    [Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
    123 Posts 51 Posters 186.3k Views 51 Watching
    • V Offline
      vmoccia
      Chris,
      3 years later, this is still an awesome find. So useful, thank you. In regards to using the tool to generate randomization of camera-facing components...If you make a group of components (say three copies of a tree, already randomly placed and scaled), you can then create an array of that group. Application of your tool to the array will randomly scale-rotate the group and create an even more random disposition.
      You've cut my tree-planting workload by a third. thanks again.
      Tree group array
      Tree group randomized
        mgeras
        thanks a lot. you are great.
          popfunky
          GREAT
            popfunky
            THANK YOU
            • HornOxxH Offline
              HornOxx
              as always - a great tool again ! thank you
              never trust a skinny cook
              • W Offline
                wat
                thank sir
                • W Offline
                  wat
                  • HornOxxH Offline
                    HornOxx
                    once again THANK YOU! - A wonderful tool that I use almost daily
                      SUNutz
                      Wow! this is mind blowing. For its simplicity and effectiveness. Thanks!
                      • TommyKT Offline
                        TommyK
                        I use this plugin almost everyday. Many thanks!
                        As a "power" user, I have noticed performance issues when applying the script to lots of components. In a model with hundreds of components, it gets very sluggish indeed, and the memory usage of Sketchup goes through the roof, and sometimes ends in a bugsplat.
                        I am happy to take a look and see what optimisations are possible in the ruby script, but before I do so, I should ask if you have had a go at optimisation already? Do let me know!
                        Tommy
                        • onzkiO Offline
                          onzki
                          Thanks for sharing this.. it will be very useful in my work. By the way, I have a similar need, this time multi-face scale plugin, to scale a multiple polygon/faces in one go. Is this possible? My screenshot:
                          Thanks a lot!
                          [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                            Just transform all your faces in group or component then apply the Scale multiple! πŸ˜‰
                            By Tig each face in Component
                            m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
                            You have in the same spirit the Multiple face Offset by Remus! πŸ˜„
                              potemutzu
                              Thank you for a very usefull plugin
                              • JQLJ Offline
                                JQL
                                Hi Chris,
                                I know you've been busy with other things but I'd like to make a request on this plugin, if you wouldn't mind.
                                I'd like it to work on a choosen axis. Right now we can choose axis, center, base or world, but they all act acording to the Z axis. It would be cool to be able to choose the X or Y axis as a base too.
                                Thanks in advance,
                                JoΓ£o
                                www.casca.pt
                                Visit us on facebook!
                                • HornOxxH Offline
                                  HornOxx
                                  πŸ‘ this is a great suggestion - i join this request πŸ˜„
                                    You can solve that in rotate your objects before apply the script! πŸ˜‰
                                    • JQLJ Offline
                                      JQL
                                      I know I can do that but I have 1643 individual objects that I wanted to randomly rotate.
                                      They were 1643 groups all aligned to the Y axis. I could get inside each one of them and change the Y axis to become the Z axis. But I would be mad if I did that...
                                      Also, I can see myself wanting to do this a LOT more times, and I think, if this plugin would allow it my life would be easier.
                                      Chris, certainly has other things in his mind though, because he hasn't dealt with plugins for ages, nor showed himself up around that often, but he is still very much connected to Sketchup and probably he could take a look at the script easily.
                                      If not... I'll have to deal with this kind of stuff myself or find alternatives...
                                      Thanks for your attention.
                                      www.casca.pt
                                        Random Rotation by Sdmitch πŸ˜‰
                                        • few Random Select by Tig + Scale Multiple does make the trick!
                                        • JQLJ Offline
                                          JQL
                                          Thanks Pilou I'll try Random Rotation
                                          www.casca.pt
                                            tomaszdrgas
                                            Does it work with sKetchup 2015.. ?
                                            I installed but nothing in Extensions>Chris Fullmer Tools> I have there extended views already.. Maybe issue is only the change of "plugins" folder name to "extensions"..
                                            Tomasz
                                            • 3 / 7
