    [Plugin] SuSolid for 3d Printing (updated April 2014 )
    43 Posts 16 Posters 25.4k Views 16 Watching
      jonorman
      Thank you.
      New version works just fine. This is a great plugin and I`m still hoping for a COG feature πŸ˜‰
        tomot
        Its important to revive this thread, in light of David's ruby, which is capable of removing interior faces from solids. This can become a big deal if you import 3d geometry from other programs into SU. In addition its a requirement to remove interior unwanted faces if you intend to create 3D printed output of your geometry.
        For additional discussion, here is my initial inquiry about this topic:
        http://sketchucation.com/forums/viewtopic.php?f=323&t=22920&start=705#p462200
        cheers!
        my plugins
        tomot
        • I Offline
          iantyson
          The susolid free 1_1 version caused massive bug splats on my HP laptop. Windows 7, separate video card, i7 processor and lots of ram. I had to go through all my plugins to locate this one as the culprit. Next time I will load one plugin at a time and utilize sketchup to see if the latest plugin addition is not compatible. Instead I loaded plugins like crazy only to have this one give me bugsplats. Hope someone avoids the bug hunt like I had.
          • voljankoV Offline
            voljanko
            Finaly a new version !!! πŸ˜„
            %(#800080)[New version 2_2 (April 2014) , what's new:
            -Check for Reversed Faces in Analyse tool
            -Flip Reversed Faces tool (will do just that all at once)
            -Buttons Select (to hide the unused buttons from toolbar)
            -Analyse Filter (to skip some inspections for better see others)
            -Hide Solids (for better inspections of non-solids)
            -Hide Non Intersecting Solids (for better inspections of intersecting solids)
            -Inspection Line Width (for better see the small colored inspection lines)
            -SU 2014 ,SU2013 and SU8 compatible]
            SuSolid
            (www.susolid.com)
            [flash=425,355:2cbm4d4r]http://www.youtube.com/v/5apMm080yI8[/flash:2cbm4d4r]
            SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
            • kenK Offline
              ken
              The version I bought, 2011 and upgraded oin 2012, does not load in SKP 2014. And I looked at your site, there doesn't seem to be an upgrade that will load in 2014. So do I have to buy another to get a version that will load in SKP 2014?
              Note, I miss not having the program in 2014. "PIA" to save go to 2013, test than back to 2014.
              Thanks for your plugin
              Ken
              • voljankoV Offline
                voljanko
                Hello Ken,
                Due to many changes in every version of Sketchup and also due to many updates that I made in SuSolid Plugin,I have decided to offer the Lifetime Updates option to all my customers. That means you will receive every update of SuSolid "forever" ,for the modest price of 11 EUR (only once).
                With 3d printing I have received biggest demand to continue developing my plugin and I also have more ideas to make the SuSolid plugin more 3d printing friendly and up to date.
                So,if you find my plugin useful and want to support additional development,please make a purchase of the "SuSolid Lifetime Updates".I will send you (and to others) a link to your mail.
                And yes,the latest version is SU2014 compatible.
                David Malnar
                • voljankoV Offline
                  voljanko
                  Check out this new video related to 3d Printing from SketchUp.
                  Is about reversed faces,that cause my first ever printed 3d model to not have 1 hole that suppose to be.Later I discovered that the face in the hole was reversed.
                  This is why now the SuSolid plugin can show you and fix all reversed faces in solid model.
                  David Malnar
                  [flash=425,355:3j7eqwd4]http://www.youtube.com/v/7u0h0E_5EVA[/flash:3j7eqwd4]
                  • kenK Offline
                    ken
                    So I have the new version and I get this error on this file.
                    So any help would be appreciated.
                    Ken
                    Clamp to Jack V8.skp
                    • voljankoV Offline
                      voljanko
                      Ahh... is because of the construction line.If you delete it,you will have no errors.
                      Anyway I will exclude this error possibility from the code and send you a new version.In meantime just avoid construction lines for the tool that you were using.
                      Or you can use the free version till then,that don't have this bug,I have checked it and is ok with your model.
                      EDIT
                      The version is now corrected and checked on your model.
                      Also the version on the server is now updated.
                      But you can admit that i have a good debugging system πŸ˜‰ It shows me the exact line of code where the bug is πŸ˜„
                      David Malnar
                      • kenK Offline
                        ken
                        David
                        You did a quick turn around and the fix works.
                        Thanks for the quick turn around.
                        Ken
                        • H Offline
                          huky
                          Hey I love this pluging!! i buy full versiΓ³n im very happy with it, but how can i get the pro version for intersect tool?? i dont see on web site
                          • voljankoV Offline
                            voljanko
                            Hello and sorry for the late answer,for using the intersection tool you need the pro version of Sketchup.
                              Bobvandevoort
                              Hi Voljanko,
                              I have two questions.
                              First is there any other way than to pay by paypal (because otherwise I need to pay an extra 5€ just to charge a paypal account)?
                              Second question/suggestion is a little more complex.
                              Since The tool can check for intersection between solids it should also be able to check for touching solids (which on its self is not that useful) but I was wondering if a tool or function could be added (or maybe created by some else) that makes it possible to move components (my components are solids, so solids) along an axis until it touches the next solid in that direction (so as soon as it would be prevented in real life from moving any further).
                              Greetings,
                              Bob
                              • jgbJ Offline
                                jgb
                                Re: 2nd question.
                                SU already does "touching" indications when moving a comp towards another comp.
                                You need only grab the moving comp and when you move it into contact with the stationary comp, SU will flag it touching face or edge. You can move past that of course, but the move will hesitate a bit when the contact happens.
                                If you are contacting faces, then you can make one face a "Glue anything" and it will contact and stay put.
                                jgb
                                  Bobvandevoort
                                  @jgb said:
                                  Re: 2nd question.
                                  Thanks but it not exactly the same. If I were to moving an object along the z direction it might already by touching something on the left or the rigth that's in parralel with the movement direction. This will in reality only cause friction and not prevent the movement from happening (solvable for wood by sanding). Making this technique you described extremely hard to use and almost impossible if we talking about cylinders nested in bigger components and the cylinder is the object touching something.
                                  My main problem with using this is that it is really prone to errors, because I'm checking it by eye and I'm human (the amount of movements I have to checks is over 150).
                                  Anyhow, still thanks for the tip πŸ˜„
                                    cadmunkey
                                    Does this work in SU 2015?
                                    • voljankoV Offline
                                      voljanko
                                      Hello
                                      @Bob
                                      1.Other than Paypal it is possible to pay directly to the company bank account.Send me a PM for details.
                                      2.About checking of touching solids...if this is important for your design maybe you can scale every solid a little and then check the intersections.Otherwise I don't think that such a tool would be generally useful.
                                      @cadmunkey
                                      Yes, SuSolid plugin is running form the day one of SU2015 without any problems.
                                        cadmunkey
                                        @voljanko said:
                                        @cadmunkey
                                        Great, will make a purchase later today πŸ‘
                                          armsweak
                                          Is this still being actively developed? Will it work in SketchUp 2016?
                                            jhatcher
                                            I know I am late with this. I have SketchUp Make 2016 and it seems to work fine.
                                            • 2 / 3
