    [Plugin] SuSolid for 3d Printing (updated April 2014 )
    43 Posts 16 Posters 27.1k Views 16 Watching
    • voljankoV
      voljanko
      Check out this new video related to 3d Printing from SketchUp.
      Is about reversed faces,that cause my first ever printed 3d model to not have 1 hole that suppose to be.Later I discovered that the face in the hole was reversed.
      This is why now the SuSolid plugin can show you and fix all reversed faces in solid model.
      David Malnar
      [flash=425,355:3j7eqwd4]http://www.youtube.com/v/7u0h0E_5EVA[/flash:3j7eqwd4]
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
      • kenK
        ken
        So I have the new version and I get this error on this file.
        So any help would be appreciated.
        Ken
        Clamp to Jack V8.skp
        • voljankoV
          voljanko
          Ahh... is because of the construction line.If you delete it,you will have no errors.
          Anyway I will exclude this error possibility from the code and send you a new version.In meantime just avoid construction lines for the tool that you were using.
          Or you can use the free version till then,that don't have this bug,I have checked it and is ok with your model.
          EDIT
          The version is now corrected and checked on your model.
          Also the version on the server is now updated.
          But you can admit that i have a good debugging system πŸ˜‰ It shows me the exact line of code where the bug is πŸ˜„
          David Malnar
          • kenK
            ken
            David
            You did a quick turn around and the fix works.
            Thanks for the quick turn around.
            Ken
            • H
              huky
              Hey I love this pluging!! i buy full versiΓ³n im very happy with it, but how can i get the pro version for intersect tool?? i dont see on web site
              • voljankoV
                voljanko
                Hello and sorry for the late answer,for using the intersection tool you need the pro version of Sketchup.
                • B
                  Bobvandevoort
                  Hi Voljanko,
                  I have two questions.
                  First is there any other way than to pay by paypal (because otherwise I need to pay an extra 5€ just to charge a paypal account)?
                  Second question/suggestion is a little more complex.
                  Since The tool can check for intersection between solids it should also be able to check for touching solids (which on its self is not that useful) but I was wondering if a tool or function could be added (or maybe created by some else) that makes it possible to move components (my components are solids, so solids) along an axis until it touches the next solid in that direction (so as soon as it would be prevented in real life from moving any further).
                  Greetings,
                  Bob
                  • jgbJ
                    jgb
                    Re: 2nd question.
                    SU already does "touching" indications when moving a comp towards another comp.
                    You need only grab the moving comp and when you move it into contact with the stationary comp, SU will flag it touching face or edge. You can move past that of course, but the move will hesitate a bit when the contact happens.
                    If you are contacting faces, then you can make one face a "Glue anything" and it will contact and stay put.
                    jgb
                    • B
                      Bobvandevoort
                      @jgb said:
                      Re: 2nd question.
                      Thanks but it not exactly the same. If I were to moving an object along the z direction it might already by touching something on the left or the rigth that's in parralel with the movement direction. This will in reality only cause friction and not prevent the movement from happening (solvable for wood by sanding). Making this technique you described extremely hard to use and almost impossible if we talking about cylinders nested in bigger components and the cylinder is the object touching something.
                      My main problem with using this is that it is really prone to errors, because I'm checking it by eye and I'm human (the amount of movements I have to checks is over 150).
                      Anyhow, still thanks for the tip πŸ˜„
                      • C
                        cadmunkey
                        Does this work in SU 2015?
                        • voljankoV
                          voljanko
                          Hello
                          @Bob
                          1.Other than Paypal it is possible to pay directly to the company bank account.Send me a PM for details.
                          2.About checking of touching solids...if this is important for your design maybe you can scale every solid a little and then check the intersections.Otherwise I don't think that such a tool would be generally useful.
                          @cadmunkey
                          Yes, SuSolid plugin is running form the day one of SU2015 without any problems.
                          • C
                            cadmunkey
                            @voljanko said:
                            @cadmunkey
                            Great, will make a purchase later today πŸ‘
                              armsweak
                              Is this still being actively developed? Will it work in SketchUp 2016?
                                jhatcher
                                I know I am late with this. I have SketchUp Make 2016 and it seems to work fine.
                                • KnottyRicoK
                                  KnottyRico
                                  Anyone here from the developer? This still under active development? πŸ˜‰ Looks very interesting. If not, any recommendations for similar tool(s)?
                                    missedupmind
                                    hello,
                                    i just purchased the plugin .. and im hoping i get it at the earliest. i used the paypal acount with the nick used here.
                                    please send me the plugin asap, im in somewhat of a hurry
                                    • 2 / 3
