    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 484.7k Views 75 Watching
      tosudatma
      i needs plugin Bitmap To Mesh for sketchup 2014 ,help me
      • tt_suT Offline
        tt_su
        It should work for SU2014. Download latest from SCF PluginStore or the Extension Warehouse.
        Or have you already done that and found errors?
          mwoonkey
          I cant figure this out, been trying for ages and cant make the plugin seeable from the plugin menu even after installing the extension.
          running win7 with trimble 8.0.151158
          I can get other plugins to work perfect but the TT_Lib2 not showing or the bitmap to mesh either.
          any help please
            This plugins doesn't add menus to the Plugins - it adds it to the Draw and Context Menu. See the description for details.
            • dimixD Offline
              dimix
              Is it possible to take a closed loop of edges, and fill them with a bitmap?
              Kinda like the Soap Skin & Bubble plugin douse.
                Like a height map, or making faces out of each pixel?
                • TandemT Offline
                  Tandem
                  @iichiversii said:
                  Ok i got the Lib thing sorted but im still running into that issue where "mesh from heightmap" wont allow me to select depth, still confused, anyone else had this issue and solved it?
                  I was stuck on the exact same problem and was able to make it work by changing my steps to:
                  1. File > Import...
                  2. Navigate to your image file, select it and click Import.
                  3. Place and size the image in SU.
                  4. Right-Click on the placed image and select Mesh from Heightmap.
                  5. Pick depth by clicking somewhere on the blue axis above the image.
                  6. The plugin will take some time to index the points and generate the mesh.
                    May have something to do with file format. I don't know.
                  Thanks thomtom for a great plugin. I am trying to use it to generate terrain from downloaded TIF heightmaps. Still trying to figure out what size image is doable.
                  • dimixD Offline
                    dimix
                    Yes like a height map (if i understand what a height map is correctly πŸ˜„ ).
                    If i have a spesific face that i have to work with, and it represents a water surface:
                    http://i.imgur.com/OGAljLM.png?1
                    I woud like to add small waves to that face like Mistro11 did in this post
                    Is there some way to bound the bmp to that face?
                      Why not just make the mesh from a rectangular bitmap and trim it to that shape after?
                      • tt_suT Offline
                        tt_su
                        The mesh would be incredible dense. Are you rendering the image eventually? I'd then put use the render engine and apply the bitmap as a bump map or displacement map instead.
                        • dimixD Offline
                          dimix
                          I agree with both of you. Trimming it or rendering it would be a solution. But still i am curious if it is possible to bind the bmp to a face.
                            Lersince1991
                            This plug in is amazing, thank you so much.
                            But it took me a long time to find, I suggest in your extension warehouse keywords you add "Displacement Map" or Displacement baking and similar stuff to help others find it.
                            • jojo9J Offline
                              jojo9
                              nice one, could be useful for landscape modeling in my case.
                              ive probems to draw the depth plane.
                              -i loaded a bitmap noise image into su
                              -i defined the origin and width, while with depth im unable to confirm, the click is blocked.
                              Also using a numerical imput and confirming that op doesnt work.
                              (mac, su13 free)
                                Any errors in the Ruby Console?
                                • IneshtineI Offline
                                  Ineshtine
                                  Make sure the bitmap is 24bit and that it doesn't include color space information.
                                  What? you haven't tried Raylectron yet?
                                    cowboyathome
                                    To those people having an issue with not being able to click when prompted to Pick depth, make sure that the image you are using does not have any color space information. I believe that someone already mentioned this awhile back in the thread.
                                    The link below shows an image of the GIMP export settings when exporting a BMP image.
                                    Notice that I have Do not write color space information checked.
                                    I have no idea how to check if a BMP image has color space or not. Best bet is to open the image and save/export it without color space information.
                                    https://goo.gl/photos/knF2NPQ5fEhLrhe79
                                    • E Offline
                                      Efrado
                                      Hi Thom,I have been trying to install this jewel for three days,and not able to do.
                                      Had read several times almost every thing at the forums without success.
                                      Could you give me a hand please.
                                      My OS X 10.6.8 and Skp.8.0.15157 free.
                                      This is what appear in the ruby console:
                                      Failed to read /Users/AMADO/Desktop/PRUEBA 1.bmp
                                      BMP Magic Marker not found.
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_bitmap2mesh/core.rb:535:in read_image' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_bitmap2mesh/core.rb:472:in initialize'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_bitmap2mesh/core.rb:139:in new' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_bitmap2mesh/core.rb:139:in bitmap_to_mesh_tool'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/tt_bitmap2mesh/core.rb:44
                                      THANK YOU
                                        Can you share the image you try to load?
                                        • E Offline
                                          Efrado
                                          Thank you for your fast answering. By the way,what do I have to do to select image clicking the right button on my mouse.
                                          Continuing with the attempt to install the plugin (the only one after easy install) I got this message in the skp. screen
                                          https://cf.dropboxstatic.com/static/images/icons/icon_spacer-vflN3BYt2.gif
                                          this is the bmp image:
                                          https://www.dropbox.com/s/qcmig0ajnkn2p5r/Screenshot%202016-04-09%2011.05.35.png?dl=0
                                          Thankyou
                                            That first image doesn't appear to load. (You can upload directly to the forum btw.)
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 12 / 14
