[Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
Chris,
3 years later, this is still an awesome find. So useful, thank you. In regards to using the tool to generate randomization of camera-facing components...If you make a group of components (say three copies of a tree, already randomly placed and scaled), you can then create an array of that group. Application of your tool to the array will randomly scale-rotate the group and create an even more random disposition.
You've cut my tree-planting workload by a third. thanks again.
thanks a lot. you are great.
GREAT
THANK YOU
as always - a great tool again ! thank you
thank sir
once again THANK YOU! - A wonderful tool that I use almost daily
Wow! this is mind blowing. For its simplicity and effectiveness. Thanks!
I use this plugin almost everyday. Many thanks!
As a "power" user, I have noticed performance issues when applying the script to lots of components. In a model with hundreds of components, it gets very sluggish indeed, and the memory usage of Sketchup goes through the roof, and sometimes ends in a bugsplat.
I am happy to take a look and see what optimisations are possible in the ruby script, but before I do so, I should ask if you have had a go at optimisation already? Do let me know!
Tommy
Thanks for sharing this.. it will be very useful in my work. By the way, I have a similar need, this time multi-face scale plugin, to scale a multiple polygon/faces in one go. Is this possible? My screenshot:
Thanks a lot!
Just transform all your faces in group or component then apply the Scale multiple!
By Tig each face in Component
m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
You have in the same spirit the Multiple face Offset by Remus!
Thank you for a very usefull plugin
Hi Chris,
I know you've been busy with other things but I'd like to make a request on this plugin, if you wouldn't mind.
I'd like it to work on a choosen axis. Right now we can choose axis, center, base or world, but they all act acording to the Z axis. It would be cool to be able to choose the X or Y axis as a base too.
Thanks in advance,
João
this is a great suggestion - i join this request
You can solve that in rotate your objects before apply the script!
I know I can do that but I have 1643 individual objects that I wanted to randomly rotate.
They were 1643 groups all aligned to the Y axis. I could get inside each one of them and change the Y axis to become the Z axis. But I would be mad if I did that...
Also, I can see myself wanting to do this a LOT more times, and I think, if this plugin would allow it my life would be easier.
Chris, certainly has other things in his mind though, because he hasn't dealt with plugins for ages, nor showed himself up around that often, but he is still very much connected to Sketchup and probably he could take a look at the script easily.
If not... I'll have to deal with this kind of stuff myself or find alternatives...
Thanks for your attention.
Random Rotation by Sdmitch
- few Random Select by Tig + Scale Multiple does make the trick!
Thanks Pilou I'll try Random Rotation
Does it work with sKetchup 2015.. ?
I installed but nothing in Extensions>Chris Fullmer Tools> I have there extended views already.. Maybe issue is only the change of "plugins" folder name to "extensions"..Tomasz
