    [Plugin] !AdditionalPluginFolders - v5.4a - 27 Sep 20
    156 Posts 51 Posters 248.3k Views 51 Watching
      @chon said:
      Issue with Shape Bender.
      It doesn't work when SB files and folder are placed in the AdditionalPluginFolder, but works fine when placed in the SU plugins folder.
      This is a known issue in any version using a non-standard Plugins folder.
      Reread the ShapeBender thread.
      I have recently posted a simple change to the loader script's code that fixes it to load from anywhere in the $LOAD_PATH list...
      http://sketchucation.com/forums/viewtopic.php?p=494591#p494591
      • chonC Offline
        chon
        Thanks TIG ! πŸ‘
        • chonC Offline
          chon
          TIG,
          thanks a lot for Shape Bender, works fine now !
          I've got the same problem with Didier Bur's Projections.
          Do you think you could do something for us if you've got a quiet moment ? 😳
            @Chon
            Edit the loader ' projection_extension.rb' file
            In line#2:
            Sketchup::require Sketchup.find_support_file("Plugins") + '/Projection/projection'
            add a leading # to disable it:
            #Sketchup::require Sketchup.find_support_file("Plugins") + '/Projection/projection'
            Then add in a line below it thus:
            Sketchup::require(File.join(File.dirname(__FILE__), 'Projection', 'projection'))
            It should now work properly from any Plugins folder's location, provided that the loader rb and the folder of other files are in the same Plugins folder... [although the rbs format for the main code file is an perhaps unknown quantity]...
            • chonC Offline
              chon
              Many thanks TIG ! πŸ‘
              I'll try that on monday morning. πŸ˜‰
              • chonC Offline
                chon
                Works fine ! Thanks TIG ! πŸ‘
                  crayonal
                  Error Loading File bootstrap_Curviloft.rb
                  uninitialized constant Curviloft::T6Error Loading File bootstrap_FredoScale.rb
                  (eval):1: uninitialized constant F6_FredoScale::T6Error Loading File CurviloftAlgo.rb
                  uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                  uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                  uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                  uninitialized constant Curviloft::T6Error Loading File __loader.rb
                  uninitialized constant Traductor
                  • fredo6F Offline
                    You seem to have a wrong installation of Curviloft.
                    Could you please check the file and fiolder footprint.
                      samyell77
                      Ive been using the additional plugins folder with great success until recently. Im now not able to install extensions and am not sure what the problem is. Ive downloaded a couple of .rbz to the folded I have designated as my additional plugins folder. I have then gone to Window>Preferences>Extensions and gone to install extensions but Im now getting a message that tells me "This extension will have the ability to access the filesystem on your computer. Do not grant access to this lightly; be sure you trust the author. Do you want to install the extension." If I click yes it then takes me to an admin user name and password page? I had this working fine before but now for some reason SU won't load the plugins in this folder. Can anyone help..?
                      I have deleted the 000_aditional plugins folder and have the following installed in my main plugins folder;
                      AdditionalPluginFolders - v4.2a - 23 Oct 13
                      LibFredo6.rbz
                      Can anyone help me to resolve this ...?
                      SU Pro 2016
                      Dell Precision M4800
                      PC Windows 10
                      Intel Core i7-4900MQ @ 2.80ghz
                      Nvidia Quadro K2100M
                      16gb RAM
                        The native Preferences > Extensions > Installer ALWAYS tries to use the main Plugins folder - you may not have sufficient permissions to do that - especially on a corporate or educational network...
                        The SketchUcation Plugin Store toolset offers two possible options:
                        1. A ../Plugins/SketchUcation submenu utility named 'Archive Installer'... this lets you auto-install from a RBZ [or ZIP] archive you have already downloaded onto your PC... and if you have a custom-plugins folder set-up it offers that as a potential destination...
                        2. The SketchUcation Plugin Store's dialog which opens within SketchUp itself also offers you the choice of any set-up custom-plugins folder a destination for it's AutoInatll too...
                          samyell77
                          Thanks TIG - will play with this tomorrow. Have set the additional plugins setting to force it to ask if I want to use the non-standard plugin folder every time SU opens which seems to work for now.
                          Sam
                          SU Pro 2016
                          PC Windows 10
                          16gb RAM
                            Clinton
                            hi
                            im trying to down load lib fredo 6 t run joint push pull where do I find the link ??
                            if you can help great
                              This is not the hard part πŸ˜’
                              Search the Plugins forum, or see the PluginStore - search that for its instructions and download too πŸ˜•
                              Also read its instructions carefully... and find / get the support 'Lib' and install that too...
                                g.moggel
                                Is it possible, that in Sketchup 2014 this doesn't work anymore? can anyone confirm? cheers.
                                  Works just fine.
                                  Get the latest version and the latest Fredo Lib from the PluginStore...
                                    pickprooflemon1
                                    Unfortunately, im usng office pc which doesnt allow me to put anything into original sketchup plugin folder. Is there a way i can install the plugins externally?
                                      Please complete your User-Profile...
                                      If you have v2014, on PCs the default Plugins folder is now within your User path, so you should have suitable permissions...
                                      But in earlier PC versions the Plugins folder is within the Program Files folder, and is therefore always restricted [unless the permissions are changed].
                                      Assuming you have v8/v2013...
                                      You need to convince the IT guys to install at least this one script [+ the LibFredo] in the main restricted Plugins folder.
                                      It will load at startup and allow you to specify another Plugins folder for your own use.
                                      You will then be able to install plugins into that folder [after a restart] manually.
                                      Change RBZ to ZIP and extract the contents, keeping files in subfolders as they are shipped...
                                      Unfortunately the native RBZ installer always uses the default Plugins folder, so you can't use that when you are restricted.
                                      BUT if you have the SketchUcation Plugin Store tools installed, thereafter you can AutoInstall any downloaded RBZ using the 'Archive Installer' available from its menu - you will be offered your additional plugins folder in a dialog...
                                      If you use the PluginStore dialog itself [run within SketchUp] you will also be offered your additional plugins folder for that AutoInstallation, without recourse to having a physical RBZ file at all... πŸ˜‰
                                        Jooles13
                                        Help! I do not have the Sketch up Plug-in file to drop anything in to!
                                          A bit more info might help?
                                          What plugin file are you missing?
                                            If you mean the v2014 default 'Plugins' FOLDER... then if you Download the RBZ version of any Plugin from the PluginStore, then you can use the v2014 Preferences > Extensions > Install... button to automatically do the installation for you [remember that most of Fredo's tools also need his 'Lib', that is also available from the PluginStore...].
                                            If you install the SketchUcation PluginStore toolset [see Resouces...] then you can then browse and AutoInstall Plugins from within SketchUp, without even having to download the RBZ...
                                            That also includes a useful submenu item to open the Plugins folder for you, should you ever need to look into it...
                                            • 5 / 8
