    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 433.5k Views 75 Watching
    • iichiversiiI Offline
      iichiversii
      Ok i got the Lib thing sorted but im still running into that issue where "mesh from heightmap" wont allow me to select depth, still confused, anyone else had this issue and solved it?
      Bring on the Rain...
      • fredziarzF Offline
        fredziarz
        Playing with it is cool, but there's a huge "BUT" πŸ˜‰ from two bitmaps I used in single SU file (400x400 & 200x200) it made my file 60MB big! It's much to much. My PC handles aprox.100MB files, but they're almost uneditable and hard to use. So what do we need this plugin for? Maybe some small not complicated architectural details? Simple scenes?
        maxwellrender v3
        maxwellrender v3
        • tt_suT Offline
          tt_su
          ? Can you describe your process?
          • tt_suT Offline
            tt_su
            400 * 400 = 160000 (that's just tiles - but these have to be triangulated, so the actual number of faces generated will be 320000)
            If you use a render engine that support proxies you can generate a high res mesh and generate a proxy object of it and use a low res mesh in your model.
              tosudatma
              i needs plugin Bitmap To Mesh for sketchup 2014 ,help me
              • tt_suT Offline
                tt_su
                It should work for SU2014. Download latest from SCF PluginStore or the Extension Warehouse.
                Or have you already done that and found errors?
                  mwoonkey
                  I cant figure this out, been trying for ages and cant make the plugin seeable from the plugin menu even after installing the extension.
                  running win7 with trimble 8.0.151158
                  I can get other plugins to work perfect but the TT_Lib2 not showing or the bitmap to mesh either.
                  any help please
                    This plugins doesn't add menus to the Plugins - it adds it to the Draw and Context Menu. See the description for details.
                    • dimixD Offline
                      dimix
                      Is it possible to take a closed loop of edges, and fill them with a bitmap?
                      Kinda like the Soap Skin & Bubble plugin douse.
                        Like a height map, or making faces out of each pixel?
                        • TandemT Offline
                          Tandem
                          I was stuck on the exact same problem and was able to make it work by changing my steps to:
                          1. File > Import...
                          2. Navigate to your image file, select it and click Import.
                          3. Place and size the image in SU.
                          4. Right-Click on the placed image and select Mesh from Heightmap.
                          5. Pick depth by clicking somewhere on the blue axis above the image.
                          6. The plugin will take some time to index the points and generate the mesh.
                            May have something to do with file format. I don't know.
                          Thanks thomtom for a great plugin. I am trying to use it to generate terrain from downloaded TIF heightmaps. Still trying to figure out what size image is doable.
                          • dimixD Offline
                            dimix
                            Yes like a height map (if i understand what a height map is correctly πŸ˜„ ).
                            If i have a spesific face that i have to work with, and it represents a water surface:
                            http://i.imgur.com/OGAljLM.png?1
                            I woud like to add small waves to that face like Mistro11 did in this post
                            Is there some way to bound the bmp to that face?
                              Why not just make the mesh from a rectangular bitmap and trim it to that shape after?
                              • tt_suT Offline
                                tt_su
                                The mesh would be incredible dense. Are you rendering the image eventually? I'd then put use the render engine and apply the bitmap as a bump map or displacement map instead.
                                • dimixD Offline
                                  dimix
                                  I agree with both of you. Trimming it or rendering it would be a solution. But still i am curious if it is possible to bind the bmp to a face.
                                    Lersince1991
                                    This plug in is amazing, thank you so much.
                                    But it took me a long time to find, I suggest in your extension warehouse keywords you add "Displacement Map" or Displacement baking and similar stuff to help others find it.
                                    • jojo9J Offline
                                      jojo9
                                      nice one, could be useful for landscape modeling in my case.
                                      ive probems to draw the depth plane.
                                      -i loaded a bitmap noise image into su
                                      -i defined the origin and width, while with depth im unable to confirm, the click is blocked.
                                      Also using a numerical imput and confirming that op doesnt work.
                                      (mac, su13 free)
                                        Any errors in the Ruby Console?
                                        • IneshtineI Offline
                                          Ineshtine
                                          Make sure the bitmap is 24bit and that it doesn't include color space information.
                                          What? you haven't tried Raylectron yet?
                                            cowboyathome
                                            To those people having an issue with not being able to click when prompted to Pick depth, make sure that the image you are using does not have any color space information. I believe that someone already mentioned this awhile back in the thread.
                                            The link below shows an image of the GIMP export settings when exporting a BMP image.
                                            Notice that I have Do not write color space information checked.
                                            I have no idea how to check if a BMP image has color space or not. Best bet is to open the image and save/export it without color space information.
                                            https://goo.gl/photos/knF2NPQ5fEhLrhe79
                                            • 13
                                            • 14
                                            • 2 / 14
