    [Plugin] !AdditionalPluginFolders - v5.4a - 27 Sep 20
    156 Posts 51 Posters 266.6k Views 51 Watching
    • fredo6F
      You seem to have a wrong installation of Curviloft.
      Could you please check the file and fiolder footprint.
        samyell77
        Ive been using the additional plugins folder with great success until recently. Im now not able to install extensions and am not sure what the problem is. Ive downloaded a couple of .rbz to the folded I have designated as my additional plugins folder. I have then gone to Window>Preferences>Extensions and gone to install extensions but Im now getting a message that tells me "This extension will have the ability to access the filesystem on your computer. Do not grant access to this lightly; be sure you trust the author. Do you want to install the extension." If I click yes it then takes me to an admin user name and password page? I had this working fine before but now for some reason SU won't load the plugins in this folder. Can anyone help..?
        I have deleted the 000_aditional plugins folder and have the following installed in my main plugins folder;
        AdditionalPluginFolders - v4.2a - 23 Oct 13
        LibFredo6.rbz
        Can anyone help me to resolve this ...?
        SU Pro 2016
        Dell Precision M4800
        PC Windows 10
        Intel Core i7-4900MQ @ 2.80ghz
        Nvidia Quadro K2100M
        16gb RAM
          The native Preferences > Extensions > Installer ALWAYS tries to use the main Plugins folder - you may not have sufficient permissions to do that - especially on a corporate or educational network...
          The SketchUcation Plugin Store toolset offers two possible options:
          1. A ../Plugins/SketchUcation submenu utility named 'Archive Installer'... this lets you auto-install from a RBZ [or ZIP] archive you have already downloaded onto your PC... and if you have a custom-plugins folder set-up it offers that as a potential destination...
          2. The SketchUcation Plugin Store's dialog which opens within SketchUp itself also offers you the choice of any set-up custom-plugins folder a destination for it's AutoInatll too...
            samyell77
            Thanks TIG - will play with this tomorrow. Have set the additional plugins setting to force it to ask if I want to use the non-standard plugin folder every time SU opens which seems to work for now.
            Sam
            SU Pro 2016
            PC Windows 10
            16gb RAM
            • C
              Clinton
              hi
              im trying to down load lib fredo 6 t run joint push pull where do I find the link ??
              if you can help great
                This is not the hard part ๐Ÿ˜’
                Search the Plugins forum, or see the PluginStore - search that for its instructions and download too ๐Ÿ˜•
                Also read its instructions carefully... and find / get the support 'Lib' and install that too...
                • G
                  g.moggel
                  Is it possible, that in Sketchup 2014 this doesn't work anymore? can anyone confirm? cheers.
                    Works just fine.
                    Get the latest version and the latest Fredo Lib from the PluginStore...
                    • P
                      pickprooflemon1
                      Unfortunately, im usng office pc which doesnt allow me to put anything into original sketchup plugin folder. Is there a way i can install the plugins externally?
                        Please complete your User-Profile...
                        If you have v2014, on PCs the default Plugins folder is now within your User path, so you should have suitable permissions...
                        But in earlier PC versions the Plugins folder is within the Program Files folder, and is therefore always restricted [unless the permissions are changed].
                        Assuming you have v8/v2013...
                        You need to convince the IT guys to install at least this one script [+ the LibFredo] in the main restricted Plugins folder.
                        It will load at startup and allow you to specify another Plugins folder for your own use.
                        You will then be able to install plugins into that folder [after a restart] manually.
                        Change RBZ to ZIP and extract the contents, keeping files in subfolders as they are shipped...
                        Unfortunately the native RBZ installer always uses the default Plugins folder, so you can't use that when you are restricted.
                        BUT if you have the SketchUcation Plugin Store tools installed, thereafter you can AutoInstall any downloaded RBZ using the 'Archive Installer' available from its menu - you will be offered your additional plugins folder in a dialog...
                        If you use the PluginStore dialog itself [run within SketchUp] you will also be offered your additional plugins folder for that AutoInstallation, without recourse to having a physical RBZ file at all... ๐Ÿ˜‰
                          Jooles13
                          Help! I do not have the Sketch up Plug-in file to drop anything in to!
                            A bit more info might help?
                            What plugin file are you missing?
                              If you mean the v2014 default 'Plugins' FOLDER... then if you Download the RBZ version of any Plugin from the PluginStore, then you can use the v2014 Preferences > Extensions > Install... button to automatically do the installation for you [remember that most of Fredo's tools also need his 'Lib', that is also available from the PluginStore...].
