    [Plugin] DoorMaker
    24 Posts 17 Posters 46.5k Views 17 Watching
      markitekt
      DoorMaker.rbI made some basic revisions to this myself to set different default settings.
      Thanks,
      Mark
      • EdsonE Offline
        Edson
        paul,
        DoorMaker is an invaluable plugin and I use it a lot. but there is one thing that I do not like about it: the fact that the geometry that make up frames and leaves does not remain on Layer 0. is there a way to change it?
        another thing that would be useful is to be able to decide the position of the door leaf at creation so that one does not have to delete the unwanted door positions afterwards.
        thanks again for a great plugin.
        http://www.mahfuz.arq.br
        • Paul RussamP Offline
          Paul Russam
          Hello all,
          I'd love to be able to help but to be honest this is the only plugin I ever wrote and looking at the code now I cant remember anything about Ruby 😳
          If anybody want to pick it up and run with it I'm more than happy for them to do so.
          Sorry.
          Paul Russam
          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
            markitekt
            No problem Paul. You have forgotten more Ruby than I'll ever know.
            Guess we'll have to leave it up to other interested parties.
            Thanks,
            Mark
            • E Offline
              element
              Thanks a lot for this πŸ˜† .
                smb5823
                Unfortunately Doormaker.rb which I use most days malfunctions when used in SU2014Pro.
                On initial startup if you don't change any of the option selections Door Maker inserts a simple door correctly.
                It will also accept different sizes for frame/leaf etc.
                Select any of the rebate options; panel types; kicker; nameplate options and it only creates an outline of the door.
                Shame cos it's one of my must have plugins....
                Anybody have the time and inclination to look at this with Ruby 2?
                  I have updated the script to v2.1 which will now be compatible with v2014.
                  I also took the opportunity to module-ize it and swap the hundreds of $ variables for @ and enduring @@ ones.
                  Get it from the PluginStore http://sketchucation.com/pluginstore?pln=DoorMaker πŸ˜„
                  • FrederikF Offline
                    Frederik
                    Thanks, TIG...! πŸ‘
                    I really enjoy using this little gem from time to time... πŸ˜„
                    Cheers
                    Kim Frederik
                      smb5823
                      Wow TIG
                      So fast........
                      Many Thanks for this.
                        caspajack
                        Hi Paul, I love this script it saves so much time. πŸ‘
                        A question though, can the width of the door leaf where the handle sits be changed to match the other side? In most residential doors these are equal, well here in the UK at least. πŸ˜„
                        Also the doors always appear relative to the red axis, is there a way to set them on the green?
                        I have looked in your instructions but can't see if this is documented anywhere.
                        All the best
                        Joe.
                          c_m1911
                          Well great PlugIn ..
                          Improvement wishes :
                          1/ It would be to have door as a instanced component, while modifying the D-00 leaf, all the other instances would change too ..
                          2/ Can you have a full glass door (clarit) without a frame around it
                          Thx, and best regards from France
                            billmorr
                            Hi Paul
                            Liking the door maker but doesn't seem to operate properly in 2015?
                            When trying to insert it in a wall on another axes (other than the red one) the door doesn't orientate itself to that axes (ie is always set for being on the red axes)
                            Hope that makes sense???
                            regards
                            Bill
                            • W Offline
                              woodchipz
                              DoorMaker was written in 2007 for Google SketchUp. The thread shows an update suitable for Sketchup 2014. I am using the last freestanding 2017 version. What must be updated for me to use DoorMaker? I am a savvy woodworking; not a ruby programmer. Help please?
                              WoodChipz newby (sorta)
                              • 2 / 2
