problems with Construction Points: inferencing when cpoint is on a face and avoid doubling when drawing in Guide mode.
                        It is published as part of FredTools 2.1a.
                        • L
                          laudhi
                          πŸ‘
                          • sicksickisckS
                            sicksickisck
                            This is incredible tool.
                            • F
                              function
                              Is it possible to have length snapping with DrawAlong? I can't seem to have it working . . .
                              • F
                                FlorinAp
                                In SU 2024, in a newly created and empty file, the first line (even formed from multiple edges) is not visible, only the second is visible, or if the file is not empty.
                                I tested in SU 2023 and 2022, and this bug is only in 2024.
                                Edit: It is a problem in my custom template that occurs only in SU 2024...!
                                The problem doesn't exist with the same template in SU 2022 or 2023... I don't understand yet...
                                • 2 / 2