                              If you install the SketchUcation PluginStore toolset [see Resouces...] then you can then browse and AutoInstall Plugins from within SketchUp, without even having to download the RBZ...
                              That also includes a useful submenu item to open the Plugins folder for you, should you ever need to look into it...
                                jgt1942
                                Where in the heck do I find !AdditionalPluginFolders - I've searched the SketchUp Extension Warehouse as well as setchucation and the internet.
                                I have SketchUp 2014 installed on my Win8.1 system.
                                Looking at my system I do see C:\Program Files (x86)\SketchUp\SketchUp 2014\Plugins!AdditionalPluginFolders.rb and it is dated 3/4/2014 Do I already have the latest installed? How can I verify? Is it installed in the correct location?
                                Sorry but I'm lost.
                                jgt
                                  @jgt1942 said:
                                  Where in the heck do I find !AdditionalPluginFolders - I've searched the SketchUp Extension Warehouse as well as sketchucation and the internet.
                                  Sorry but I'm lost.
                                  Where did the C:\Program Files (x86)\SketchUp\SketchUp 2014\Plugins folder come from ?
                                  It is NOT made by SketchUp in SketchUp v2014.
                                  It is NEVER used !
                                  If you have made it manually, then please remove it - it will not auto-load any Plugins from within it anyway.
                                  If you have copied it over from say SketchUp v2013, then there is a good chance that some of its Plugins will be incompatible if reloacted in the correct folder!
                                  Get the latest versions of all Plugins and install those into the correct location...
                                  Most Plugins have been made compatible with v2014, but you need the newest versions of them.
                                  The default Plugins folder [from which any Plugins auto-load as SketchUp starts up] can be found using this snippet in the 'Ruby Console':
                                  Sketchup.find_support_file('Plugins')
                                  It is typically returned as:
                                  C:/Users/YourUserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                                  With ALL SketchUp versions since v8M2 you can AutoInstall RBZ archived Plugins using the Preferences > Extensions > Install... button...
                                  This is SketchUp 101 ๐Ÿ˜’
                                  You don't then need to worry about this as the correct default Plugins folder is always used...
                                  Aside - there is a potential 'shared' Plugins folder, which can be located in:
                                  C:/ProgramData/SketchUp/SketchUp 2014/
                                  BUT that is NOT made by SketchUp.
                                  If you [or an Installer App] add it manually, then its contents are also auto-loaded as SketchUp's starts up.
                                  This folder is not normally used - each User get their own Plugins folder.
                                  The native AutoInstaller always puts RBZ contents into the User's Plugins folder.
                                  The ProgramData Plugins folder is only useful when shared Plugins are used between several Users on that one PC.
                                  If you get the 'SketchUcation PluginStore Toolset' [install it from the RBZ downloadble from the Resources submenu item above]... then you can use that to AutoInstall Plugins directly - skipping the RBZ download altogether.
                                  Unlike the native AutoInstaller it also spots if you have any additional Plugins folders setup, into which you might want to install the Plugin, and it offers those alternatives where appropriate...
                                  Fredo's Additional Plugins Folder tool needs to load from the 'default Plugins folder' [which always auto-loads].
                                  This tool then allows you to specify custom Plugins folders - such as Dropbox or GoogleDrive - from which your synced Plugins can be auto-loaded as SketchUp starts on any PC...
                                  But before you jump into the world of Additional Plugins folders please ensure you have the proper defaults setup, and you understand how they work... ๐Ÿ˜•
                                    dgood133
                                    Hi Fredo ๐Ÿ˜„ having a slight issue with your plugins, I recently decided to update what is in my system and now whenever I start SU I get an error message from LibFredo6 saying some files are in error and cannot load, please see attached
                                    I have not had this issue before, and I have attempted to redo the install 3 times now with same resultโ€ฆ
                                    both using the old way of just putting in the plugins folder and running the auto install from within plugin store, also updated to the latest versionโ€ฆ
                                    osx 10.8, macbook pro, Sketchup8Pro
                                    any help greatly appreciated
                                    PS the plugins do seem to be working at least the ones that loadโ€ฆ
                                    D
                                    • fredo6F
                                      Did you try to open the trace log file and see what the error is?
                                        dgood133
                                        Hi sorry for late reply yes I opened the log but I am not sure how to read it I can post the results if will help
                                        LibFredo6Trace_8_1409587670470.txt
                                        • fredo6F
                                          You seem to have FreeScale still present in your plugins. This is a very old version of FredoScale. I suggest you remove the subfolder and rb file.
                                            dgood133
                                            Thank you fine sir!
                                            These plugins are incredible and you and the other developers are so generous of your time!
                                            D
                                            • 6 / 8
