    [Plugin] CleanUp
    974 Posts 217 Posters 862.1k Views 217 Watching
      saucerful
      It works! Thank you so much. This plugin is extremely useful for our workflow at Open Source Ecology (see here).
      Any idea when 2.9.9 will be pushed to the extension warehouse?
      • tt_suT Offline
        tt_su
        @saucerful said:
        It works!
        Huh! How about that! Stab in the dark!
        Glad it worked. πŸ˜„
        I'll upload to EW right now. Not sure when it goes live, depends on the moderation queue.
        • tt_suT Offline
          tt_su
          So, I'm making a guess here: Wine calls Linux's file functions which returns the files in a different order - revealing a dependency bug that isn't visible in Windows or OSX.
          Can you try this version attached:
          (Deleted file as it's now been uploaded to Extension Warehouse, Plugin Store and GitHub.)
            Asloric
            Hello i have a problem: useless faces in models (per exemple a face in a cube) doesnt erase with the plugin . could it be possible to add please? or explain how to do if there is yet
            here is a screen if you don't understand what i mean
            the wood face in the cube doesn't erase
            PS: thanks a lot for this usefull plugin πŸ˜„
              If it's the one occurrence, then can't you cut a temporary section to give access to the inner unwanted face and erase it/its edges that way ?
              Some tools like my SolidSolver will remove inner partitions/flaps if the 'box' [group] is intended to be a 'solid'...
                Asloric
                thanks.i've erase all useless faces πŸ˜„ .but i thinks it's a bit buggy with my model ( it erase most part of my project sometimes)
                  Does your model have many very small faces/edges? Like ~1mm?
                    Asloric
                    yes beacause a lot of detail for much immersion ( i use the playup plugin to export it to crysis2)
                      If you are trying to create tiny faces (less than 1mm) you are going to have problems unless you work at a larger scale. This has nothing to do with CleanUp, it's just a fact of using SketchUp.
                        SketchUp's internal precision is 1/1000th of an inch. When things get close to that vertices begin to be treated as having the same position and edges and faces might not create - or be lost when you modify them.
                        One workaround is to scale up the actual geometry, the edges and faces by a factor of say 100 - then scale down the instance/group to counter-weight it. That way the definition of the geometry it large enough, but the instance's scale make it appear in correct size.
                        • frankflafyF Offline
                          frankflafy
                          hi
                          thanx for the plug in. really love this.
                          i have one problem. its Vray dome light
                          when i ran this with vray dome light on screen, the vray dome light deleted.
                          how i fix this?
                          thanx
                            What does it look like this VRay dome?
                            This plugin isn't aware of "special" objects that other extensions create - it treats everything as regular edges and faces.
                            • jiminy-billy-bobJ Offline
                              jiminy-billy-bob
                              It's two arcs and a circle, without any face. So no surprise Cleanup deletes these edges.
                              • tt_suT Offline
                                tt_su
                                Anyone got a sample model?
                                  frankflafy
                                  Vray dome light is like this
                                  Vray Dome Light
                                    Charles502
                                    so many thanks, is too very useful plugin for my model 3d and my time, thanks for sharing. thomthom
                                    • utilerU Offline
                                      utiler
                                      Hi Thom, hope you're doing well. πŸ‘
                                      Between your CleanUp Tools and Edge Tools I'm wondering if you have thought about adding an option to move all verticies to Z=0. I often import dwg files that for some reason some lines are just that tiny bit off Z which causes all sorts of issues in finding out what is and isn't flattened....
                                      What do you think?
                                      Love your work!
                                      Just Curious...
                                        "There's an extension for that!": Architect Tools (Look for the big weight-icon that will flatten everything like the Hulk)
                                          antonio.calvo
                                          Thanks so much for your plugins, enjoy the cookie. I'm pretty new posting on this forum althought I have been following all of you guys and your fantastic work for a long time. Recently I'm working in a large model and your plugin is givin me a couple of errors of the model.
                                          Results of Validity Check.
                                          CLoop (1154934) does not reference CFace (1161656) - fixed
                                          The plane equation for CFace (4395989) is not valid - fixed
                                          Both of then never seem to be fixed after running the plugin. Also straight after closing Sketchup, it will create a bug splat! Is driving me mad πŸ˜• and can't find which part of the model is doing it. Any help will be great. Thank you
                                          • cottyC Offline
                                            cotty
                                            @antonio.calvo said:
                                            ...and can't find which part of the model is doing it.
                                            Without having a look at the model no one else will be able to find it too...
                                            my SketchUp gallery
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 48
                                            • 49
                                            • 37 / 49
