    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 439.8k Views 109 Watching
    • KrisidiousK
      Krisidious
      @zacchia said:
      Many thanks for this plugin!! I tried to install it with the Plugin Store but there I could not find it. Are not all plugins listed there? I mean I could install it but I was just wondering...
      All plugins are not in the store... just a heck of a lot of them. some are in the warehouse and then some others are on people's websites and then some others are just small things buried in forums and various author's computers.
      By: Kristoff Rand
      • Z
        Zacchia
        Thanks for answer!
          Because this tool is 'work-in-progress', its author [Sam] has opted not to put it into the PluginStore just yet.
          When he has sorted out any 'beta' issues I'm sure it'll become available there as an RBZ in due course.
          At the moment it's available in the first post as an RB file, which needs downloading and manually placing into the default SketchUp Plugins folder.
          If you have the SketchUcation PluginStore toolset Plugin installed then it has is a submenu option to find and open the Plugins folder.
          If you are using < v2014 on PC you need to ensure that you have FULL security permissions to read/write to the Plugins folder - there is a Tutorial about fixing those, accessed from the menu above...
          • N
            notareal
            Nice work so far! I am sure that when released as "final" this will be a hit.
            • sdmitchS
              sdmitch
              Floor Generator has been moved to the Plugin Store.
              http://sdmitch.blogspot.com/
              • guanjinG
                guanjin
                The plug-in is perfect, but unfortunately does not support Chinese language πŸ˜’
                • OxerO
                  Oxer
                  ~~There is a conflict with offset.rb required for Protude.rb, the next Patterns don't work:
                  • Irregular Polygons
                  • HopScotch3
                  • I_Block
                    The rest of patterns work fine.~~
                  Another question, is it possible give support to translate the plugin?
                  EDIT: I found a version of offset.rb that it isn't conflict with Floor Generator.
                  • sdmitchS
                    sdmitch
                    • HopScotch3
                    • I_Block
                    I can't see how Floor Generator could ever have a conflict with offset.rb since I use a method of my own creation to do the offsets and every pattern uses the same offset method.
                    I have no ability or plans to do any translations of the plugin.
                    • OxerO
                      Oxer
                      Thanks for the reply.
                      • tt_suT
                        tt_su
                        I think offset.rb modifies core classes which breaks plugins.
                        • O
                          Openspaces
                          Thank you so very much, very useful Plugin. πŸ‘
                          • sdmitchS
                            sdmitch
                            Shortly after finding and using offset.rb, it was pointed out that that could be a potential problem so I did away with the class and just used it as a method. The first versions of Floor Generator used this offset method until I tried to add the Herringbone pattern. It failed apparently because the way the faces are arranged it cause multiple edges to be reversed in the face and it couldn't handle that. So I had to create my own version.
                              azumayugo
                              hi,
                              i've used your script for several times, it's nice and run well. But suddenly, the script didn't load. When I check ruby console, it show some error message like this :
                              Error: #<NoMethodError: undefined method to_l' for nil:NilClass> C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:89:in dialog'
                              C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:63:in initialize' C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:33:in new'
                              C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:33:in block in <top (required)>' -e:1:in call'
                              What should I do to make the script run again?
                              Thank's before
                              • sdmitchS
                                sdmitch
                                @azumayugo said:
                                hi,
                                Thank's before
                                It is probably a problem related to the saved defaults. If the plugin runs at all, choose the reset option at the bottom of the pattern list to reset the defaults.
                                If that isn't possible, paste the following into the Ruby Console and press Enter.
                                ["Brick","Tile","Wood","Tweed","Hbone","BsktWv","HpScth1","HpScth2",'HpScth3',"HpScth4","IrPoly","Hexgon","Octgon","Wedge","I_Block"].each{|o| Sketchup.write_default("FloorGenerator",o,nil)};
                                  azumayugo
                                  @sdmitch said:
                                  @azumayugo said:
                                  hi,
                                  Thank's before
                                  Thank's sdmitch. It work again πŸ‘
                                  • U
                                    unsuns
                                    Hello Everyone !
                                    First of all, thank you for the great job you did to bring us that tool.
                                    However, I have an issue : I wanted to be able to run it through a toolbar button (which I successfully did, but when I close the FG window the button is still activated and if I try to run it again the FG window doesnt show up anymore (even if I use other tools after that).
                                    Could you please help me to fix it ? πŸ˜•
                                    My issue
                                    • sdmitchS
                                      sdmitch
                                      @unsuns said:
                                      Hello Everyone !
                                      Just don't "X" out of the WebDialog window, instead Right click in space or select any other tool. This will close the WebDialog window an unselect the Toolbar Icon.
                                      • jolranJ
                                        jolran
                                        Sam. I think you could try trigger some actions during the closing of the dialog with "X", using @yourdialog.set_on_close { #set closing action here }. If you are not already using it, that is.
                                        As usual concerning webdialogs, I don't know how reliable that method is..
                                        • U
                                          unsuns
                                          I tried what you said jolran but I couldn't figure it out. How should I do it ?
                                          Here is the code:
                                          [mod=:3izmkj1d]Please don't post entire blocks of code from other authors - it's bad manners...
                                          Extracts are fine...[/mod:3izmkj1d]
                                          • sdmitchS
                                            sdmitch
                                            I wasn't. Another one of those things that is there but not a necessity so I just ignored it. Thanks for the suggestion.
                                            • 16
                                            • 17
                                            • 4 / 17
