    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
      Lee05
      @ppoublan
      I removed everything from plugins menu but 3darcstudiotree folder and 3darcstudiotreeloader.rb and plugin was loaded adn working.
      When extensions.rb is back in plugin folder, error is back too.
        @Lee05
        There should NOT be a extensions.rb file in your 'Plugins' folder at all !
        When SketchUp is installed it adds 3 files into the 'Tools' folder - which it needs and which it expects to be in there...
        extensions.rb langhandler.rb sketchup.rb
        These 3 files should never appear in the 'Plugins' folder.
        Check that they are in the 'Tools' folder, and then remove the rogue ones in 'Plugins'...
        In SketchUp version 8 there are also several other rb files in 'Tools' - unlike v2013, which should only those 3 rb files in 'Tools' with su_... versions of these extras in 'Plugin's.
        The v8 extras will include.
        dynamiccomponents.rb sandboxtools.rb shadowstringsfix.rb SolarNorth.rb
        Again, in v8 these rb files should not appear in 'Plugins' - they belong on 'Tools'...
        Looks like you installation is messed up... πŸ˜’
          Lee05
          @TIG
          Yes, i guess my plugin folder is a little messed up, extensions.rb and sketchup.rb were there. I remove them and everything is fine now, plugin is loaded and works.
          Thank you for support.
          • ramjanR Offline
            ramjan
            hello everyone... i installed .rbz file and when i start sketchup,this error appeared...why??? ❓
            error comment
              You say you "installed the .rbz file" How did you do that? It appears that you didn't do it correctly and/or you haven't got sufficient privileges to add things to the Plugins folder.
              • ramjanR Offline
                ramjan
                i found it... it is because extensions.rb
                i must send it to disable plugin at sketchucation plugin manager... πŸ‘
                  Huh?
                  Did you find extensions.rb in the Plugins folder? If so, that's not where it is supposed to be. It's supposed to be in Tools. If you find extensions.rb in the Tools folder AND the Plugins folder, delete it from Plugins. I wonder what plugin you installed put extensions.rb in the wrong place.
                    There are three rb files that should never be in the Plugins folder.
                    They belong in the Tools folder, where SketchUp puts them as you install it.
                    They are:
                    extensions.rb sketchup.rb langhandler.rb
                      kaas
                      Hello Pascal,
                      I like your 3d tree maker plugin. Great plugin and I'm having fun with the licensed version.
                      I'm trying to make a (low poly) maple tree. It would be great if it would be possible to control the length of the branches relative to the position on the trunk (something like the options for 'leaves position' maybe). For instance, the upper branches could be less in length compared to the lower branches. There are all kinds of controls for the decrease of angles and width but maybe a decrease for the length of the branches could be possible?
                      A decrease in size of the leaves relative to the position on the branch might be a nice idea as well (advanced section).
                      Finally, it seems like the vertices of the trunk are not welded together somehow. If I do a LightUp rendering I get artifacts on the trunk. If I use the weld plugin on the trunk the artifacts are gone. The branches seem not affected by this.
                      Greetings, Max
                      edit: rephrased some sentences and added last two sections.
                      • ppoublanP Offline
                        ppoublan
                        @kaas said:
                        Hello Pascal,
                        It should be achievable using the branches shape parameters. here are some samples, it make changes in length and number of branches based on their position amongst the parent branch. But i can think of more fine parameters.
                        Yes, definitively something I will add. Good idea.
                        Is this only when you render or also within Sketchup ? I will have a look at the plugin you mentioned to see what it do and if I could change the way material is applied to branches.
                        I'm preparing a version with new improvements regarding managing multiple trees in a model, with grass freatures.
                        Cant wait to show you a preview result :
                        Yours
                        Pascal
                          kaas
                          Is this only when you render or also within Sketchup?
                          It's not visible in SketchUp but only during the LightUp walkthrough (LightUp runs in Sketchup - no seperate program).
                          I'm preparing a version with new improvements regarding managing multiple trees in a model, with grass features. Cant wait to show you a preview result
                          Looks great!
                          • bigstickB Offline
                            bigstick
                            This is truly fantastic - epic work Pascal! The improvement from version 1 (which was good) is immense.
                            I'm going to buy this, it's what I've been waiting for for a long time!
                            • ppoublanP Offline
                              ppoublan
                              Just released this night Version 1.10 on my website:
                              See : http://www.3darcstudio.com/downloads-files/24-3d-tree-maker-sketchup-plugin.html
                              with new features including grass. Will update asap Sketchucation and Sketchup Extension sites.
                              Yours
                              Pascal
                              • ppoublanP Offline
                                ppoublan
                                Available in last version 1.10
                                Hi Max,
                                Could you post tree sample (skp) here in order to try to debug ? I was not able to reproduce the problem. Will do more tests.
                                Yours
                                Pascal
                                  kaas
                                  @ppoublan said:
                                  Hi Max,Could you post tree sample (skp) here in order to try to debug ? I was not able to reproduce the problem. Will do more tests.
                                  Hi Pascal, Just installed and tried the new plugin. Tried a few trees and can't reproduce the problem as well...Strange.. Will try more after I'm back from a trip abroad.
                                  Max
                                    jaceguay
                                    Very nice plugin, Thanks. All I need now itΒ΄s a people maker πŸ’š
                                    • bigstickB Offline
                                      bigstick
                                      Great work with the updated version Pascal!
                                      One suggestion however, when inserting multiple instances of the same plant/tree, what would be very cool would be an option in the 'Settings' dialog to randomly scale and rotate each new instance.
                                      With 3D plants, you can naturally get a degree of variation just by rotating and scaling components. The benefit of this is that it works with instancing for render engines, and keeps the file size down πŸ˜„
                                      • Bob JamesB Offline
                                        Bob James
                                        Totally, unequivocally, without question, absolutely OUTSTANDING 😍
                                        Note: Does not work if loaded into "additional folder". Needs to reside in the SU standard plugin location.
                                          dtrarch
                                          Great work Pascal
                                          A quantum leap for in-SU bushing up.
                                          Really quite amazing and only 10 Euro.
                                          πŸ‘ πŸ‘ πŸ‘
                                          Thank you β˜€
                                          dtr
                                          • ppoublanP Offline
                                            ppoublan
                                            Hi Bob,
                                            Thanks for your support. Yes you're right regarding plugin files location that needs to stay within default Sketchup Plugins dir. I started to make changes to fix that, but was blocked by limits of .rbs files (scrambled scripts) that does not work the same way as non scrambled scripts with ruby Files/Dirs functions. Hope to find a workaround for future versions. Will have to get help from the developers forum experts...
                                            Yours
                                            Pascal
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
