    [Plugin] SuSolid for 3d Printing (updated April 2014 )
    43 Posts 16 Posters 25.8k Views 16 Watching
      driven
      it would be very useful if the loader was a plain .rb file.
      at the moment it can't be launched from a separate directory which limits it's usability for a lot of 'ruby' uses who organise there rubies in sub or separate directories/folders.
      I also get this on a normal load with only this [+ the debug ruby's] in plugins and although it runs it may cause issues for SU or other rubies.
      Error Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/susolid no such file to load -- /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/susolid
      • voljankoV Offline
        voljanko
        Thanks John for pointing this out.I will check it and include the solution in the next version(expected this year).
        SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
          jonorman
          ERROR MSG..
          Never seen this before. My favourit tool, never had an issue with it. now this after reinstalling SU 8 PRO. any idea
          • voljankoV Offline
            voljanko
            @jonorman said:
            ERROR MSG..
            Hello,
            no problem,you just need a newer version.
            Please send me an email to info@susolid.com an I will send you a new version.
            David
              jonorman
              Thank you.
              New version works just fine. This is a great plugin and I`m still hoping for a COG feature πŸ˜‰
                tomot
                Its important to revive this thread, in light of David's ruby, which is capable of removing interior faces from solids. This can become a big deal if you import 3d geometry from other programs into SU. In addition its a requirement to remove interior unwanted faces if you intend to create 3D printed output of your geometry.
                For additional discussion, here is my initial inquiry about this topic:
                http://sketchucation.com/forums/viewtopic.php?f=323&t=22920&start=705#p462200
                cheers!
                my plugins
                tomot
                • I Offline
                  iantyson
                  The susolid free 1_1 version caused massive bug splats on my HP laptop. Windows 7, separate video card, i7 processor and lots of ram. I had to go through all my plugins to locate this one as the culprit. Next time I will load one plugin at a time and utilize sketchup to see if the latest plugin addition is not compatible. Instead I loaded plugins like crazy only to have this one give me bugsplats. Hope someone avoids the bug hunt like I had.
                  • voljankoV Offline
                    voljanko
                    Finaly a new version !!! πŸ˜„
                    %(#800080)[New version 2_2 (April 2014) , what's new:
                    -Check for Reversed Faces in Analyse tool
                    -Flip Reversed Faces tool (will do just that all at once)
                    -Buttons Select (to hide the unused buttons from toolbar)
                    -Analyse Filter (to skip some inspections for better see others)
                    -Hide Solids (for better inspections of non-solids)
                    -Hide Non Intersecting Solids (for better inspections of intersecting solids)
                    -Inspection Line Width (for better see the small colored inspection lines)
                    -SU 2014 ,SU2013 and SU8 compatible]
                    SuSolid
                    (www.susolid.com)
                    [flash=425,355:2cbm4d4r]http://www.youtube.com/v/5apMm080yI8[/flash:2cbm4d4r]
                    • kenK Offline
                      ken
                      The version I bought, 2011 and upgraded oin 2012, does not load in SKP 2014. And I looked at your site, there doesn't seem to be an upgrade that will load in 2014. So do I have to buy another to get a version that will load in SKP 2014?
                      Note, I miss not having the program in 2014. "PIA" to save go to 2013, test than back to 2014.
                      Thanks for your plugin
                      Ken
                      • voljankoV Offline
                        voljanko
                        Hello Ken,
                        Due to many changes in every version of Sketchup and also due to many updates that I made in SuSolid Plugin,I have decided to offer the Lifetime Updates option to all my customers. That means you will receive every update of SuSolid "forever" ,for the modest price of 11 EUR (only once).
                        With 3d printing I have received biggest demand to continue developing my plugin and I also have more ideas to make the SuSolid plugin more 3d printing friendly and up to date.
                        So,if you find my plugin useful and want to support additional development,please make a purchase of the "SuSolid Lifetime Updates".I will send you (and to others) a link to your mail.
                        And yes,the latest version is SU2014 compatible.
                        David Malnar
                        • voljankoV Offline
                          voljanko
                          Check out this new video related to 3d Printing from SketchUp.
                          Is about reversed faces,that cause my first ever printed 3d model to not have 1 hole that suppose to be.Later I discovered that the face in the hole was reversed.
                          This is why now the SuSolid plugin can show you and fix all reversed faces in solid model.
                          David Malnar
                          [flash=425,355:3j7eqwd4]http://www.youtube.com/v/7u0h0E_5EVA[/flash:3j7eqwd4]
                          • kenK Offline
                            ken
                            So I have the new version and I get this error on this file.
                            So any help would be appreciated.
                            Ken
                            Clamp to Jack V8.skp
                            • voljankoV Offline
                              voljanko
                              Ahh... is because of the construction line.If you delete it,you will have no errors.
                              Anyway I will exclude this error possibility from the code and send you a new version.In meantime just avoid construction lines for the tool that you were using.
                              Or you can use the free version till then,that don't have this bug,I have checked it and is ok with your model.
                              EDIT
                              The version is now corrected and checked on your model.
                              Also the version on the server is now updated.
                              But you can admit that i have a good debugging system πŸ˜‰ It shows me the exact line of code where the bug is πŸ˜„
                              David Malnar
                              • kenK Offline
                                ken
                                David
                                You did a quick turn around and the fix works.
                                Thanks for the quick turn around.
                                Ken
                                • H Offline
                                  huky
                                  Hey I love this pluging!! i buy full versiΓ³n im very happy with it, but how can i get the pro version for intersect tool?? i dont see on web site
                                  • voljankoV Offline
                                    voljanko
                                    Hello and sorry for the late answer,for using the intersection tool you need the pro version of Sketchup.
                                      Bobvandevoort
                                      Hi Voljanko,
                                      I have two questions.
                                      First is there any other way than to pay by paypal (because otherwise I need to pay an extra 5€ just to charge a paypal account)?
                                      Second question/suggestion is a little more complex.
                                      Since The tool can check for intersection between solids it should also be able to check for touching solids (which on its self is not that useful) but I was wondering if a tool or function could be added (or maybe created by some else) that makes it possible to move components (my components are solids, so solids) along an axis until it touches the next solid in that direction (so as soon as it would be prevented in real life from moving any further).
                                      Greetings,
                                      Bob
                                      • jgbJ Offline
                                        jgb
                                        Re: 2nd question.
                                        SU already does "touching" indications when moving a comp towards another comp.
                                        You need only grab the moving comp and when you move it into contact with the stationary comp, SU will flag it touching face or edge. You can move past that of course, but the move will hesitate a bit when the contact happens.
                                        If you are contacting faces, then you can make one face a "Glue anything" and it will contact and stay put.
                                        jgb
                                          Bobvandevoort
                                          @jgb said:
                                          Re: 2nd question.
                                          Thanks but it not exactly the same. If I were to moving an object along the z direction it might already by touching something on the left or the rigth that's in parralel with the movement direction. This will in reality only cause friction and not prevent the movement from happening (solvable for wood by sanding). Making this technique you described extremely hard to use and almost impossible if we talking about cylinders nested in bigger components and the cylinder is the object touching something.
                                          My main problem with using this is that it is really prone to errors, because I'm checking it by eye and I'm human (the amount of movements I have to checks is over 150).
                                          Anyhow, still thanks for the tip πŸ˜„
                                            cadmunkey
                                            Does this work in SU 2015?
                                            • 2 / 3
